- SOLD!!!!!!!!!!!!!Spec-R Group A Dump T-Piece & Braided hose
- Sold ...........
- 3door clocks
- Fuel Line Clips
- wanted - 3 door rs cosworth genuine back box
- grp a coil n leads
- Cosworth carbon fibre heatsheild SOLD
- Cosworth 4x4 parts
- Gizzmo boost controller/diff/ other bits inc rs500 fg bumper.
- 3 door parcel shelfs
- 2wd rack and crossmember
- Ap racing clutch
- Grey Injectors
- TT T3/34 mar'M shaft
- 2wd front crossmember, ps rack, ps pump, hubs
- Cosworth leather rear seats
- Saff Cosworth rear bumper
- Cosworth 2wd rear beam complete or split
- 4x4 thermostat housing
- Sierra 3dr cosworths x 2 and 2wd saff for breaking
- GT3071.82 internal gate turbo .......prov sold
- 3 door electric window switch and regulator
- free interior plastics
- KentCams springs and retainer
- Secs monitor
- Garage clearout
- EsCos WRC grille
- secs monitor
- 4x4 Cosworth Alternator - reduced to £55 delivered
- 3 door cos bonnet
- Brand New Motorsport Leads (Coil-Pack)
- Sold...
- polybushes, saf window switches and strut tops
- GT3076R
- 2wd konis,leather door cards+other parts
- Cosworth parts clearout!!! Can take to classic ford
- Brand new GTX3071 for sale
- cosworth Turbo T34
- sierra cosworth 2wd original suspension
- 909 Cosworth top mounts
- Powerflex front end kit
- Cosworth 4x4 samco lower rad hose in blue. brand new
- sapphire front bumper
- Bosch 044 pump
- Ford Racing Gauges with surround
- Gauges - Racetech, Collins, Escos Pillar Mount
- Escort cosworth whale tail and rear pop out windows
- 2wd standard exhaust, refurbed front hubs
- Safety devices 6 point roll cage (saph)
- RS 4 Spoke (fair condition) SOLD
- Mint sapph dash in grey
- Stack 30psi Boost Gauge SOLD
- Escort Cosworth plug cover
- 3Bar Boost Gauge
- Big spec saph breaking pics page 2
- 2wd cos near new brakes front and back
- coilovers for saph
- boost gauge and filter
- Stainless 3 inch 90 degree exhaust bends
- Garage broken into last night
- Deposit taken on shell. Lots of other parts still forsale.
- Safety Devices cage for saph and 3dr.
- grey injectors,3 bar,bd10,l6 ecu
- B&M short shift / Motorsport leads /.48 exhaust housing / AP clutch / 4x4 heat shield
- Escort Cosworth WRC (Mike Little Prepared) Breaking
- Cone filter shield.
- GGR group A dump valve
- Siemens 83lb low impedance injectors NEW
- sapphire door mouldings
- 4x4 exhaust manifold
- l6 ecu with msd stage 3 chip
- cosworth L1 ecu with stage one chip
- Few bits
- Set of Greens
- MSD 4x4 plug leads
- RED Sierra Cosworth Wiring Loom Clips 3Door & RS500
- Brand new 2wd Cosworth front brake pads
- 2wd cosworth big brake upgrade kit
- 2wd Saph cosworth parts
- L8 ecu
- sparco adjustable sidemounts
- Escort Cosworth Fog Lights
- Saph Morrettes, Pace Breather and other bits.
- breaking stage 3 2wd sapphire
- Cossie 2wd Brembo brake kit
- cosworth grpa/wrc brackets for ap's
- bells and brackets for ap's
- Sierra cosworth 2wd and 4x4 breaking
- few bits,carbon splitter, fuel cell
- sold
- sold
- More spares found cosworth, twin plate, hyd..
- few bits from clearing out the garage
- Lots of 4x4 & 2WD Saph parts *UPDATED 03/03*
- ST Es Cos Plenum & Pro Alloy Breather
- BIG SPEC 4x4 SAFF BREAKING H71 YAP PHOTOS
- 4x4 rear driveshafts
- whats it worth? L8 ECU...
- some Cosworth and Ford parts for sale
- Cosworth Badges
- 3 Door leather interior
- spec-r group a dumpvalve
- found some more bits...
- sold
- rs 4 spoke steering wheel
- MSD diff mount
- Powder Coated 4x4 18mm Rear ARB with Clamps & 2WD PAS Pump
- SOLD - 2WD Cosworth Ferodo Racing front brake pads
- Escort Cosworth Stainless Steel Exhaust 3"
- 4x4 Up-rated Engine And Gearbox Mounts
- Escort Cosworth Under Bonnet Bling
- Mint leather full trim SOLD
- 3door dashboard been flocked grey £50 SOLD
- Cossie samco oil return hose
- Saph Morrettes
- 2wd konis, B&M shifter and cam belt cover
- FRS Brembos, disks,pads and mounting brackets
- MSD wasted spark kit
- Head lining Escort c Cosworth
- MT75 Fix IT Big Tooth Gearbox With 4.4 Drop Gear Set
- MSD Wasted Spark Loom
- Breaking Escort Cosworth
- Saph cosworth genuine ford front cross member
- t34.63
- Fully adjustable top mounts
- Tilton bias peddle box and external w/gate
- Gt3076 and exhaust manifold. * ALL SOLD*
- Turbo cooler - sold
- whats it worth 3dr L1 ecu with stage 1 chip
- Cossie 2wd mongoose exhaust
- es cos parts
- escort cosworth walbro pump
- MT - Motorsport
- Small turbo steering wheel
- 3 door / Saff / Escos bits
- escort cosworth smoked rear lights new + dashboard
- Cosworth Goodridge braided custom two piece rear brake hoses **SOLD**
- Cosworth Goodridge front & rear braided brake hoses **SOLD**
- 225/45/16 Avon ZZ1's
- Escort cosworth Boot catch
- sold
- 4x4 Front Diff £60 - Alloy Turbo Heat Shield £100
- Sierra cosworth 2wd for breaking
- saph raven leather door cards
- T34 turbo
- 2wd saff cossie parts for sale
- siemens 55 black injectors, turbo
- Bosch grey injectrs
- Genuine Escort RS Cosworth Whale Tail - Imperial Blue
- Stack dash
- Turbonetics GTK550 turbo
- SOLD
- Escort Rs cosworth running gear
- Msd chip 55lb siemens t38.63
- sold
- Trim bits Escort Cosworth
- Cosworth parts
- Cosworth 4x4 Throttle Body Modified For Anti Lag
- Garrett GT30 Turbo With 0.63 Housing
- Sierra Cosworth Rad, Fans and Master brake cylinder
- 4X4 grpN uprated front shafts, (pics now up)
- 4wd Cosworth front brake discs 273mm - £30
- -31 actuator
- Pectel t2 ecu and loom, pedal box, dry sump and more on ebay
- brand new escort cosworth door / window scapper mouldings
- *SOLD* Brand New GTX 3076 Tial V-band exhaust housing
- new bara gearbox
- Group A genuine 4wd steel front crossmember
- escort cosworth rolling shell
- 2wd saffire cosworth in for breaking
- Omp bucket seat harness side mount
- Escort Cosworth Rollcage 6 point
- saph cosworth 4x4 front koni's (still available)
- Push on gear knob
- 2wd Cosworth 4 pot Calipers - £45 delivered
- Nice crackle black complete inlet manifold
- 3dr carpeted dash, heater matrix
- Bailey Motorsport 2WD Header Tank
- T4 Turbo
- Pro Alloy RS500 Intercooler SOLD SOLD
- 4x4 Rear ARB and 2WD PAS Pump
- Saph cosworth front bumper
- 044 fuel pump - SOLD
- Small turbo inlet, dark green 803 injectors
- Parts for Sale... T38, fuel pump, inlet etc
- Escort Cosworth Group A LHD Rally Car Breaking, 9" Rear Diff, AP brakes
- Comp MO 18x8 Old Style 6-spokes Gloss Black (A048's)
- 3dr cosworth breaking
- brand new willans 3" harness on e bay
- Few parts. Seals and rail added 22/1/12
- KNOCK LINK - Engine Safegaurd
- Rear Quarters
- 2wd saph cosworth parts
- 2wd drive welded diff
- Dump valve and airbox
- A few 3 door/ Cosworth bits for sale, Prices lowered to shift.
- SOLD!!!
- 2wd cosworth parts
- 3dr cosworth rear lights
- Escort and Sierra Cosworth Parts
- sold
- A few parts for sale.
- 3 door breaking
- Battery Relocation Cabling (to boot)
- Cosworth oil pressure switch adaptor block
- Parts for sale, secs, plenum, NOW WITH PICS AND MORE PARTS,NOW ON EBAY
- Focus Rs front brake set for 2wd*now on ebay*
- 3DR doors now on ebay with hayward and scott exhaust - no res
- cosworth parts escort sierra 2wd 4wd
- Garett GT3071R Turbo
- Cosworth Parts
- Some lovely bits for you Cosworth guys ;) UPDATED 16/01
- Ap 6 pots to suit 330x28 discs
- Apexi 60mm 2bar boost gauge for sale
- Aim Dash
- Various Parts off my 2wd!! New part 14\01\13
- Pectel board for l8 ecu & bt escos beru leads
- Rs 500 front bumper
- Cosworth 4x4 7" rear Diff - £150
- 3" bore stainless steel silencer with 3.5" rolled in tip - Pics Added
- Escort nomad rear lamps
- Garage clearout, manifold, mounts, rad, fans etc...
- Cosworth 2wd B&M Quickshift... SOLD
- Cosworth parts
- pro alloy radiator and rad fans
- Escort cosworth carbon a pillars SOLD
- 2wd diff..
- Escort Cosworth Big Spec Breaking
- 2wd rear cosworth CV boot kit
- sold
- sold
- Sapph jacking point cover
- Reyland bells and brackets For cosworth ap brakes £185 delivered
- dump valve
- 4x4 handbrake cable wanted
- 380mm 6pot 2wd front Brake Kit (Reyland Bells)
- saph boot and spoiler
- L6 stage 4 powerchips with ecu...
- Suspension
- Evolution Chip 4x4 cos
- Swedish pleunm New ! Never Been Fitted !
- 2wd cosworth front hubs
- 2wd cosworth rear calipers
- Cosworth steering wheel
- saph shell
- Cosworth Parts
- B&M shifter for 2WD, T5
- Cosworth looms and intake manifold
- Sierra/saff 2wd cos koni's
