PDA
View Full Version : Ford RS Cosworth Parts for Sale
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 [26] 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
  1. AP Racing 4 pot 330mm Escort Cosworth complete kit grooved discs
  2. all my cos parts
  3. 2wd cosworth head.
  4. few cosworth bits
  5. 2wd or 4x4 brembos,brand new quaife thick wall atb, 4x4 leda 3way adjustables
  6. L8 ecu withall the toys-what's it worth??
  7. Rouse Rear Spoiler Gaskets
  8. AIM MXL Strada & Carbon Surround *PRICE DROP*
  9. Saff 65mm gauge holder (pillar)
  10. Sikolene oil x 2
  11. cosworth bits
  12. sold
  13. ford racing boost **open to offers**
  14. cosworth part's
  15. Morettes for saph cosworth
  16. 2WD saph cossie breaking in Ireland
  17. Bailey dump valve
  18. smoked lamps
  19. saph/3 dr pro alloy intercooler (PROV SOLD)
  20. Cosworth Crank
  21. radtec intercooler and radiator with twin fans BRAND NEW
  22. New bd14 Inlet cam and Escos EECIV throttle housing,ISCV & throttle sensor
  23. Group n cosworthfuel filter&fittings
  24. New bd14 Inlet cam and Escos throttle housing,ISCV & throttle sensor
  25. AP 330mm 4 pot brakes 2wd
  26. seimens 72lb cossie injectors....
  27. POSSIBLY breaking 89 2wd saff
  28. Collins alloy actuator
  29. Full escort cosworth wiring loom and fusebox
  30. 18" white compomotive mo's
  31. what are they worth????
  32. gaskets/seals
  33. bosch 8bar pump, redtop, swirl pot
  34. 909 escort cosworth breaking
  35. 2wd exhuast manifold+2wd prop..update..23/02/10
  36. Compomotive CXN 17" wheels
  37. Spark plug size for yb cosworth engine please
  38. Ford Sierra & Escort Cosworth Uprated Differential Mounts.
  39. 2wd sump..............sold
  40. RS 4spoke steering wheel
  41. 2wd saph bits 4sale
  42. New msa regs Aeroquip hose and fittings
  43. Bnib. Rs500,70mm.&rad,60mm airtec. NOW SOLD
  44. cossie parts
  45. motorsports leads
  46. 4x4 Cosworth Parts - Block, Head, Crank,Sumps
  47. Cosworth parts
  48. Morettes, buckets, brakes and comp MO's
  49. brand new racetech gauges + more...
  50. Compression struts
  51. polished throttle cable bracket
  52. New Webshop Online... Your Help Appreciated and rewarded...
  53. AP 6 pots with 368mm discs for sale
  54. AP Racing Brakes + Steering Rack (needed)
  55. Cosworth racing pistons, low comp
  56. SOLD
  57. Some ecos part
  58. 200 block/bottom end cosworth
  59. Forge oil breather Inc goodridge fittings(Picture off car)
  60. Swedish Plenum
  61. cossie parts for sale
  62. Cosworth Carbon plug cover(small turbo)
  63. 2wd Cam cover, Fog lights, 2wd Polished oil filler cap and side skirt clips
  64. Standard fuel pump
  65. 3dr cosworth rolling shell
  66. Remote idle control valve fitting.Now with pics
  67. 4x4 inlet with 14mm spacer
  68. Cosworth turbo heatshields
  69. Cos Interior... parts
  70. Rouse splitter
  71. wrc multi layer head gasket
  72. SOLD
  73. escort cosworth morettes
  74. Carbon cambelt cover
  75. Ford racing boost gauge
  76. T34 Turbo
  77. Momo Steering wheel boss
  78. Anthracite TSW Imolas with Toyo 888's Fitted
  79. std grind cossie crank
  80. Polished 2WD Plenum Cover and Elbow
  81. Aquamist Water Injection Dash Display System
  82. 2wd diff
  83. escort cosworth rs 500 style intercooler
  84. 5x Pirelli PZero tyres 225/650x18
  85. rs 500 intercooler pace
  86. 2wd callipers, disks, pads, lines
  87. defi gauge and control panel
  88. s/s cambelt cover and k&n air filter. ending ebay tonight
  89. few 3 door bits
  90. 2wd saph koni's
  91. Brembo 4pots and 330 disks
  92. cosworth lambda sensor
  93. Focus brembo 2wd set up NOW WITH PICS
  94. Aeroquip fittings
  95. 3dr trim and 3dr parts 3dr breaking
  96. 3.92 CWP ,7" Cosworth 4x4 Diff
  97. RS500 Pace Intercooler and Rad
  98. omex 600
  99. cosworth crank + various other cosworth spares
  100. White clocks and 2wd oil pump
  101. bailey breather **now with pics**
  102. Escort cossie new thermostat and fan switch
  103. 2wd engine.
  104. T34 Turbo - air roose hose
  105. GT35/42 turbo
  106. Cosworth parts for sale - few more bits added !!!!
  107. Various Items For Sale
  108. Wanted
  109. Cosworth Parts For Sale
  110. Few Sapphire Cosworth Bits
  111. cosworth chips
  112. cosworth adj's & compression struts
  113. Cossie brakes for sale Willwood superlites on ebay
  114. 3Dr/500 Boot Carpet
  115. T34 Air Filter + Hoses
  116. Fast ford and performance ford year sets from 88 on
  117. Cossie Clearout(Updated 03/12/10)
  118. *SOLD* Auto Meter Electrical Fuel Pressure Gauge
  119. set of rear konis -cosowrth- sold pending payment
  120. ** Cosworth spares **
  121. Ford RS Boss 501 2678 for sale £30.00 INC P&PP
  122. sierra mk1 rs cosworth front grill
  123. group a t34
  124. T34.55
  125. Polished Spec-r swirl pot, polished bailey breather kit, polished header tank
  126. *BREAKING* j plate 4x4 saph new parts added, *PRICES REDUCED*
  127. 3dr trim
  128. Last of the leftover cossie Bits!
  129. Bailey pas and washer bottles
  130. Brand new 4x4 Escort/Sierra Cosworth ex manifold
  131. RS500 splitter (rep)
  132. 6 pot 330mm willwood front brake setup for cossie of my sapph(SOLD)
  133. Reyland 2wd hyd clutch bellhousing
  134. white sapphire 4*4 bonnet with vents & Green injectors
  135. escort cossy leather
  136. erl aquamist systm 1s
  137. a couple of saph bits
  138. few cosworth bits more bits added
  139. sierra cosworth ecu to run greys wanted
  140. escos carbon heatshield
  141. Few 3dr parts
  142. **Escos project breaking, plus many other spares!** updated 8th june
  143. Screamer Pipe Silencer.....
  144. cosworth parts ive got on ebay
  145. cosworth parts
  146. AP Racing CP6600 caliper brake pads
  147. Gated sump baffle plate
  148. RS 3 spoke steerin wheel
  149. Carbotech XP8 pads to suit AP 4 pot CP5200s
  150. Few cossie bits
  151. saph head light protectors
  152. mint 3 door dash now sold sold sold
  153. all sold!
  154. RS500 Turbo NEW and used 247 maram shaft
  155. Bara box
  156. S8 ecu for sale
  157. Apexi Active Tailpipe Silencer
  158. A1 level 6 chip
  159. 2wd saff parts last bits! inc ENGINE! defi's
  160. saff double pillar pod and spec r heatshield
  161. Genuine 3 Door Wing
  162. Teflon fuel hose
  163. Stainless Steel Cable Ties (Prov All Sold For Now)
  164. brand new drivers side amber saff indicator
  165. FAO All Cosworth 2 and 4wd Owners. Great New Products For You!
  166. Garrett GT4088 new price!!
  167. Repsol Escort cosworth rolling shell
  168. Saff Panels
  169. Cosworth mirror image breather *SOLD*
  170. atl race fuel cell
  171. NOS Genuine Ford Cosworth Parts
  172. front strut brace and 2wd front coil overs
  173. Sapphire cosworth grooved front discs..
  174. cloth interior
  175. Cosworth cam cover, SOLD
  176. genuine 3 door bonnet vents
  177. 2WD suspension / brakes
  178. Group A bias brake pedal and cylinders
  179. Silkolene Pro-S & Pro-R just £38 5L for Limited Period Only!
  180. Pro Alloy intercooler, rad, and ggr breather+ M600 BHP reg
  181. 3 door bonnet vents
  182. New k&n cone filter trumpet+ other bits
  183. 4x4 koni strut/shock
  184. sold.....
  185. Oval ford badges several highest offers takes em
  186. Stage 2 4x4 Adjustable Rear Beam PROV SOLD PENDING DEPOSIT
  187. T35 Hybrid Turbo 0.63!!!!!!!!!
  188. teflon braided ptfe -6 fuel hose
  189. saff cos 4x4 dash £30+ some trim parts
  190. p8 ecu
  191. 3dr cosworth shell sold sold sold
  192. brand new bosch fuel pumps for sale
  193. positive battery terminal covers - new genuine ford.
  194. es cos chrome/shiney bits etc
  195. standard 3 door downpipe
  196. 4x4 Cosworth Parts + Esc Cos Interior...
  197. New years clear out, Ecu, manifolds, ect
  198. 480BHP Cosworth TURBONETICS turbo system (manifold, external wastegate, turbocharger)
  199. New 200 block
  200. escort cosworth grill
  201. 530bhp engine for sale
  202. crank pulley
  203. compression struts and ap paddle clutch
  204. 580BHP engine for sale
  205. .
  206. compbrake compression struts
  207. T35 Turbo
  208. 3 dr leather interior complete..MINT
  209. 4x4 Gearbox for sale
  210. Comp mo's x5 as new 8x18 et 15
  211. various seals and cometic gaskets
  212. Cosworth Engine Parts - Crank, Pistons, Rods
  213. MINT 3 Door Cossie trim
  214. Saff flocked dash
  215. Escos azev a's brand new boxed 18's
  216. Avo coilovers 2wd boxed new never used
  217. sierra cosworth rear beam poly bushes
  218. 2wd saff light grey front seats
  219. Bilstein Mag Coilovers, Mongoose Exhaust ect
  220. BD10's and 4x4 inlet
  221. 4x4 cosworth old bits
  222. Bailey piston dump valve
  223. MSD Chip Sapph Cosworth (L8) *New Price*
  224. 3dr cosworth front seats
  225. what is this worth?
  226. 2wd saff rear amber lights
  227. airtech 500 cooler
  228. 3 door rear beam and swinging arms
  229. Aeroquip fitments and hose
  230. Cosworth spares
  231. Cosworth rad for sale
  232. 2 Minty mint front seats 3dr Cossie for sale
  233. T38 turbo for sale
  234. Cosworth bits - See inside! ( some wasted spark stuff)
  235. 3door, 2wd, 4wd parts
  236. specialised indoor car cover
  237. Gearbox oil cooler for sale and Quaife diffs ect ect
  238. 2wd cosworth breaking, engine, bb big turbo, external wg, bd14, adjustable suspens
  239. Escos Morettes and 500 grills and smoked rears(Pics added)
  240. 3 door parts, baileys, rs500 hose, samco hose kit
  241. BD14 Inlet cam for sale
  242. 4x4 focus cosworth shell
  243. BRAND NEW GT28RS Turbo
  244. R&B Poly Diff Mount
  245. Cosworth Autospecialist STAINLESS CAM COVER FOR SALE
  246. Bd12 inlet cam 2wd for sale
  247. Rs 500 spec T4 and AP 5200 calipers, 403 greys.
  248. 3 door bits
  249. Escort Cosworth Grey Hex Interior...
  250. Few Cos bits
