- COSWORTH PARTS POSTAGE INCLUDED
- Plastic gear surround for 4x4 Sapphire Cosworth
- sold
- My 7.5" Cossie Gripper plated lsd will be for sale
- Lot of race Cosworth parts
- 4x4 MT75 Gearbox Sold Please delete. Thanks
- Pace Breather Pot
- New heavy duty conrods & front caliper repair kits
- 2wd Cossie head
- Mocal oil cooler , new and unused
- T34.63 / wiring loom
- Sapphire Cosworth Leather trims the best you will find £400
- freshly powder coated fuel pump braket
- 4x4 bits
- 4X4 COSSIE CALIPERS AND TAROX DISCS/PADS
- 200 blocked short engine SOLD
- L6 ECU with Stage 3 Chip and MSD Coil pack £220 delivered
- Cossie Paddle Clutch Plate SOLD
- Set of Fully refurbed Focus RS Alloys (no Tyres)
- Set of Dark Greens (803s) £100
- cossie parts, block, pistons, k&n, intercooler on ebay
- Cossie 2WD T34 SOLD
- Sapphire Cossie Panels
- Genuine Ford Escort Cosworth Topspoiler SOLD
- 3 BAR MAP SENSOR***VIRTUALLY NEW!!***
- saph cos door
- cosworth 4x4 rear brakes disks & calipers
- sierra cosworth 4x4 front crossmember
- 2wd cos engine good spec £1300 now with pics
- 4X4 Koni's and rouse boost / coolant hoses, prices updated.
- 2 wd Cossie Mongoose systems
- Cossie intercoolers
- 2wd Cossie Konis
- 2wd Cossie 4Pots + Tarox Brand new Combi Disc's,Pads
- Bailey turbo damper, New forge headertank
- AIR INJECTORS***SOLD***
- brand new 2wd rear calipers and brackets**(sold)
- 3 BAR MAP SENSOR (REPAIRED)****PROV SOLD****
- BRAND NEW CARBEAU SEATS
- 4x4 bonnet in black(SOLD)
- 1/24 saphire models
- ESCORT COSWORTH bling header tanks PROVISIONALLY SOLD !!!
- 2WD Flint Grey Cosworth *JUST IN FOR BREAKING*
- 2wd rear set up
- Escort cos parts for sale (with pics)
- 3DR BREAKING (got my cossie head back on )
- Compomotive wheels for 2wd 17"
- brand new never used garrett gt35
- ap caliper brackets..2wd coz
- 2wd oil pump
- *******2wd Sapphire Cossie just in for breaking*******
- T4 Rs 500 turbo
- cosworth bits for sale
- workshop manuals and wiring diagrams for sale
- no longer for sale
- 4x4 power steering rack
- t34 / t35 TURBO AIR FILTER SAMCO HOSE
- 3 Door Cosie trim
- Sapphire Cossie Leather trims
- cosworth parts
- sold
- brand new bosch 403 greys
- 4wd AP 4 pots. 330mm
- 2wd 330mm brembo's
- sapphire shell any good to anyone?
- cossie spares/parts----------updated 12/3/07 (PARTS ADDED)
- Escos carbon front spoiler and hockey sticks
- Big and main bearing shells on ebay
- Stainless Steel Coil Cover & Ignition Coil
- DIY Coilpack leads
- CompB4 330 Brake kit 4x4 or Ecos
- Wizards Of Nos minimax
- grp a coil
- escort cossie parts
- cosworth parts, now on ebay
- 4x Brand new Bosch 403's with fitting kit
- Rebuilt T38 Turbo with left handed shaft NOW SOLD
- Cosie engines and parts
- Two 10" spal fans
- dark greens
- ebony black 4x4 breaking(pics added)
- turbo
- Cossie 4x4 engine + more added
- Cosworth Distributor - NEW
- 2wd magnex VGC *** £100 ***
- coil per plug (for aftermarket management)
- few cosworth parts
- 2 COSSIE PARTS FOR SALE
- GpA mag coilovers
- A few parts for sale
- brand new 3 door shell (sold)
- Brand New 4x4 Cossie Samco Boost Hoses (T3)
- 2wd Cossie short engine
- OMP alloy strutbrace
- Gr.A water pump Cosworth Sapphire Escort
- P8 ECU
- loads of cossie parts on the bay
- B+M for Escort Cosworth(pics added)
- 2WD Mongoose System
- 2WD AP RACING 4 POT 330MM BRAKES SOLD
- standard 2wd cams, Brand new 2wd discs, tappets and misc
- Cosworth Motorsport Leads
- 2wd hi spec 330mm big disc conversion (sold)
- New Distributors for TRS Harnesses
- parts to sale
- water testing ????
- Brand new set of greens (803) + used 3 bar
- few cossie parts on ebay
- cosworth parts
- 3.9 front and rear matching diffs 4wd
- Hoses, header tank, intercooler
- Genuine valve stem oil seals
- bayjoo spec leda springs 2wd cosworth front and rear
- cosworth 2wd engine gearbox ecu= loom
- escort cosworth dump valve
- new carbon/kevlar sapp front bumper
- Sold! Cheers
- A few bits
- Breaking 2wd Saff...''All parts now sold''
- 4x4 driveshaft
- Spax Adjustables + springs for 4x4 cosworth
- Cosworth workshop manual Vol 1 and 2
- 2wd koni adjustables (sold)
- FEW ESCORT BITS...
- Sierra Cosworth 4x4 Low Comp +0.5mm Pistons
- 2wd diff, crank pulley and sump
- Level 8 ECU with Pectel board
- MINT RS 3 and 4 Spoke Steering Wheels...
- sierra cossie bits for sale
- ORIGINAL AIR INJECTORS FOR SALE
- genuine rs 500 8 injector manifold for sale
- February Oil Offers
- ESCORT COSWORTH PARTS...
- Cos parts on ebay last twelve hours
- cosworth last few bits prices have now been dropped
- 200 block and crank
- 4 spoke wheel
- Azev A wheels brand new tyres
- NO LONGER AVAILABLE
- GRP A COIL BACK FOR SALE *cosworth*
- Escort Cos Intercooler/Charge Cooler (With seperate pump)
- 400+ BHP Harvey Gibbs Engine... £3500 ono... Price Drop...
- fiesta mk3 rwd shell
- T34 ish Garrett Turbo , New !!
- 4wd cossie head
- 1 HOUR TO GO! *T38 Turbo and 'Swedish style' Plenum*
- Level 8 ECU
- sold
- cossie parts
- escort/sierra t34 hybrid turbo.and maifold**sold**
- 2wd engine, £800
- Cossy bottom end + trim........... updated
- sierra cosworth 4x4 MT75 gearbox SOLD
- sold
- Last part for sale!
- ***********SOLD**************
- pace rs500 cooler
- L6 ECU with Stg3 chip £100
- Cosworth Bottom Pulley
- cossie bits
- Seat and Harness
- Power Engineering Stg 3 Chip for 4x4 Cosworths
- Cosworth Parts
- cosworth dash, and slightly dented vented bonnet
- Escort Cosworth Front 4x4 diff
- brand new light blues ......OFFERS
- Saph Cossie 4x4 parts ## UPDATED 25/03/07##
- L6 ECU and Collins Board
- Small turbo cam/plug cover cosworth badges
- T4 as new
- Quaife thich wall front diff
- Leda 3 way adjustable coilovers *ammended price*
- SOLD * mods please delete. *
- * BRAND NEW S/S COSWORTH BATTERY COVER & SURROUND. *
- Eletric sunroof motor, switch and cover
- cossie full engine loom 4wd (NOW £70)
- 2WD Cossie shell
- 2WD 4.1 Rear Diff Crown Wheel & pinion
- saph cossie front fogs
- SECS S8 Ecu
- selling my Knob (as in gear)
- 3 door side mouldings for sale
- **** Just in for breaking 1 owner Saopphire Cossie*****
- hi spec rear disc conversion now on ebay
- Cossie 4x4 Polished Intercooler cover
- Set of 4wd Cossie Blue Samcos in good condition
- Cossie 2wd magnex
- ESCORT COSWORTH VIRGIN 200BLOCK/ MORE CLEAROUT BARGAINS!!!
- cossie bits garage clear out
- 2 Cossie 4x4 samco boost hoses in black
- Sierra Cosworht 4x4 Magnex SS exhaust system
- steering wheel 3 spoke
- wastegate forge 24 28 psi
- last of my cosworth parts - must go
- COSWORTH PARTS......
- misc cosworth stuff
- how much do these cossie parts go for
- std 4wd injectors and boost hoses
- ESCORT COZ- ENGINE UNDERTRAY,BOOT CARPET,WHEEL+JACK COVER
- Brand new rs 500 white dials £20 delivered
- L6 superchips stg1 chipped ecu for spares or repair
- 3door spares more added!!
- Various cossy bits
- Full set of BRAND NEW Roose Motorsport hoses
- SOLD !
- Proalloy 500 Cooler for sale AND Genuine Behr 500 cooler
- 2wd Blue Samco Boost Hoses and RamAir Induction Filter...
- Sapphire Cosworth 4x4 Chip *STAGE 3 !!!* and NEW polybushes
- 4x4 COSWORTH GEARBOX
- hi spec monster rear brakes *****now on ebay*****
- Escos wheels
- Brand New Escort Cosworth Turbo NOT RECON - BRAND NEW
- Cosworth stage 4 conversion Kit (T4, intercooler, Greys etc)
- Just in for Breaking 4WD Cossie
- New MT75 third gear and some used sm. turbo Escos parts
- cosworth adjustable verniers for sale
- 2wd cossie 4 pot calipers
- Cossie parts clearout
- Brand new set of conrods genuine Ford/Cosworth
- bosch green 440cc injectors
- L8 ECU with a proper Pectel Board - PROV SOLD !
- turbo, spoiler, interior
- sierra sapphire boot & spoiler
- genuine 2wd balck dash
- PLEASE DELETE WHEN YOU HAVE THE TIME
- clifford alarm intellistart
- Mocal boost oil temp and oil pressure Gauges
- bd10 cams
- Cossie leather Trims
- Piper Cam Verniers
- 4x4 front and rear disks and front callipers
- Standard 4x4 Intercooler
- Sapphire Cosworth 4x4 Engine
- sapp cosworth parts
- saph rear spoiler / front bumper / side skirts / debagedgril
- brand new bilstein suspention saph cosworth custom paint
- Ahmed Bayjoo Stage 3 Chip for 2wd L6 ECU
- Brand New 4x4 TPS
- SAFF COSSIE INTERIOR. SOLD !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- cosworth parts greens turbo manifold plate rims.
- ESCORT COSWORTH BUMPER PARTS
- Bosch 003 Escort Cosworth Fuel Pump + Fitting Kit....
- couple of 4wd bits
- Ford racing oil pressure gauge
- Breaking Granada Cosworth
- Dump Valve
- Cossie bits for sale
- T34 0.48 TURBO T TECHNICS sold
- Cosworth 2wd Diff
