- Carbon effect battery box
- fuel stytem, cell, lines, aeroquip
- sold
- Omp dished, suede steering wheel
- WANTED MK1 Focus RS bare shell
- 3 door parts
- 2wd mongoose exhaust £200
- Big spec Cosworth tall engine, 10 long studs, oil jets... £6500
- SOLD thanks
- 2wd diff done 35k miles
- Sierra RS500 (3Dr) Lightpod with lamps
- 2wd koni 's bayjoo springs excellent condition £250
- gates cambelt and ina tensioner SOLD
- Couple of sierra 3 spoke steering wheels
- Bosch 803 greens
- Granada Cosworth 24v v6 Engine
- sold please delete
- rs500/3 door/2wd steering uj new old stock SOLD
- 20% Off All Turbosmart Products
- Turbosmart Blow off
- Sold
- please delete
- Complete twin fuelpump setup + swirlpot + aeroquip lines + Aeromotive FPR
- cossie parts clearout-some hard to come by parts
- couple of small 3dr cossie parts forsale
- COSWORTH parts clear out lots
- Torques fuel system fittings and fuel rail
- 2 WD Suspension shocks + springs
- L6 Cosworth sierra
- saph cos bits n bobs
- genuine webber marelli 3 bar map sensor£100
- Sierra Cosworth T5 gearbox damaged
- Escort Cosworth leather doorcard sections
- For sale ford sierra heater unit
- cosworth hydraulic clutch conversion
- MSD closed loop L8 chip(55lb) cosworth
- Saph Clear out
- WRC turbo, manifold EGR
- Small Turbo Ecsort Cosworth Coils Brand New
- Cosworth Dash Monitor
- Turbo damper
- F16 COS (JET COS) Personalised Plate SOLD
- a few Original ESCOS bits for sale
- Standard airbox and big itg cone filter
- T38 turbo as new condition.
- Siemens 83lb injectors brand new
- L6 ecu and 803 injectors
- sierra 4x4 cosworth rolling shell
- Breaking a good 4x4 Moonstone Saph PRICE DROP
- Mountune Roller Barrel Inlet
- sold thanks
- Set of 6 Escort Cosworth metal rear door card clips
- Cosworth parts for sale
- Greys / 500 cooler / turbo cooler 2wd
- nla
- manual sun roof wanted
- parts for sale
- Reyland Cosworth rear 330mm brake conversion kit
- Cosworth cam cover
- Cosworth Conrods
- For Sale New & used Escos parts **CLEAROUT**
- few bits for sale including saph original air box,
- L8 ecu from a rs500 with wasted spark complete kit and 8 green injectors
- Sierra escort cosworth 4wd sump for sale
- cosworth ybt engine for sale
- skyline cosworth gearbox
- Stage 3 Package On L6 ECU
- T 5 gearbox £650
- Selling all my Rouse Sport bits, again! For good.
- Sierra Sapphire Raven Leather...
- Sierra head light wipers, and a couple of other bits
- RS500 brand new front bumper , genuine ford item
- Garage clear-out Cosworth
- 362x32 mm 4x4 cosworth brake set up
- Rear anti roll bar & drop links 4x4 Cosworth
- MT-Motorsport Cosworth 2wd 362x32mm Front Brake Conversion
- T3 turbo upgrade kit
- all sold
- Brand new compbrake tcas and compression struts
- 4x4 cosworth rebuild front and rear diffs 3.9 £400 the pair
- New Garrett t04e
- Ohlins shocks picture added
- Nortech twin scroll manifold
- cosworth mk2 package
- airtec alloy rad and twin fans/325mm rear brakes
- Rs 500 turbo damper
- WANTED T5 reverse fork
- RS500 head T61 Turbo/4-1 manifold/waste gate. Dyno proven 650bhp
- Various Rear Diffs for sale
- 300mm rear brake kit..
- saff 4x4 Tarox 6 pots and 330mm discs
- dark greens
- mk1 sierra cosworth parts for sale
- Cam covers for sale from £115 to £145
- Cosworth parts for James - Blackduk69
- L6 ECU with stage one chip and Yellows
- Escort cosworth parts
- 356mm 8 pot brakes, 4x4 Cosworth
- Sparco 3" 4 point harness's
- 3 door sierra parts & roll over spit
- Sierra cosworth 4x4 front and rear discs
- Sold please delete.
- 4 Spoke RS Steering Wheel
- Arrow Crank
- Sold Pending collection.
- Compression struts and top feed intercooler
- Borg Warner T5 gearbox
- autometer boost gauge
- L6 ecu with stage 1 chip..
- 7.5" rear diff
- Cosworth 4x4 koni's & l8 ecu
- Mk yb cam pulleys
- Rs Cosworth 4wd sump
- 20% Off Everything for the rest of 2014
- Updated 24/12/14 -RS500/3dr/ and Cosworth Rare spares, DVDs, books and models
- Escort / 4X4 Cosworth Bits - Updated with new bits 29/12/2014
- MT-Motorsport 4x4 330x28mm Front Brake Kit Conversion
- Cosworth parts some new some used! More parts added 4/1/15 as I'm finding them
- Black samcos, cone filter..
- Fuel pump looms group A cosworth
- YB short motor/bottom end
- sold
- Inconel turbo/trouser/downpipe bolts
- Cosworth steering wheel
- Green injectors..
- MT-Motorsport Cosworth 4x4 362x32mm Front Brake Conversion
- MT-Motorsport 2wd 330x28mm Front Brake Kit Conversion
- Cosworth parts
- Full sapphire cosworth leather interior
- Wasted spark leads little use £55 posted.
- escos and saff 4wd front calipers
- Sapphire carbon wing mirror coversSOLD
- L6 working ecu
- oz split rims 4dr/500
- 4x4 antiroll bar/poly bushes front Group a driveshafts oil gauge
- 3 Door Recaros ***SOLD***
- 2wd inlet manifold, like new
- Black Weekend sale NOW ON
- Cosworth BOB Twin turbo setup
- Gt3071, swedish plenum, greys, l8 etc
- Garrett T4 for sale
- S/S Heat Shield for air filter sold
- Ex Harvey Gibbs Rally Engine for Sale
- Aston martin 360mm brake kit
- Rose jointed track control arms and compression struts
- nla back on car
- Sapphire cosworth various parts...
- BOSCH 403 grey injectors nearly new
- BOSCH 403 Dark grey injectors nearly new
- Fully Rebuilt T34 Turbo By CR Turbos
- BOSCH 044
- WRC Breather, billet diff mount, ign amp bracket and bits and bobs
- sold ,please delete
- 4x4 AP 6 pots (CP5555) & 355 disks
- Comp mo6 18x8 et40 all new yoko all round
- Complete 2wd 362mm front brake kit
- cr turbo t38
- group a headgasket
- escort cosworth shell
- Rebuilt t3 turbo
- Rebuilt t34 turbo .63 housing
- Free cossie bits to collector
- Cosworth Parts
- 55lb siemen injectors
- Sold
- GT30
- Cosworth parts
- t5 cosworth sold
- rs bits
- A few parts(more parts )
- 2WD Cosworth Engine
- 3dr front fog lamps
- 4wd bottom pulley
- Set 4x4 rods n pistons
- L6 ecu
- some 3 door cossie lock parts/microswitches etc
- T34.63 turbo
- Cosworth rear 300mm brake kit SOLD
- some used cossie parts for sale-some new
- NEW Msd Group A coil re wire loom
- 2wd set up front and rear subframes
- escort cosworth morette head lights
- cosworth? dateless reg
- New saff rear mud flaps, Collins actuator, powder coated inlet
- cosworth parts
- WANTED cosworth yb cylinder head 2wd or 4x4
- 2wd 6 pot aps 362mm discs
- Cosworth radiator for sale
- MK2 Cossie conversion/cosworth parts
- Sold
- 2wd cosworth diff for sale
- hi spec monster 4 pots 335mm
- For Sale -31 Actuator
- 3 bar map sensor throttle body pf09 tps
- FOR SALE polished bailey turbo hanger
- Weber Marelli L8 ECU for sale
- cosworth bailey motorsport power steering tank
- Complete Pectel ECU setup + Raychem loom + ignition
- Genuine RS500/3dr Cibie Headlights
- cosworth clutch master cylinder and bracket
- Spec-r polished turbo heat shield SOLD
- parts for sale
- Various upgrade parts
- Aeroquip fittings
- Brand new Siemens 83lbs and weber ECU plug.
- cosworth engine
- 8 inj manifold
- Exhaust Manifold Nut & Washer Kits - Aerotight Nuts
- MSD chip L8 ECU stage 1 closed loop !
- 3dr cosworth parts forsale (prices dropped)
- Cosworth under bonnet alloy parts + more
- Cosworth rocker cover
- Complete GT30 turbo / manifold / hoses setup
- cosworth p8 management and loom
- Defi 60mm Boost Gauge & Controller - 5 Bar Map Sensor FOR SALE
- cosworth parts
- Escort cosworth leather interior
- Clear out of RS500, 3dr and other assorted cosworth parts/models with pics
- escort cosworth hex seats
- coilpack/rocker cover
- Cosworth engine parts
- £250 Price drop - sierra 2wd bilstein B6 shocks with Eibach Springs
- Weber Marelli vel 8 L8 ECU
- Cosworth Engine Parts
- Cosworth 6 Degree Beams & Suspension Parts
- Cosworth Rear Brake Kits
- NEW Escos Carbon Fibre Front splitter,spoiler,Hockey sticks
- Turbo isolation Jacket
- Cosworth 4x4 vibratechnic mounts
- Supra diff
- Cosworth stainless exhaust system
- Cod worth stainless exhaust system
- Cosworth 3 bar map sensor
- 2wd Gaz Gold front Coilovers £250 delivered
- New green injectors, 3 bar, idle control et
- T35 . 63 turbo
- Brand new 2wd cam belt cover £??
- fuel pump
- frontdiff strengthening plate
- Grp N strut top mounts and painted engine arms.
- Powder coated crossmember and ARB
- Sierra Cosworth Skuttle RS500
- Bosch injectors 650cc new,Low Impedance!
- Hi Spec 6 pot Calipers need these gone open to offers
- num plate on retention ready to go
