- 3DR PARTS
- Standard Cossie fuel pump
- Cossie Bits n Bobs ... ebay
- 2wd/4x4/escos various bits *UPDATED*7/11/08
- Breaking club/gpa sapphire
- K&n Apollo Induction Kit
- -12 fittings
- 2WD BOX
- Escos window regulator
- Kelvar bonnet for sapphire
- 4x4 throttle position sensor
- autometer phantom boost gauge
- sold
- ggr dump valve
- Custom Pro Alloy breather tank.
- cosworth 2 bar map sensor
- sold
- dark Greens for sale (cheap)
- Volt Guage /carbon Holder
- brand new 3dr headlight lenses
- brand new t38 turbo
- PF01s & PF09s, 3 bar Map Sensor, 4x4 Modine
- Aeroquip fittings
- Saph Cosworth Front Splitter
- Spec-r header tank
- Cosworth Parts, samco, 330bhp chip, mongoose
- FS: Grey Injectors & TT T38
- pro alloy rs500 intercooler (saff fitment)
- bannana pod ending soon on ebay
- Cosworths 2wd 4x4 Escort Sapphire Parts
- Cosworth parts UPDATED
- Lots of stuff on ebay Loads ending tonight!
- 3dr interior complete
- sold
- 909 carbon ISS tank and alloy slanted rad
- Couple of 4x4 saph bits for sale
- ALS stuff T34 .55 Maram. Mountune valve and throttle body
- 2wd Alternator
- finishing on the bay tonight
- T34.55 Excellent Condition
- inlet manifold to head spacer
- brand new t38 for sale
- Cosworth Parts, Greys, Bumpers, Skirts...REDUCED MUST GO
- Escos Ap 4 Pots - 335mm Discs -£700
- few new parts few second hand
- Brand New 4 Point Harnesses
- GGR Cosworth Vernier Camshaft Pulleys
- T4 turbo on ebay finishing tonight
- last day to get universal turbos T38 off ebay
- Escos quarter panel, wing (near side)
- brand new Escos fuel rail & pipes
- Standard Escos Rear Light VGC
- bd 10 2wd cams + solid lifters
- LHD 4x4 Sapphire Cosworth *Breaking for spares* NOW WITH PRICES...
- cosworth exhausts
- 3 Spoke RS Steering Wheel...
- Loads of Good Cosworth Parts
- Secs S8 Ecu
- cossie 2wd head, 205 bare block, 2wd crank
- load of goodies
- SOLD
- Genuine RS500 Intercooler & Hoses
- 2wd cossie bits
- Mint Saph 2wd Cloth Trim
- Brand new T35 turbo oil drain pipe
- Spec R Washer Bottle
- Spec R Pas Tank And Cap
- Spec R Headertank
- ahmed bajoo springs , other bits
- STU chip T38 Siemens BD14
- Flint saff grille
- Forge Breather Powdercoated Black with Filter
- Good 2wd Cossie Head
- ECU's, KONI's, LOOM, CHIP etc
- level 8 ecu
- rs 4 spoke stearing wheel
- std 2.5 bar escort cosworth map senser, chip for stg3 level 8
- Brand new 4x4 thermostat housing
- Nomad Rear Lights & BNIB Cossie Coin Tray
- New DB Tester Cost ideal for Track Day Goers
- Good Spec Sapph Breaking, parts ready to go
- Bosch 803 dark green injectors
- 4x4 Rear Calipers
- std saff fuel pump
- Vibratechnics 4x4 engine mounts, leccy sunroof
- 2wd plenum cover
- MSD L8/T3/Greens chip
- Quick Sale Needed for New Cossie Engine seen a car
- stage 3 bits
- sold
- Pair of Sparco 3 Point Harnesses
- Cosworth parts.
- few cosworth bits
- quads for sale
- Breaking My 3dr
- Aeroquip fittings
- Escort Cos Powerflex Front Outer Bushes
- Nurburgring Spec Avo Coilovers Going Cheep
- GT 35
- escort cossie parts lots of take a look
- Turbo Technics T38 600 miles old
- Carbon, Bling and others for sale
- MSD chip with antilag/launch/wasted spark/closed loop
- Breaking saph 4x4 cos
- Escort cosworth magnex exhaust
- 4x4 fuel rail + other bits
- WRC replica front wings
- mullit big tooth straight cut 4x4 gearbox £3250!
- Garage defender, 4 Spoke steering Wheel, Disklok
- 4 new grey bosch injectors
- saphire leather
- Ahmed Bayjoo - SCS Chip to run greys, ***SOLD***
- Momo Gearknob
- Sierra Cosworth Rear Smoked Lights
- amhed bajoo chip and red dot pads cossy
- Breaking 4x4 Saph Cosworth
- Pectel T6m
- 4 pot ap brake kit 2wd cossie
- 2wd standard diff
- various alloy tanks and DV etc
- Full set of 2wd deflex polybushes
- Cossie parts clearance
- BIG COSSY Number Plate
- Cosworth parts new prices + pics
- Cosworth Bling Header Tank,swirl Pot Ect
- t5 box
- Pistons, WRC Headgasket, ARP Rod Bolts
- Seimens 83lb (Black) Injectors x 4 and a Bosch 044 Fuel Pump
- EScort Cos Hex Seats
- YB CPS and Phase sensor
- Cossie 2wd Diff
- AP 4 Pots- 2WD Saph
- Sold.
- Universal turbos T38 and an rs500 spec garrett T4
- Brand New Alloy Crank Pulley
- Stack Sequential shift light
- SOLD please delete me!
- MSD Coilpack Conversion Kit & Loom (Brand New)
- COSSWORTH and FORD BOOK
- 5 Cosworth Special Magazines
- uprated transmission parts
- Stage 3 parts/ hoses
- alloy header tank for 2wd sapph Sold
- cossie engine parts **more added, can take to ford fair**
- **** cheap parts going on ebay ****
- breaking my 2wd saff
- Long 4x4 front driveshafts from xr4x4 for lowered cossie
- autronic smc
- 2wd Cosworth stage 3 kit
- sierra tinted rear lights and surround
- 2wd beam, arm and bearing carriers
- 3DR BITS
- 4 x 4 saff parts
- ecos front spoiler and hockey sticks
- polished half rollcage for saff...
- 3door hubs...
- Badge layout for tailgate
- Alloy brake bells for AP Disks 330's & 380's
- Various ECUs for sale
- vernier pulleys, spec r cam cover, few other escos parts
- Cosworth Bling
- turbo not shore what
- Q-TEC electric exhaust valve *VID INSIDE*
- 2wd Cosworth T5 box & diff..
- bannana pod gauges escos
- YB Crank Position Sensor done 5K £15 delivered
- AP Racing from + rear brake kits
- 2WD Head
- Rs500 Number Plate
- esc cos parts
- T34. 63 3000 miles old
- Track Day Fire Extingisher, Decibel Tester
- 4x4 AVO 25mm lowering springs for sale
- Cosworth parts *MORE ADDED 18-05*
- 4x4 cosworth gearbox
- New Crank Position Sensor YB
- Blue SECS Monitor only 8 months old
- 200 block & Big valve head..
- anyone got a cheap dump valve for 4x4 cossie sapph ???
- Looking for Escort Cosworth rear ARB
- Graham Goode Boost Hose For T4 Turbo To Air Filter
- Spec R Cosworth Cambelt Cover For Sale
- Ramair Cosworth Small Breather Filter For Sale
- Jr Cosworth Group A Blue Cone Filter & Trumpet For Sale
- Blue Cosworth Rocker Cover For Sale
- Cosworth Rebuilt Engine
- Various escort parts/ models
- could some help me out with prices
- composite inlet manifold spacers
- Carbon Heatshield, 4x4 front hubs
- Sapphire Cosworth Various Interior Trim Bits
- Brand new Escort Cosworth heatshield *sold*
- roose silicone hoses
- forge alloy strut brace
- Escos/sapp 4x4 Powerflex Cradle Mounting Kit
- Escort Cosworth Caged Shell New price idea !!
- Car Braking after Ford Fair or Before depending on uptake
- Siemens 72lb 750 cc injectors
- Siemens 55 Injectors Blacks 587cc
- Breaking k reg nouvo red 4x4 saph *few more parts now*
- Cosworth Smoked Side Repeaters For Sale
- 3 Dr Indicators Lenses Amber And Clear For Sale
- Cosworth Swirl Pot And Hoses For Sale
- sold please delete.
- Cossie Parts Brand New Verniers, Diff, alloy Pulley
- 205 engine cosworth
- Loads of Cosworth Stuff on Ebay
- Innovate XD-16 AFR Gauge Kit
- AP 6 paddle Clutch KIT & 4x4 flywheel done 1500miles (SOLD)
- 4 x 4 magenta bonnet
- pair of saff electric mirrors moonstone
- 2wd stainless exhausts x2
- Rs500 Inlet Manifold Fuel Rails & Throttle Body
- Standard Escort Cosworth Exhaust
- RS500 intercooler - modified for GT30/35 turbo
- 4x4 cossie
- escort cosworth poly bushes full set BRAND NEW
- rs500 inlet, p8, t4 turbo, 500 cooler.
- k&n filter
- 355 brake kit
- bailey dump valve £20
- Some cossie bits **and more**
- escort cosworth mk4 escort 4x4 list and prices
- Massive Cossie interior plastics ect clear out
- Leda Adjustable coilovers 2wd
- 2wd magenta doors
- 2wd reconditoned passenger side rear caliper
- Escort Cos Engine
- Maram shaft T34 .63 sold
- Momo Corse steering wheel & snap off boss kit
- escos wheels
- bailey breather
- AP 4 paddle "SOLD"
- ABS unit & tank
- 92 spec sapphire cossie cloth trim
- esc cos 5 stud hubs
- Escos front spoiler and 'sticks
- Black SFS silicone 2wd Cosworth hoses + samco + K&N
- 1994 Escort Cosworth Leather Trim
- Few parts, central day delivered Sunday
- sapphire cossie 4x4 original blue injectors and map sensor for sale
- Koni suspension kits
- 500bhp MAD Engine 1500 light road miles
- saff full leather trim
- 300mm rear big disc conversion with calipers
- escort cosworth genuine ford brand new rear spoiler
- Cossy Bling parts for sale(Inc refurbed cam cover)
