PDA
View Full Version : Ford RS Cosworth Parts for Sale
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54
  1. Imperial blue escort cosworth morettes
  2. Deleted
  3. SIERRA COSWORTH 4X4 LEVEL 8 ECU's X3
  4. Sierra cosworth 3dr back seat £150
  5. SOLD!!!!!!!!!!!! Sierra cosworth comps 7.5 x 17 MO5
  6. .63 exhaust housing
  7. 3" Scorpion back box. Saph Cosworth
  8. T34 turbo as new
  9. Iecs monitor
  10. Sierra sapphire x race shell for sale open to px's
  11. Rs 500 block
  12. MK motorsport 6 degree beam
  13. Stage 3 Cossie Set Up
  14. MT75 4x4 Bara straightcut gearbox
  15. What's it worth 200 block damaged
  16. Siemens 55lb injectors
  17. Cosworth s/steel bits,mo5 compomotives,strut brace.etc
  18. Holley HP-125 Low Pressure / High Flow - Ultimate Fuel System Lift Pump
  19. Brand New In The Box - Weber / Magneti Marelli 3 Bar MAP Sensor ASP05
  20. Full car set of original 3dr/RS500 black plastic side strips - used
  21. job lot of cosworth engine parts. Pictures added £2250 if gone this weekend
  22. Cosworth engine, needs assembly
  23. Cosworth yb 205 complete bottom end SOLD!!
  24. Sierra cosworth stage 3 set ups
  25. Bucket seats
  26. 378mm ap water cooled 6pots complete kit! SOLD!!!!
  27. cossie 4x4 exhaust cam
  28. RS 500 Block
  29. Cosworth parts
  30. King racing standard size bearings
  31. Flocked sapphire dash, small turbo plenum, bayonet oil cap
  32. cosworth parts
  33. Escort cosworth 4x4 cams
  34. 55lb Siemens injectors
  35. New Auto Specialist manifold
  36. Brand new 3dr cosworth rear light lenses for sale
  37. P8 ecu
  38. Escort Cosworth. Morette headlights
  39. Escort Cosworth leather seats
  40. Brand new Hi Spec Monster 4 calipers
  41. Custom side exit exhaust group a style
  42. Genuine NOS O/S Front Wing For Escort Cosworth
  43. Upgrade Package
  44. Fresh YB motor
  45. T5 Gearbox
  46. escort cosworth debadged fiberglass grill
  47. 3door mouldings
  48. L8 P8 sequential ignition, coil on plug
  49. C18SEE Private Plate For sale
  50. spare wheels bolts and jack cover screw
  51. Wanted! Your faulty Cosworth ECU's
  52. Wanted 4X4 exhaust cam
  53. TRS 3" harness' and Wheels.... Prices dropped again!
  54. Saff Cosworth parts including Ebony black shell.
  55. T34 turbo
  56. Bailey 2wd/3dr cossie header tank
  57. Cosworth rear dust Shields, Shark tooth caps and more
  58. Borg Warner 300sx Turbo
  59. Escort cosworth clocks instrument cluster
  60. L6 super 8 and L8 super 8 ecu's
  61. BIG WING sump mk2 escort cosworth/ 2wd cambelt cover
  62. Cosworth parts clear out
  63. cosworth / rally parts for sale
  64. Escort cosworth abs pump
  65. Escort cosworth clock
  66. Escort cosworth wiring loom
  67. Escort cosworth banana gauge pod
  68. intercooler mk2 escort YB
  69. Cosworth 2wd Engine
  70. RS500 splitter /intercooler deflector
  71. 3dr/rs500 parts interior trim/ intercooler GEN500/ Engine
  72. Power engineering stage 1 chip £30
  73. Poly bushes
  74. Cosworth parts for sale
  75. GTK550 Turbonetics turbo
  76. 83 & 72 lb siemens injectors
  77. 4x4 fuel rail reg and lines
  78. 2wd koni's and avo! springs
  79. 4x4 scorpion exhaust 4" tailpipe
  80. Standard bore, virgin 200 Cosworth YBJ bare block
  81. Twin air injectors
  82. RS500/3dr Cosworth Dash
  83. Big turbo escort cossie Airbox
  84. 2x 83lb Siemens injectors
  85. Garrett GT30.71 turbo with cosworth style exhaust flange
  86. Mk1 3dr Cosworth parts - genuine kit, bumpers, 24v BOA engine
  87. 3dr 1984 A Reg Mk1 Ford Sierra 1.6L Base Model - £1700
  88. Sierra fuel pump cradle
  89. Wanted or Swaps: Cosworth Engine Dress Kit
  90. Nos 80s-90s ford nuts bolts screws and clips escort,sierra,fiesta, rs models UPDATED!
  91. 5 Speed Sequential Gearbox
  92. Airtec 50mm rad
  93. L8 green label ecu
  94. P8 ecu set with wasted spark & 83lb's
  95. Mitsubishi TD04 turbo.
  96. Garrett T3 .42/.48A/R turbo..
  97. Genuine Garrett GT3076r - £300
  98. Escort Cosworth WRC/Group A Roof Vent - NEW
  99. Cosworth Saffire Recaros
  100. 803 green injectors mint
  101. sierra parts
  102. SOLD PLEASE DELETE T4 turbo with 360' bearing
  103. New sapphire drivers side wiper motor
  104. 4x4 intercooler
  105. WRC pattern YB engine mounts
  106. Cosworth H14 front anti roll bar
  107. Cosworth Compression Struts
  108. Cosworth YB engine NOW SOLD
  109. Full breather system, avo coilovers & std intercooler
  110. Sierra cosworth 2wd shell
  111. 4x4 sump with speedo maybe for sale
  112. 2wd cosworth parts and wheels added
  113. Safety Devices Half Roll Cage for Sierra £170
  114. Escort Group A/WRC/F2/Maxi Carbon Fibre Door Mirror
  115. Msd wiring kits + other parts
  116. Cosworth stenless steel water pipe as new
  117. Airtec 50mm black turbo cooler
  118. Airtec 50mm radiator in black with fan switch
  119. Compomotive centre caps set of 4 (blue) mint
  120. Cosworth and mk1 escort parts clear out
  121. Brand new Ford Escort Cosworth /4x4 Sapph Front ARB Washers and cups
  122. Sierra Cosworth XR4i MK1 dashboard good condition
  123. Ford Escort RS Cosworth Centre Console Ashtray gearing/rear section
  124. Ford Escort RS Cosworth Small Turbo Full set of 3 genuine airbox/breather hoses
  125. 2wd sapphire springs
  126. Borgwarner twinscroll turbo
  127. Ggr 4x4 silicone boost hoses
  128. Airtec black series sapphire rs500 intercooler
  129. 4x4 t3 uprated turbo
  130. Escort cosworth front inner wheel arch liners
  131. Rouse sport boot spoiler
  132. 1991 4x4x sierra sapphire cosworth poss breaking
  133. SOLD!!!!! Sierra sapphire rear arch liners
  134. SOLD!!!!!!! Rs500 original airbox
  135. Set of 4 mo5 comps 7.5"x 17
  136. Brand new genuine ford 7.5 cwp
  137. Now sold.........Cosworth oil catch alloy tank as pictured for sale
  138. 3dr cosworth parts for sale
  139. Cosworth alloy swirl pot mint,for sale
  140. Cosworth s/steel turbo damper with all fittings for sale
  141. Cosworth alloy power steering tank for sale
  142. Cosworth 2wd koni suspension
  143. Mega clearout
  144. 4x4 straight cut bara gearbox.
  145. Cosworth Escos RS200 technical books / vids / RS500 sales brochure and model
  146. 4x4 t34 turbo & single air injector
  147. Genuine rs500 airbox complete VALUE PLEASE
  148. Some parts
  149. RS500 / 3dr Cosworth mint rear trailing arms with proper spherical bearings fitted
  150. RS500 style, original Ford rubber lower rear spoiler
  151. AIM MXL Strada digital dash - Brand new - sold please delete
  152. P8 wasted spark board
  153. Cosworth heat Shields for.starter ,and alternator
  154. Now sold..........Cosworth spec R full oil breather set up rare complete.
  155. Ford Sierra 5 spoke alloy wheel +tyre new,new,,,,,alloy
  156. Cosworth bits,,pf09 black and red working 100%
  157. Some Cosworth bits for sale
  158. Cosworth Parts
  159. Rs500, sapphire cosworth rs ecu cover,for sale mint.
  160. Light blue injectors 0 280 150 400
  161. New 5th gears T5 2wd Cosworth
  162. Cosworth parts clear out... updated
  163. Now sold......Set of 4 light blues. With chip for L8 cosworth etc
  164. cosworth fan loom
  165. Virtually new RS500 YBD and 200 YBJ 200 Block - Ideal for Big horsepower builds
  166. Gtx3076r
  167. Race line rl7s
  168. Saff dark grey recaro seats
  169. RS500 / 3dr / 2wd /4x4 loads of rare spares and odds and ends
  170. AP CP4556 Calipers and 295mm discs
  171. Cosworth 2WD 300mm brakes and hubs for softlines
  172. 205 bottom end in bits
  173. Brembo four pot brake kit with brackets and focus 324mm discs new
  174. 4 x BOSCH 65LB 65 LB 650CC 680CC FUEL INJECTORS 0280150845
  175. set of 7 1/2 x17 comp mo5 ....sold,,,,,
  176. rs cosworth 500 bumper reduced to....... £1650......
  177. cosworth parts for sale
  178. m.a.d engine SOLD
  179. Sold
  180. 3 door /rs 500 parts switches & relays(Offers)
  181. 205 YB engine, stripped and ready for assembly
  182. Various cosworth parts for sale
  183. 3door dash value?
  184. Cosworth parts - Siemens 83 lb injectors / Cam caps etc..
  185. 4x4 ESCORT RS COSWORTH FRONT ANTI ROLL BAR
  186. 2WD Cosworth T5 Gearbox
  187. 4x4 Mahle Pistons
  188. Borg Warner turbo
  189. Escort Cosworth & Mk5 Parts
  190. Escort RS Cosworth parts
  191. white stack 52mm boost and water temp gauge
  192. Wanted V band adaptor
  193. 4x4 Cosworth Gearbox
  194. New TT T38 With Billet Comp Wheel
  195. escort cosworth debaged grill
  196. original 2wd fuel pump cradle and intercooler for sale
  197. Escort cosworth replica parts
  198. Escort cosworth wing vents
  199. Escort cosworth fog lights
  200. es cos parts
  201. Sold
  202. T5 Burton Power Quickshift
  203. ZF 7.5 Rear Diff Cosworth 2wd
  204. 7.5 2wd quaife rear diff
  205. kent ab07 inlet cam
  206. Thread closed,all items sold.
  207. Wanted
  208. 2wd cosworth short shift kit
  209. Corbeau Revenge GT Width Brand New
  210. Quaife Gripper GT Diff Casing
  211. 2wd prop
  212. Saff n/s front jacking point cover wanted
  213. 4x4 subframe wanted
  214. Extremely mint rwd focus cosworth shell
  215. Cosworth bits and bobs
  216. Wanted 3 door, door strips (protectors )
  217. new fuel pump cradle cosworth or rs500 for sale
  218. Forge Motorsport Piston Dump Valve for sale
  219. bosch light blue injectors and chip for sale
  220. Avo coilovers 4x4 - pretty much brand new
  221. sierra cosworth parts, some brand new (more parts added)
  222. 2wd callipers,brackets and disc
  223. Sierra cosworth dash towel
  224. what they worth
  225. Swanky Hydraulic handbrake set up
  226. F16 COS number plate
  227. "wanted" big tooth gearbox 4x4 MT75
  228. T5 gearbox, Std/Std crank, 200 block, big wing sump
  229. Wanted 4" Mongoose/Scorpion tailpipe 4x4 Saph
  230. 2WD front suspension/brakes AP, Bilstiens
  231. Gaz gold spec coilovers
  232. Cosworth clear out.. Braided lines, solid mounts, strut brace, coilpack etc etc.
  233. **awesome spec focus cosworth breaking** new list!!
  234. T34.48,55lb Siemens,bd10 cam,4x4 inlet
  235. Escos 330 Brakes
  236. T34.5
  237. 2wd Auto specialist header tank/alloy pas tank
  238. 2wd head
  239. Spec R oil filler cap,spec r turbo damper 3dr arch, sapph rear door cards
  240. cosworth samco hose
  241. Brand new scroth harness's
  242. Sierra sapphire cosworth front seats
  243. 2wd exhaust manifold and ext gate.
  244. Brand new Tial 44mm external wastegate.
  245. Wanted 17Inch alloy wheel.
  246. Saff Cosworth front bumper stone deflector
  247. Escort Cosworth parts some Motorsport.
  248. P8 wasted spark board with chip
  249. Brand new AS/hart plenum.
  250. Cossy 2WD Gaz coilover kit and more
