- rs focus discs
- WRC spec engine, never used.
- Cossie crank
- Cossie bits 'SALE'
- t35 nearly new with pics
- 2wd cos breaking
- A few Cossie parts for sale, with pics! OFFERS, Cheap!
- TCA with poly 2wd pinch type
- GT3582R
- 2WD Brembo Callipers & 325mm Discs ***SOLD***
- 2wd rear beam/diff/shafts
- 2wd Cossie new rear discs,T3 turbo.
- Rear Diff On Fleabay
- Escort cosworth Brakes
- complete mega BHP ECU/inlet set-up
- ford racing puma seats
- GRP-A thermostat housing
- RS500 grills freepost
- ****SOLD*****
- WRC style Hydraulic Handbrake
- 4x4 GEARBOX
- 2WD BIG WING SUMP
- cossie bits clearout must go!!!!
- 4x4 Saff Cossie - INLET CAMSHAFT - For Sale
- P8 ecu and other parts
- More Cosworth Parts on Ebay ** 28.05.07 **
- bailey header tank (black) ford 6000 cd player
- Jumble sale.... 56k beware!
- STANDARD 4X4 COSSY CAT AND EXHAUST SYSTEM
- sharktooth alloys WITH tyres in excellent condition
- grp-a rear beam with mag arms and y links and hubs
- Spa Digital Dual Gauges - pics now added
- grpa square beam and bilstein coilovers *pics added*
- SOLD T4 Turbo, 360 bearing etc etc SOLD
- few interesting bits
- 3dr Cosworth interior parts - with pics
- SOLD
- Brand new boxed 4x4 thermostat housing/ST escos cam cover
- SOLD
- K&N filter, and Power steering tank.
- Gauge, Oil Temp. Reduced price
- Pirrelli p700 z tyre
- Will Swap My Scorpion With Centre Box Removed..
- 3 Bar Map Sensor....*PROV SOLD*
- Tca rubbers. New!!! SOLD SOLD SOLD. PLS LOCK.
- Escort Cosworth Leather Trim
- 2wd Genuine Cosworth Oil Pump.
- Few parts on Ebay
- cosworth engine loom and fuel rail
- l1 ecu with chip
- greens and spec r turbo damper and saf 170mph clocks
- P8 ECU + T35 .63 TURBO ***PICS***
- sold
- R & D Six Speed Dog Box
- Cosworth L1 ECU
- 4x4 Sapphire Cosworth *BREAKING* MORE PARTS ADDED...
- Cossie bits for sale
- R+D plated diff / 6 pot AP's / 9 inch rear diff
- 2wd Cos Engine. 360 BHP SOLD
- Brembo four pots...(PICS)
- 3 door cossie 500 grills and smked indicators SOLD
- Huge cosworth GpA K&N
- Cobra springs - Escort Coss
- 3Dr Cosworth Rear Bumper
- Sierra 3 door tailgate (no rust)
- 2wd parts clearout- quickshift- dampers- springs
- Escort Cosworth Grey Hex Cloth Recaro interior
- 3 door upper dash
- apexi avc-r NEW!!!!!
- lumenition AFR 10 led
- [sold]blue motorsports leads for cossie 4*4
- breaking my 3 door loads for sale.sorry no longer for sale
- 88 2wd saff lower dash
- Air injectors plus greys
- Alloy power steering bracket
- ESCORT COSWORTH PARTS NEW IN BOXS
- Leather rear bench seat...
- escort/4x4 bits for sale
- L8 and L1 ECU's and Chips, Samcos, Springs and Dumpvalve
- 2 x 2wd cosworth gearboxs for sale.
- sold.
- P8 with stage 1 chip
- Roose Boost hose NEW with DV Fitting
- cos garage clearout
- Refurbed 4X4 cosworth gearbox
- Escort Cossy intank Fuel Pump
- Brand NEW 4wd Flywheel and stage 3 chip
- Spec R Cossie rear strut brace
- escort cosworth gearbox and air con bits
- 2wd L6 stage 2 kit
- Defi gauges bf series - sold pending payment.
- full size escos 18" SUPER T with tyre - SOLD
- SOLD SOLD SOLD
- set of sapphire door mouldings SOLD
- 2wd crank pulley SOLD
- 3dr cossy rear wheel arch sound proofing
- BARGAIN L8 Greentop ECU
- Siemens injectors 55lbph 560cc "Blacks"
- 2 wheel drive head
- saf outer door rubbers what they worth
- Alloy Parts updated and leather trims
- 2wd Cossie coil over kit SOLD
- 2wd cossie 4pot callipers
- Stage 3 Parts
- breaking escort cosworth :(
- 2wd 4pots, discs, throttle elbow, exhaust manifold
- koni adjustable. SOLD SOLD PLS LOCK!!!!!!!!!!!!!!!!!!!!!!!!!
- Good Condition Bailey DV24 Dump Valve - £35 POSTED! SOLD
- black crackle rocker cover - SOLD!
- *** Escort Cosworth Parts For Sale ***
- Lambda Nut/Boss for lambda/flamer sensor fitted
- Hubcentric Spacers - As New
- Few Cossie Parts- Sierra Cos ES Cos
- Brand new complete cosworth engine ready for 450 bhp (sold)
- T35 turbo SOLD
- Escort Cosworth parts WITH PICS
- 2wd Sapph / 3 door scorpion 3" stainless exhaust - 4&qu
- Fiberglass Splitter and hockey sticks for sale (esc cos)
- Light blues injectors (400`s) and fitting kit on ebay
- Boost gauge
- 2wd cosworth manifold
- cossie 4x4 rear calipers
- Re Furbished Cossie Cam Covers with pics
- Cheap AP calipers with pic
- Imperial Blue Escort Cosworth Rolling Shell **NOW SOLD**
- 99% Brand new T34 and a few other bits and bobs- new prices
- cosworth dark green injectors £100
- 2wd Cossie 4 pots pics added
- Escort Cossie silicon water hoses
- 2wd BD10 inlet cam
- Coil Over Suspension
- R&D 6 speed dog box with pic
- Pair of 4x4 Diffs 3.9's
- Escort Cosworth Rear Diff
- T34/0.48 (fully rebuilt and un-run!)
- Dark green 803 injectors x4
- Original Ford green brake pipe
- 500 bumper/spoiler
- A few 4x4 cossie parts
- Burton low comp pistons low miles SOLD
- how much is a cosworth diff mount worth ??
- Lumenition AFR
- Nice set of Oz mags
- Cosworth L8 ECU, 4x4 Gearbox, Scorpion + More *PICS ADDED*
- Esc Cos/4x4 Parts (High Performance)... Pics Added 02-06-07
- non sunroof roof lining for 3dr
- cosworth 4x4 t3 Turbo for sale
- Cosworth 4x4 front diff *can take to Central Day*
- Sapphire Cossie Shell To Clear best offer before i scrap it
- Massive Trim Clearence
- Sierra Cosworth power steering tank / Scorpion down pipe
- bosch lambda sensor for closed loop CHEAP
- Amazing spec Escos Breaking!
- Mongoose back box and mongoose front pipe
- OMP alloy strutbrace
- cosworth group a 4x4 gearbox
- 4x4 LEVEL 8 PECTEL ECU, SOLD..SOLD..SOLD...SOLD
- Escort Cossie Leather trim
- Escort Cossie Stainless System
- sold
- P8 Ecu with a GGR chip and Pectel board
- cossie bits for sale!
- 2WD willwood brake kit 325mm PICS ADDED!!!!!!!
- GT40 Turbo
- Wanted Aftermarket Rev Gauge
- STACK 0-4 BAR BOOST GAUGE (brand new)
- l8 MSD EVO Chip with closed loop
- few saff coz bits left, need these gone asap
- Dashboard Protecting Towel, Ford Logo etc
- 4x4 cosworth front calipers
- Lots of new Cosworth items... wasted spark drivers etc etc.
- Cosworth clearout - Need the space
- 3dr/RS500 Professional Acoustic Parcel Shelf
- 3 door tinted rear lights and few saph bits
- delete please
- autometer phantom gauges
- SOLD
- INTERCOOLER AND SPRINGS
- collins 4x4 engine mounts - new
- New genuine RS500 intercooler/radiator lower cover
- Cosworth Coil and chrome...
- 2WD Brembo Disc's
- Stack Dash - SOLD
- Saff morrette's
- PF01 TPS as new SOLD !!!!!
- Bumper heat sheild
- Cosworth parts Garage clearance UPDATED
- breaking white saff updated 03/05 SOLD SOLD SOLD SOLD
- Cosworth Number Plate for sale
- charge cooler, 4x4 samcos, tricky 4x4 box wanted!
- SOLD
- Crank main shells
- cosworth 4x4 brakes, gearbox + saph moretts, sfs hoses
- Sold
- SOLD * mods please delete. *
- 3 door glass and 4x4 saff beama
- a few 4x4 cosworth bits
- pro alloy header, fuel pump
- 4x4 ARB POLY BUSHES (in Black)
- few cozzy bits left
- rs500 ecu green injectors
- breaking my own group A escort cosworth.
- 2wd Magnex Exhaust (rare twin pipe system)*NEW PICS****
- Cosworth engine bits
- 2wd cossie parts, Boost hoses, air filter, clocks *pics*
- 4x4 Cossie front brakes
- 3door + 2wd parts lots of shiny bits
- Cosworth Owners workshop Manual - Photocopy
- scorpian exhaust system 4 inch tail pipe 2wd cosworth
- 4wd koni adjustables with springs now with pic
- 3dr Cossy original gear nob - with pics
- ECOS Ramair panel Filter
- Sapphire cosworth bodykit and interior
- Escort cosworth alloy rad SOLD
- rs500 intercooler 2wd SOLD
- bailey dump valve
- New 3dr tailgate - SOLD
- SAFF.....K&N panel filter
- NEW PF09 THROTTLE POSITION SENSOR
- Ahmed Bayjoo spring on ebay!!! End in 1/2 hr grab a bargain!
- cosworth 4x4 driveshaft
- 3 door front window trims
- Closed Loop Bosch Lambda sensor NEW
- 4x4 front transfer box/differential
- Escort Cosworth brochure and Monte Carlo Window sticker.....
- Lots of 2wd parts BRAND NEW **LOADS MORE PARTS ADDED**
- 2WD ENGINE (Block and Head) new lower price!!
- Escort Cosworth Parcel Shelf
- Cossie engines
- Cosworth Dash Boards
- few cossie bits for sale...more to come
- New unsed 4x4 adjustable TCAs PROV. SOLD
- Brand New set of cosworth conrods
- Sierra Cosworth Silicone Hoses
- Sapphire Cossie shell
- Cossie baily oil breather
- BRAND NEW BD10 INLET CAM 2WD
- std front shocks and springs
- saff cos rad and fans
- saff cosworth leather door cards
- Bosch 803 green injectors
- Escort Cosworth Cambelt Cover
- SOLD
- Carbon Mirrors
- Cosworth bottom end
- Sue Collins baby board & chip + M/Sport Light Blue Injec
- Cossie Samcos and filter
- saff leather + door cards(MUST GO)
- Bailey DV24 Dump Valve £35 posted MUST GO!
- Blue Forge Dump Valve cheap
