- Sabelt 3inch Harness X2
- Various cossie bits
- pro alloy oil breather and fitting kit, new !!!
- 17¨ BBS Centrelock Wheels - SOLD
- escort cosworth wheels brand new
- 2wd Bottom End. SOLD
- Big Brakes front and rear, Coilovers, 044, steering wheel...
- Wanted: YB metal 'dohc 16v turbo etc' rocker cover badge
- sold.
- RS Cosworth metal Turbo water pipes
- trim,4wd gearbox £150 !! open to offers on the rest
- Cosworth bits n n pieces
- 4x4 Airbox
- Cosworth polished and ported head. pics added.
- cosworth parts .......
- Pro Alloy Racing Fuel Tank! Brand New!!! PT800!! Reduced!!!
- 3dr Interior Door Cards - NOW WITH PICTURES
- Licence PLate for sale Cheap needs to be asigned before 6th!
- T34 BLING Actuator Bracket ** SOLD **
- Cosworth parts...
- Saph twin bar alloy polished front strut brace......
- Escort mrk5 Momo steering wheel SOLD SOLD SOLD
- N800 COS Registration For Sale - Ford Fair Special - Offers over £200
- 3 door Rollcage
- Twin Cossie 2wd cooler with spacer bracket
- Grp A Coil & Ign Leads.
- msd chip, p8 ALS greys coilpack
- brand new t25 esc cos boost hoses x3
- Escos Banana pod - for 3 gauges!!
- Escos Red and Clear Rear Lights.
- few cossie bits
- COSSIE BITS 500 BHP TURBOSYSTEMS ENGINE!!! PLUS LOADS MORE!!
- box of cosworth bits offers on individual or all
- brand new saph cossie fog lamps in box x2 sold
- SOLD
- 4x4 cts quaife gearbox as new. all new parts.
- Maram shafted T35 with .63 housing **SOLD**
- Bling Bling bits for sale - Boost Hoses now £80
- leada -ahmed bayjoo springs . SOLD
- 3 bar map sensor
- SOLD
- sparco buckets and harnesses now on e blag
- 4x4 saph cossie heatshield
- SOLD
- mint .48 ex housing..
- Samco t3 boost pipe
- 3dr Parts - Must Go - No Sensible offer refused
- 3 door Cossie leather trim with pics
- Some stuff sold, some just in the way, prices updated....
- Brand new AP clutch plate
- Freshly Painted YB Rocker Cover (Green)
- GpA coil with flamer kit works really good - £50
- SOLD
- 4wd gearbox and prop doughnut
- Defi Guages
- 2wd cossie gaz coilovers.new
- Cosworth 3 Layer Cometic Head Gasket **SOLD**
- 4x4 front calipers +disk
- ***Sapphire Cossie shell and Compomotive MOs on EBay ***
- radtec 60mm cooler esc cos
- 200 4x4 block, Long Studded
- SOLD
- 2wd hispec 330 brakes
- Full cage for Saph
- Professionally refurbed std 2wd 4 pot front calipers.(Pics)
- Brand New Escort Cosworth Gearknob SOLD SOLD SOLD
- Few Spec R and other 'bling' bits
- 4x4 Inlet Manifold & Throttle Body
- b&m quickshift SOLD
- cosworth hoses 4x4 saff - *ebay last few hours BARGAIN*
- Bosch 803 Greens
- Sapphire/3 door roll cage SOLD
- Cossie Amal Valve + Phase Sensor
- AVO Coilovers for sale
- GT30.76R
- dump valve - £25 posted
- free bits!
- Roose Silicone Turbo Hose !! SOLD SOLD SOLD
- 2wd steering rack and front subframe
- 2wd cosworth bonnet bootlid and headlights.
- Sold
- 4X4 SAPPHIRE DRIVESHAFT
- Saph cossie clocks !! SOLD SOLD SOLD
- few bits for sale
- 2 Saph Cosworth Front inner C.V Boots !! SOLD SOLD SOLD
- SOLD
- 4wd Cossie head SOLD
- Cossie T5 dog box SOLD
- Magenta saff doors gotts go now!!!
- Cosworth Stainless Exhausts
- Pair of sparco buckets and harnesses
- 2wd quick shift
- sold
- 4 spoke rs steering wheels
- CTS 4wd dog box quaife on ebay
- Escort Cossy Parts (Cam Cover & Turbo Heatsheild)
- Sierra 3 door cosworth intercooler & air direction plate
- Ford Sierra Sapphire plastic headlight guards
- escort morettes
- 406BHP Harvey Gibbs Engine inc new t34 turbo & inlet
- rs 500 plenum complete.used
- 2wd Cossie track car in for breaking
- SOLD
- BLING alternator Brkt on EBAY with link & pics
- grpA k&n filter
- T5 2wd cosworth gearbox
- MSD Stage 3 setup (closed loop lambda) 3 Bar & 4x803's
- Cosworth Parts *** SOLD ***
- 3dr Seats & Doors Cards
- TCA RUBBERS. BRAND NEW. 4x4 saff, escos.
- modified steering wheel cowling to fit extra guages (SOLD)
- 3 bar map sensor
- -34 actuator £45 = SOLD
- sapphire cos rear arms
- Sold!
- cosworth parts for sale *updated*
- suspension parts
- cossie bits
- Siemens 55lbph Fuel injectors (Black) Cosworth Upgrade.
- fuel sender escort cos
- A few cosworth bits, intercoolers, chip, injectors, turbo
- a few Escort Cosworth parts
- Brembo 4 pots
- Magenta 2wd saff breaking (not mine!!)
- timing belt cover and a swedish inlet
- ends in two hours, its a bargain
- -10 goodrich
- 2wd rear beam
- 6 paddle clutch kit SOLD
- ****Genuine RS 500 engine**** NOW SOLD
- 4wd cossie bits
- 200 block SOLD
- Set of yellows £20
- T3 turbo (needs rebuild)
- BD10 Inlet cam with Vernier Pully
- DEFI BOOST GAUGE
- Pro Alloy Fuel Tank! (E Bay)
- oe turbo damper
- brand new Bosch 403 (greys) injectors (Inc fitting kit) £200
- Few white Sapphire bits left...
- Pro alloy RS500 cooler...
- Fully Rebuilt 200 block and 4x4 B.V.H...
- <<<FINALLY BREAKING BIG SPEC SAPH>>>
- 17"x8" hockenheims
- pace products intercooler mint condition
- Clearance time
- Genuine Ford RS500 Splitter
- Cosworth Parts
- 2wd quaife diff
- Hybrid T34 just in
- 2wd calipers good and cheap......
- set of 403 greys
- Alcon 6 paddle Clutch kit on ebay DIRT CHEAP!!!!!!!!!!
- 2wd Cosworth Parts For Sale Updated List 21/10 & Prices!
- Cossie 2wd big winged sumps
- FOCUS RS BLUEFLAME / MONGOOSE
- NEW Saph Cossie parts.....offers please!
- L8 cossie collins stage 1 chip and board
- 2wd Cosworth brakes ( refurbed calipers and new discs )
- Collins -31 Actuator
- Collins -31 polished alloy actuator for sale
- Cheapo 4x4 cossy alloy rad for sale!
- Cosworth 2wd flywheel
- Grey cosworth injectors 403's...Offers
- My stainless timing belt cover!! 7 hours to go only £10
- brand new 215 45 17 pirelli p zero 1 hour to go! cheap!
- Luke 4 point 2" harness's
- SOLD - Cossie Braided Wiring Loom (By Ryan)
- P8 ECU with Anti Lag and Coilpack
- Pro alloy fuel tank
- black "RS" ECU dash cover
- Pair of imperial blue Escos doors
- PACE Products (Turbo Cooler Radiator) Provisionally Sold
- Set of Greys, BD 15 & standard cam
- Brand new 2wd Samco hoses full engine set
- escos car cover ** sold **
- genuine Escos bonnet vents ** SOLD **
- 200 Block bottem end
- 2WD Vibra-Technics GEARBOX MOUNT - Now available
- wasted spark coil pack motorsport leads and cam cover
- a few parts not needed.
- Sierra Saphire Cosworth Roof Skin
- YB & Cossie Parts......LOADS...All must go soon
- Braided hose
- Chrome Battery cover and Coil Cover
- Ford Racing Volt Gauge
- AVO rear shocks and springs
- Cosworth Cam Cover
- 4x4 Intercooler
- COSWORTH ITEMS.......EBAY 22 hours left!!!!!!!!!!
- mk1 sierra cosworth bonnet now with pics
- 1 Cam Cover
- Escort Cossie Turbo Heatsheild
- turbo
- Couple Cossie Parts
- P8 ECU and full engine wiring loom PRICE DROPPED
- 4x4 bits & bobs
- ESCORT COSWORTH PASSENGER HEADLIGHT
- stage 3 chip mapped by a1 rallyesport
- 2x Defi Gauges for sale!
- Breaking 3dr Cosworth
- sold
- Rear Trailing arms 2wd Cosworth
- breaking 2wd sapph. most parts available!!
- Bosch 400 Light blue injectors x4
- escort cosworth bits
- EEC IV PLENUM COVER AND THROTTLE BODY.BD10 CAMS
- **** SOLD ****
- Freshly Rebuilt 4x4 Engine (200 block) SOLD
- gear stick for a 2wd
- sapphire cosworth side skirts
- momo wheel
- few Cosworth parts for sale
- 4x4 discs, callipers and pads will be at national day
- spec r power steering tank £40 still for sale.sold
- 2wd Scorpion Stainless Exhaust
- Bosch 803 dark greens as new +bayjoo 330 bhp chip and K&
- Various 2wd parts, ECUs, Stg3, leads, coils, coolers etc
- Breaking...White 2wd Sapphire Cosworth...
- 4x4 cosworth suspension
- Escort Cosworth P8 ecu 250£ or offers!
- SOLD
- Bosch 803 "Green" Injectors
- SOLD
- Cosworth parts - swirl pot, samco, bailey
- cos parts samco, bailey header tank etc
- New Collins pro ecu monitor
- Number plate for sale **** SOLD ****
- Cosworth Engine Parts
- 4+4 head
- *WANTED* 2wd saph throttle cable bracket (Now sorted )
- cosworth parts for sale-UPDATED WITH PICS
- 3 DOOR COSWORTH RECARO TRIM /EAGLE F1 TYRES
- Escos Small Turbo K&N large cone filter
- On car Adjustable TCA's 4x4 Cos Pinch Bolt Type
- sold
- Cosworth alloy union for rocker breather
- cosworth group A wheel studs and nuts
- SOLD
- Air Box
- header tank 4 sale
- 4 DUNLOP SLICK TYRES CHEAP!!!
- 2wd saff steering rack and pump + Stainless exhaust.
- 2wd saff Full light gray cloth interior + 4 Cryst blue doors
- 2wd BD10s
- P8 ecu for sale 250pounds posted!!
- Cossie rear Leda Race Suspension SOLD
- SOLD
- Sold
- 4wd uprated motorsport rear diff SOLD
