Adjustable tca,s ABS block, front diff, swirl pot.
Old 27-08-2016, 03:56 PM
Caddyshack
Caddyshack's Avatar
Default Adjustable tca,s ABS block, front diff, swirl pot.
I have had a bit of a clear out and have these bits for sale:
Inlet manifold off my 4x4 £40 posted SOLD
Front diff, done 32,000 miles. Came off my 4x4 all standard, I only took the cover off to look inside. No noises and was working fine, I just swapped it for a quaife one.
£65 plus £10 postage
4 (dark) green injectors, came off my 4x4 that was around 330bhp, removed by Mark Shead when he upgraded my engine. £50 posted SOLD
Swirl pot in ally, make not known, will polish up<br/>Well. It looks to have had one side cut down and a few marks but will clean up and works well. I bought it whilst waiting for my spec r one. £30 posted.
These would probably sand and polish out and are not seen when fitted
4x4 ABS block comes with the bits below in the pic, ECU, one or Two abs sensors, Ecu plug. £40 posted
Part number on block. I had this working on my car.
Ecu part numbers
Ecu plug
Air Fuel ratio, as you can see it has been used. The wires are there and some like live and neutral are obvious. The others I assume go to lambda. I am sure some googling will show the wire diagrams so I will try to find them. This was working in my car. £20 posted
Air fuel ratio wires
Pair of Cossie 4x4 adjustable Track Control Arms taken off my car, one of the boots has split but easy to get from a motor factors £35 posted.
I also have a Greddy boost controller and will put up a pic when I find the wires for it....no idea what that is worth?
Old 27-08-2016, 05:41 PM
timster
timster's Avatar
Injectors are 803's? If so I'll take them.
Old 27-08-2016, 05:59 PM
Caddyshack
Caddyshack's Avatar
I think someone has just pay palled me, sorry.
Old 27-08-2016, 06:07 PM
timster
timster's Avatar
No worries ☺
Old 27-08-2016, 09:28 PM
Ridgey
Ridgey's Avatar
The inlet manifold is a 2wd
Caddyshack (28-08-2016)
Old 28-08-2016, 10:14 AM
Caddyshack
Caddyshack's Avatar
Adjustable TCAs sold pending payment and I think I have someone on the diff and the A/fuel ratio meter.
ABS sensors sold but other ABS bits remain
Old 28-08-2016, 10:26 AM
Caddyshack
Caddyshack's Avatar
I just found the wiring instructions for the Lambda, the interested buyers inbox is now full though. Here is the wiring instruction link: http://autocar-electrical.co.uk/imag...nstruction.pdf
Old 28-08-2016, 11:08 AM
Caddyshack
Caddyshack's Avatar
Standard supra diff cover, has recently been painted. £40 posted
I gave the swirl pot a quick wipe over with auto sol
Cleans up ok, you could easily wet sand it for better results
Old 28-08-2016, 12:30 PM
bazza77
bazza77's Avatar
i will have the afr if still available please
Old 28-08-2016, 03:42 PM
Caddyshack
Caddyshack's Avatar
Pm sent
Old 28-08-2016, 03:45 PM
Caddyshack
Caddyshack's Avatar
I have just found my old NON adjustable track control arms, they are £15 posted if anyone wants them. I also have a 4x4 front anti roll bar, obviously quite heavy (no mounts or brackets though)
Old 28-08-2016, 04:57 PM
bazza77
bazza77's Avatar
just paid for afr bud
Old 28-08-2016, 07:53 PM
Ridgey
Ridgey's Avatar
I'll take the brake pressure reducing valve from the bottom of the abs block if you'll sell separate?
Cheers Ridgey
Old 28-08-2016, 08:49 PM
Caddyshack
Caddyshack's Avatar
Cheers Ridgey
Pm me your address and I will post it to you free of charge.
Old 28-08-2016, 08:59 PM
Ridgey
Ridgey's Avatar
PM'd you
M K (29-09-2016)
original
14
19-08-2016 11:40 PM
ricky
15-08-2016 12:29 PM
CrOwSoN15
08-07-2016 06:34 AM
Quick Reply: Adjustable tca,s ABS block, front diff, swirl pot.
