Cosworth Parts, Engine, Fuel System, Loom + More
Engine – Engine re-built by Piero at X-Power Engines. Headwas ported by Neil Roper and has all new bronze valve guides, 3 angle valveseats, new tappets, Newman double valve springs and a new standard exhaust cam andnew Turbosystems spec BD15+ inlet cam with Piper pulleys. Bottom end has new+.25 pistons with valve cut outs, all new standard size bearings and seals,lightened and balanced, big wing sump with group a baffle, WRC head gasket, ARPbig end bolts, con rod bolts & flywheels bolts and new high flow oil pump.Engine has 6 x WRC stud & nut kit and comes with a port matched trumpetsection with brand new hart style inlet, WRC breather with screw fittingswelded in sump, all new sensors, recondition hybrid T34 turbo on manifold withturbo oil filter and AP Racing extra heavy duty clutch. Also comes with fuelrail. Compression ratio is 8:1. This engine is newly built and never been run -£8000
Siemens 83lb injectors brand new - £350
Twin Pump system. 2xBosch 044’s, 2xfilters, earls braded lines& fittings all done less than 1000 miles. Brand new under car fuel swirlwhich cost £200 - £450 the lot.
Brand new Burton Power braided engine loom, still in thebox. These cost around £650 – want £450.
Brand new Philoy Strut Brace - £100
4x4 Gearbox, good condition - £400
Brand new adjustable lower arms, compression struts & Rose Joint Track arms -£350
Brand new Magnetti Marelli 3 Bar Map Sensor - £250
Brand New IECS ECU monitor mounted in banana gauges, comeswith vent panel with the switches fitted and an A/F meter fitted - £350
Compete Escort Cosworth Yellow Samco - £150
Almost Brand New Forge re-circ dump valve - £60
Brand New 4x4 Group N gated sump Baffle - £100
Used standard inlet & exhaust cams - £50
Brand new Escort Cosworth electric window switch panel - £60
Brand new brushed Cosworth boot badge - £50
Brand new front panel ford badge - £35
All prices plus postage plus paypal fees or welcome to comeand collect.
Photos and more parts to come…….
