PDA
View Full Version : Ford KA
  1. lost in confusion icv and maf
  2. Error codes
  3. Proxi Alignement?
  4. Water leak into boot on 2017 Ford KA+
  5. Ford Ka Kit Car
  6. Problems with my mirrors
  7. KA RU8 Titanium Heated Seats in a Studio spec
  8. Advice on P0030 diagnostic trouble code
  9. Ka issue
  10. Mk2 Air filter housing hose query
  11. 2014 KA outside temperature sensor inaccurate
  12. Water in the rear passenger foot well
  13. Ka rear trim removal
  14. Any tips for installing a streetka hardtop?
  15. Streetka and headlight swap
  16. Reverse light and lighter point problem
  17. 2006 mk1 ka cooling fan u/s
  18. Ford KA steering wheel swap
  19. engine advise needed..
  20. New installation of mk2 fog lights
  21. Ka zetec conversion
  22. Ford Ka mk2 radiator
  23. 07 Ka fuel filter on 1.3
  24. ka rev counter swap
  25. Need a bigger Ka :D
  26. Socket for OBD unit
  27. Problem with dash warning lights
  28. Curiosity about Ford Ka
  29. '07 ka rear brakes
  30. Alloy suggestions for my ka
  31. 05 KA, tail lights not working.
  32. Universal arches
  33. Sportka missfire when hot
  34. 1998 ka carpet and door card problems
  35. Phew! Hot Ka!
  36. MTX into Ka... what drive shafts to use?
  37. Gearbox end gasket
  38. How do I tell which model StreetKa mine is?
  39. Brake lights stopped working
  40. StreetKa wiring diagram
  41. Problem with Engine Management Light Ford Streetka
  42. 1998 1.3 Manual steering help needed
  43. valve settings for ford ka 1.3i 1999
  44. KA - Puma Engine Swap
  45. SPORTKA SE iDLE PROBLEMS HELP PLEASE!!!
  46. Ford KA 1.6 Se Sport
  47. Immobiliser Problem
  48. Help - P0138
  49. Help please!
  50. ABS !
  51. MPG.
  52. ka 2000 (x reg) power steering, help
  53. Coolant Drain and Flush?
  54. swapping roof on street ka??
  55. Ford Ka 2005 central Locking
  56. 2004 sportka abs and airbag lights
  57. ford ka heater valve
  58. Engine/exhaust issue.
  59. paint
  60. Ka Duratec engine...starter not turning??
  61. Streetka door handles broken - help!
  62. Ka steering
  63. Hi folks, please I need a help or advice
  64. Ford ka 1.3 throttle body
  65. Ford ka mk2 2009 water in passenger footwells
  66. streetka airbag code
  67. Streetka b2256 window heater short to ground
  68. ABS light and speedo stopped
  69. airbag light on solid on streetka
  70. 2003 Ford Ka
  71. Ford KA 2001 1.3, floppy brakes and clutch
  72. general sportka maintenance prices
  73. Ka Bodyshell
  74. 2009 KA - External Temperature Sensor.
  75. Ka Petrol filler
  76. Battery Drain
  77. SportKa Speedo, rev counter and trip problem
  78. LOST KEYS
  79. OBD P0118 engine temp High output
  80. My daily driver with rally style
  81. pu-ka budget trackcar project
  82. Engine Management Light struggles...
  83. diagnosis via OBD Scan advice
  84. HELP!!!
  85. Haynes Manual MK2
  86. water pump ka
  87. rocker cover gasket replacement sportka?
  88. Ka Sport loss of power?
  89. Immobiliser Problems
  90. Ka Power Steering Leak From Rack
  91. KA Driver's Door Adjustment?
  92. KA Central Locking Fault
  93. Bunny costume
  94. KA battery warning light /loss of performance
  95. Random alarm INSIDE my SportKa! What is it?!
  96. ka wont start
  97. Roof Trouble- 52 plate KA
  98. Issue with moving off. KA but need advice from anyone with experience.,
  99. help needed
  100. Wondering under acceleration
  101. indicators not working
  102. Ford ka engine swap to zetec help and advice needed
  103. Ford ka engines
  104. Niggles on a Sport Ka
  105. ka sport
  106. Newby with KA edge
  107. Some one please help ECU problem
  108. Ford ka ecu problems. Help Please
  109. Ka brake change Q
  110. Engine management light
  111. ka 2003 alternator change, help
  112. Ka brakes.. Advice needed!
  113. Ford KA power steering
  114. Ford Indy in Hemel Hempstead?
  115. Ford SportKa, opinions?
  116. Ka rs
  117. KA rear hub nut torque
  118. airbag ecu
  119. ford ka back lights problem
  120. Ford KA Power steering gone light? Advice needed!
  121. KA on Carbs
  122. misfire problem
  123. airbag light
  124. Ford Ka rally car build
  125. StreetKA Roof
  126. Couple of questions
  127. master cylinder pipes
  128. FAO Rich and your KA
  129. 2008 KA Zetec not starting
  130. Service Manual
  131. fault code p0138 on sportka
  132. Performance Parts
  133. New ford Ka
  134. Engine stopping when driving and now not starting anymore
  135. mpg display
  136. street KA n/s door wont open from out side
  137. Replacement seat lever
  138. Gearbox help
  139. Ka turbo
  140. Zetec Ka Project
  141. Cutting out when driving, alternator?
  142. sportka eml light on, help
  143. Over-revving problem
  144. Ka chassis repair opinions
  145. Clutch slipping problem??
  146. ST150 gearbox into ka ib5
  147. Sportka Rear Diffuser
  148. Oil!!!
  149. anyone changed a sportka fuel filter?
  150. ford ka colant/thermostat problem? help please
  151. ford ka coolant problem
  152. Resetting Ka Engine Warning Light
  153. Ka race car, which car and which engine?
  154. ka rst help needed
  155. help needed please
  156. DTC help
  157. swapping complete puma loom into a ka
  158. Ka indicator problem
  159. 2003 Ford Ka Duratec issue Help!!!
  160. Ford KA OBD Interface
  161. ka oil
  162. Remove 1998 MK I KA fuel flap.
  163. Engine question.
  164. my new ka! bye old blue
  165. silertop conversion
  166. Bucket Seats
  167. front and rear springs
  168. Which Ka engine, 60 or 70bhp?
  169. Ht Leads
  170. Ford ka
  171. Ford Ka repair
  172. Vibration since doing clutch
  173. sportka/ka heater control valve help
  174. what brake lines
  175. changing rocker cover gasket 1.3 duratec ka
  176. 1st Ka
  177. Rs 2000 mk6 recaros do they fit ?
  178. 55 ka sump removal.
  179. ka zetec wiring,
  180. just wondering..................
  181. Threads asking for Car Stereo codes are not allowed.
  182. engine light
  183. request
  184. 2003 onwards ka alternator help!!
  185. Ford Ka cold weather sounds: drivetrain
  186. 2004 1.6L Duratec engine swap
  187. 1.3 Turbo conversion
  188. Another turbo conversion plan
  189. Which radiator?
  190. ka mk2 factory bluetooth
  191. lambda sensor
  192. sport ka copyka
  193. Ford ka custom radiator
  194. 180/60/13 on a ka yes/no??
  195. Ford ka brake upgrade - pedal problem
  196. Ford ka RST conversion
  197. Ford Ka immobilsed
  198. Ford Ka Tuning Advice
