IF PASSIONFORD IS SLOW OR WON'T LOAD FOR YOU
MY BOY, this peace is what all true warriors strive for.
In Windows, do the following:
Start -> Run -> cmd
This will open a DOS box. Type the following:
tracert passionford.com
You'll get some results that look like this:
Right click the window, then choose Select All (it will turn white), then press Enter. This will copy the text to your clipboard.
Once you have this, post your results in this thread and we'll see what's going on.
If you are on MacOS or Linux, you can use the traceroute command - it will do the same thing.
Start -> Run -> cmd
Code:
14 149 ms 149 ms 149 ms 83.231.148.20 15 144 ms 145 ms 143 ms ge-9-2.the.uk.euroconnex.net [217.112.81.2] 16 145 ms 144 ms 145 ms 217.112.82.21 17 146 ms 140 ms 154 ms passionford.com [92.48.66.100]
Microsoft Windows [Version 6.0.6000]
Copyright (c) 2006 Microsoft Corporation. All rights reserved.
C:\Users\Ade>tracert passionford.com
Tracing route to passionford.com [92.48.66.100]
over a maximum of 30 hops:
1 1 ms 3 ms 1 ms . [192.168.2.1]
2 23 ms 24 ms 23 ms brnt-bam-3.inet.ntl.com [194.145.148.170]
3 26 ms 29 ms 34 ms brnt-t3core-1b-ge-112-0.inet.ntl.com [195.182.17
9.145]
4 24 ms 32 ms 30 ms bre-bb-b-as1-0.inet.ntl.com [213.105.174.249]
5 26 ms 24 ms 26 ms bre-bb-a-ge-000-0.inet.ntl.com [213.105.174.225]
6 26 ms 28 ms 27 ms 212.43.162.218
7 34 ms 33 ms 29 ms tele-ic-1-as0-0.inet.ntl.com [62.253.184.2]
8 31 ms 29 ms 32 ms 212.250.14.110
9 29 ms 30 ms 48 ms ge-5-2.the.uk.euroconnex.net [87.127.231.90]
10 31 ms 31 ms 31 ms 217.112.82.21
11 32 ms 36 ms 32 ms passionford.com [92.48.66.100]
Trace complete.
C:\Users\Ade>
9.145]
Trace complete.
C:\Users\Ade>
PassionFords Creator
1) Delete all internet cache.
2) Close all internet explorers.
3) turn Off PC.
4) Turn off ROUTER/MODEM
5) power it all back up.
Now i dont know why this is, but without step 4, mine was dog slow and kept freezing if i pressed reply etc. Was a real drain.
Point 4 alone fixed mine and a few others. Why? Clueless mate.
Lots of people were originally having these problems pal, cure for them all, including me was:
3) turn Off PC.
3) turn Off PC.
My ISP advised this to me ages ago, their explanation was that BT do repairs to the connections every so often so it alters your current connection. By turning off the router you will connect to a fresh connection that hasn't been messed with [yet]. I regularly turn off my router because of this and it's amazing just how much faster it is when you turn it back on.
Most likely there is a bad routing table entry somewhere. Not necessarily the ISP's fault, but their support department is a good place to start. The fact that resetting your router (& thus getting a new IP from them) fixes it does point at it being either within the ISP's network, or VERY close to it.
1 1 ms <1 ms <1 ms 192.168.0.1
2 39 ms 37 ms 37 ms rt-lostg01.dial.aol.com [195.93.23.193]
3 * 37 ms * iptfarmlg-los-sw0-V3.net.aol.com [195.93.17.2
4 37 ms 38 ms 38 ms accessl1-los-A6.net.aol.com [172.17.169.107]
5 38 ms 37 ms 39 ms accessl2-los-S1-2-0.net.aol.com [195.93.31.31
6 74 ms 38 ms 39 ms pop2-loh-S0-1-0.atdn.net [66.185.134.201]
7 38 ms 37 ms 38 ms ldn-b2-pos12-0.telia.net [213.248.75.69]
8 38 ms 38 ms 38 ms ldn-tch-i2-link.telia.net [80.91.250.214]
9 39 ms 38 ms 37 ms ldn-tch-i1-link.telia.net [80.91.250.217]
10 40 ms 39 ms 39 ms 83.231.148.20
11 38 ms 38 ms 38 ms ge-9-2.the.uk.euroconnex.net [217.112.81.2]
12 40 ms 40 ms 40 ms 217.112.82.21
13 40 ms 39 ms 39 ms passionford1.passionford.com [92.48.66.100]
Gotta love aol's american based proxies for ping!
1 <1 ms 1 ms <1 ms 192.168.2.1
2 87 ms 81 ms 226 ms lo98.gr-acc-bras-5.as9105.net [212.74.102.20]
3 112 ms 26 ms 27 ms 10.72.4.91
4 214 ms 148 ms 241 ms 10.72.4.188
5 214 ms 166 ms * xe-1-3-0.lon20.ip.tiscali.net [213.200.79.181]
6 163 ms 81 ms 116 ms ge-5-1-0.lon22.ip.tiscali.net [89.149.186.86]
7 173 ms 210 ms 284 ms 213.200.78.238
8 288 ms * 254 ms ldn-tch-i2-link.telia.net [80.91.250.214]
9 193 ms 257 ms 105 ms ldn-tch-i1-link.telia.net [80.91.250.217]
10 * * * Request timed out.
11 112 ms 150 ms 308 ms ge-9-2.the.uk.euroconnex.net [217.112.81.2]
12 62 ms 161 ms * 217.112.82.21
13 89 ms 76 ms 39 ms passionford1.passionford.com [92.48.66.100]
Trace complete.
C:\Users\Tony>
That took 4 attempts to post
Its currently pathetic and almost impossible to post on !!
Trace complete.
C:\Users\Tony>
And after a router re-boot..
1 <1 ms <1 ms <1 ms 192.168.2.1
2 27 ms 26 ms 26 ms lo98.gr-acc-bras-5.as9105.net [212.74.102.20]
3 25 ms 26 ms 26 ms 10.72.4.91
4 27 ms 27 ms 27 ms 10.72.4.188
5 27 ms 26 ms 27 ms xe-1-3-0.lon20.ip.tiscali.net [213.200.79.181]
6 25 ms 27 ms 27 ms ge-1-1-0.lon22.ip.tiscali.net [89.149.186.78]
7 27 ms 27 ms 27 ms 213.200.78.238
8 123 ms 29 ms 27 ms ldn-tch-i2-link.telia.net [80.91.250.214]
9 29 ms 27 ms 27 ms ldn-tch-i1-link.telia.net [80.91.250.217]
10 35 ms 39 ms 39 ms 83.231.148.20
11 * * * Request timed out.
12 38 ms 34 ms 36 ms 217.112.82.21
13 * * * Request timed out.
14 * * * Request timed out.
15 * * * Request timed out.
16 * * * Request timed out.
17 * * * Request timed out.
18 * * * Request timed out.
19 * * * Request timed out.
20 * * * Request timed out.
21 * * * Request timed out.
22 * * * Request timed out.
23 * * * Request timed out.
24 * * * Request timed out.
25 * * * Request timed out.
26 * * * Request timed out.
27 * * * Request timed out.
28 * * * Request timed out.
29 * * * Request timed out.
30 * * * Request timed out.
Trace complete.
C:\Users\Tony>
So I tried a different site which is fine..
Tracing route to bbc.com [212.58.251.202]
2 24 ms 26 ms 26 ms lo98.gr-acc-bras-5.as9105.net [212.74.102.20]
3 29 ms 27 ms 26 ms 10.72.4.91
4 29 ms 25 ms 27 ms 10.72.4.188
5 28 ms 27 ms 25 ms ge-5-1-0.lon22.ip.tiscali.net [213.200.77.177]
6 38 ms 26 ms 26 ms ge-7-1.core2.London1.Level3.net [213.200.77.130]
7 26 ms 27 ms 27 ms ae-21-56.car1.London1.Level3.net [4.68.116.175]
8 28 ms 26 ms 27 ms 195.50.118.242
9 42 ms 28 ms 27 ms 212.58.238.129
10 29 ms 26 ms 26 ms 212.58.239.58
11 28 ms 27 ms 26 ms www2.telhc.bbc.co.uk [212.58.251.202]
Trace complete.
C:\Users\Tony>
Trace complete.
C:\Users\Tony>
Trace complete.
C:\Users\Tony>
Microsoft Windows [Version 6.0.6000] Copyright (c) 2006 Microsoft Corporation.
All rights reserved. C:\Users\Bi>tracert passionford.com
Tracing route to passionford.com [92.48.66.100] over a maximum of 30 hops:
1 1 ms 1 ms 1 ms 192.168.1.1
3 31 ms 29 ms 29 ms lo98.sc-acc-bras-10.as9105.net [212.74.102.10]
4 29 ms 29 ms 29 ms 10.72.4.147
5 30 ms 30 ms 29 ms 10.72.4.126
6 31 ms 31 ms 29 ms ge-5-1-0.lon12.ip.tiscali.net [213.200.79.9]
7 31 ms 29 ms 29 ms so-3-1-0.lon22.ip.tiscali.net [213.200.80.30]
8 30 ms 31 ms 30 ms 213.200.78.238
9 136 ms 221 ms 211 ms ldn-tch-i2-link.telia.net [80.91.250.214]
10 32 ms 30 ms 30 ms ldn-tch-i1-link.telia.net [80.91.250.217]
11 44 ms 38 ms 39 ms 83.231.148.20
12 37 ms 57 ms 37 ms ge-9-2.the.uk.euroconnex.net [217.112.81.2]
13 41 ms 40 ms 42 ms 217.112.82.21
14 39 ms 42 ms 40 ms passionford1.passionford.com [92.48.66.100]
Trace complete.
Trace complete.
After a clean up and re boot.
1 2 ms 1 ms 2 ms 192.168.1.1
3 30 ms 29 ms 29 ms lo98.sc-acc-bras-10.as9105.net [212.74.102.10]
4 42 ms 52 ms 76 ms 10.72.4.147
5 29 ms 31 ms 30 ms 10.72.4.126
6 32 ms 34 ms 31 ms ge-4-0-0.lon11.ip.tiscali.net [213.200.77.73]
7 35 ms 30 ms 30 ms so-3-1-0.lon22.ip.tiscali.net [213.200.80.30]
8 32 ms 30 ms 30 ms 213.200.78.238
9 31 ms 30 ms 33 ms ldn-tch-i2-link.telia.net [80.91.250.214]
10 840 ms 30 ms 31 ms ldn-tch-i1-link.telia.net [80.91.250.217]
11 39 ms 39 ms 40 ms 83.231.148.20
12 38 ms 38 ms 37 ms ge-9-2.the.uk.euroconnex.net [217.112.81.2]
13 39 ms 40 ms 39 ms 217.112.82.21
14 41 ms 38 ms 38 ms passionford.com [92.48.66.100]
Trace complete.
Im going to so a full scan now to see if its something at my end.
Trace complete.
Comprehensive scan revealed nothing at all, and after another re boot.......
C:\Users\Bi> tracert passionford.com
1 2 ms 3 ms 1 ms 192.168.1.1
3 30 ms 30 ms 48 ms lo98.sc-acc-bras-10.as9105.net [212.74.102.10]
4 30 ms 35 ms 30 ms 10.72.4.147
5 30 ms 31 ms 29 ms 10.72.4.126
6 30 ms 52 ms 34 ms ge-4-0-0.lon11.ip.tiscali.net [213.200.77.73]
7 30 ms 31 ms 31 ms so-7-0-0.lon22.ip.tiscali.net [89.149.186.22]
8 65 ms 29 ms 30 ms 213.200.78.238
9 36 ms 49 ms 52 ms ldn-tch-i2-link.telia.net [80.91.250.214]
10 49 ms 53 ms 55 ms ldn-tch-i1-link.telia.net [80.91.250.217]
11 72 ms 62 ms 62 ms 83.231.148.20
12 63 ms 63 ms 63 ms ge-9-2.the.uk.euroconnex.net [217.112.81.2]
13 63 ms 64 ms 63 ms 217.112.82.21
14 64 ms 59 ms 63 ms passionford.com [92.48.66.100]
Trace complete.
It still times out and has to be refreshed every page I try to view. Im using Firefox browser, had not problems at all up to this past week. Its getting irritating already.
Trace complete.
Another re boot, different PC on same connection
C:\Users\Office>tracert passionford.com
2 145 ms 121 ms 42 ms lo98.gr-acc-bras-5.as9105.net [212.74.102.20]
3 * 166 ms 177 ms 10.72.4.91
4 51 ms 28 ms 69 ms 10.72.4.188
5 145 ms 104 ms * ge-5-1-0.lon22.ip.tiscali.net [213.200.77.177]
6 * 113 ms 103 ms ge-3-0-0.lon22.ip.tiscali.net [89.149.186.90]
7 45 ms 41 ms 34 ms 213.200.78.238
8 168 ms 161 ms 118 ms ldn-tch-i2-link.telia.net [80.91.250.214]
9 71 ms 100 ms 75 ms ldn-tch-i1-link.telia.net [80.91.250.217]
10 128 ms 44 ms 59 ms 83.231.148.20
12 35 ms 43 ms * 217.112.82.21
13 179 ms 58 ms 162 ms passionford1.passionford.com [92.48.66.100]
Trace complete.
C:\Users\Office>
Trace complete.
C:\Users\Office>
Ex Full Price gold member
Getting really bad for me now has been fine since the move just the last 4-5 days i'm getting nothing but internet explorer cant display web page etc as well..
C:\Users\Martin>tracert passionford.com
1 80 ms 60 ms 99 ms dsldevice.lan [192.168.1.254]
2 28 ms 27 ms 27 ms lo99.glo-3-dsl.as9105.net [212.74.111.243]
3 28 ms 28 ms 29 ms ge1-2-26.glo1.as9105.net [212.74.106.206]
4 31 ms 28 ms 28 ms pos2-0.glo0.as9105.net [212.74.108.166]
5 31 ms 29 ms 32 ms pos0-0.bri1.as9105.net [212.74.108.162]
6 33 ms 32 ms 33 ms ge0-0-0.he-lon0.as9105.net [212.74.109.14]
7 34 ms 35 ms 33 ms ge4-0-0.he-lon1.as9105.net [212.74.106.54]
8 34 ms 34 ms 35 ms ge-6-1-0.lon22.ip.tiscali.net [213.200.78.233]
9 32 ms 33 ms 34 ms ge-5-1-0.lon22.ip.tiscali.net [89.149.186.86]
10 33 ms 33 ms 33 ms 213.200.78.238
11 170 ms 202 ms 227 ms ldn-tch-i2-link.telia.net [80.91.250.214]
12 33 ms 34 ms 33 ms ldn-tch-i1-link.telia.net [80.91.250.217]
13 46 ms 50 ms 47 ms 83.231.148.20
15 41 ms 41 ms 41 ms 217.112.82.21
16 41 ms 43 ms 41 ms passionford1.passionford.com [92.48.66.100]
Trace complete.
Trace complete.
C:\Users\Ben>tracert passionford.com
1 1 ms 1 ms 1 ms . [192.168.2.1]
2 14 ms 14 ms 14 ms lo99.lon-1-dsl.as9105.net [212.74.111.225]
3 14 ms 16 ms 16 ms Gi1-0-4-28.lon11.as9105.net [212.74.106.154]
4 15 ms 15 ms 15 ms ge-5-0-0.lon12.ip.tiscali.net [213.200.78.117]
5 15 ms 15 ms 14 ms so-7-0-0.lon22.ip.tiscali.net [89.149.186.22]
6 16 ms 16 ms 15 ms 213.200.78.238
7 15 ms 14 ms 15 ms ldn-tch-i2-link.telia.net [80.91.250.214]
8 15 ms 15 ms 15 ms ldn-tch-i1-link.telia.net [80.91.250.217]
9 24 ms 28 ms 29 ms 83.231.148.20
10 21 ms 22 ms 23 ms ge-9-2.the.uk.euroconnex.net [217.112.81.2]
11 25 ms 23 ms 24 ms 217.112.82.21
12 23 ms 24 ms 23 ms passionford.com [92.48.66.100]
Trace complete.
C:\Users\Ben>
Trace complete.
C:\Users\Ben>
can you please Help my laptop is Brand new 2 days old and my internet connection is fine every other website is fine just this one give me problems not loading pages ect having to refresh just to get them top work
this has only been like this in the last 5 days i thought i had a virus on my old laptop but this is new so i dont know
Help!
Help!
Nuts and S2's traceroutes seem to reveal a common problem with the last hop between Verio (an Internet provider) and eUKhost (where PF lives.) I have opened a ticket with eUKhost to see if they can troubleshoot it.
BigErn, dunno what to tell you. The traceroute there looks fine. Ditto Gatecrasher.
ok i just tride to reply twice and got
The following errors occurred when this message was submitted:
and then i got
Internet Explorer cannot display the webpage
Most likely causes:
[IMG]res://ieframe.dll/bullet.png[/IMG] Diagnose Connection Problems
[IMG]res://ieframe.dll/up.png[/IMG] More information
This problem can be caused by a variety of issues, including:
You can still view subscribed feeds and some recently viewed webpages.
To view subscribed feeds
- The message you have entered is too short. Please lengthen your message to at least 1 characters.
and then i got
Most likely causes:
- Click the Favorites Center button [IMG]res://ieframe.dll/favcenter.png[/IMG], click Feeds, and then click the feed you want to view.
1 71 ms 99 ms 99 ms dsldevice.lan [192.168.1.254]
2 30 ms 27 ms 28 ms lo99.lon-z-ips.as9105.net [212.74.111.187]
3 144 ms 26 ms 25 ms ge1-0-7.lon11.as9105.net [80.40.119.162]
4 26 ms 26 ms 26 ms ge-7-1-0.lon11.ip.tiscali.net [213.200.77.49]
5 43 ms 27 ms 27 ms so-7-0-0.lon22.ip.tiscali.net [89.149.186.22]
6 27 ms 29 ms 26 ms 213.200.78.238
7 130 ms 206 ms 206 ms ldn-tch-i2-link.telia.net [80.91.250.214]
8 27 ms 31 ms 27 ms ldn-tch-i1-link.telia.net [80.91.250.217]
9 42 ms 39 ms 38 ms 83.231.148.20
10 34 ms 34 ms 43 ms ge-9-2.the.uk.euroconnex.net [217.112.81.2]
11 34 ms 34 ms 38 ms 217.112.82.21
12 44 ms 35 ms 34 ms passionford1.passionford.com [92.48.66.100]
Trace complete.
god that took some doing.really slow
Trace complete.
1 12 ms 99 ms 98 ms dsldevice.lan [192.168.1.254]
2 28 ms 27 ms 29 ms lo99.glo-3-dsl.as9105.net [212.74.111.243]
3 29 ms 27 ms 28 ms ge1-2-26.glo1.as9105.net [212.74.106.206]
4 29 ms 28 ms 28 ms pos2-0.glo0.as9105.net [212.74.108.166]
5 30 ms 29 ms 30 ms pos0-0.bri1.as9105.net [212.74.108.162]
6 33 ms 33 ms 34 ms ge0-0-0.he-lon0.as9105.net [212.74.109.14]
7 34 ms 33 ms 34 ms ge4-0-0.he-lon1.as9105.net [212.74.106.54]
8 33 ms 33 ms 33 ms ge-6-1-0.lon22.ip.tiscali.net [213.200.78.233]
9 34 ms 34 ms 33 ms ge-5-1-0.lon22.ip.tiscali.net [89.149.186.86]
10 34 ms 32 ms 32 ms 213.200.78.238
11 34 ms 35 ms 34 ms ldn-tch-i2-link.telia.net [80.91.250.214]
12 35 ms 34 ms 34 ms ldn-tch-i1-link.telia.net [80.91.250.217]
13 45 ms 49 ms 48 ms 83.231.148.20
15 40 ms 43 ms 43 ms 217.112.82.21
16 42 ms 43 ms 42 ms passionford1.passionford.com [92.48.66.100]
Trace complete.
I know you have reported it like you said but just keeping you updated..
Still the same for me i have to refresh any page i open on PF as i get "this page cannot be displayed" about 3-4 times before it loads..
Mart
My latest efforts
C:\Users\Tony>tracert passionford.com
2 143 ms 110 ms 28 ms lo98.gr-acc-bras-5.as9105.net [212.74.102.20]
3 * 195 ms 58 ms 10.72.4.91
4 104 ms 102 ms 26 ms 10.72.4.188
5 88 ms 235 ms 25 ms xe-2-2-0.lon20.ip.tiscali.net [213.200.79.185]
6 156 ms 26 ms 27 ms ge-5-1-0.lon22.ip.tiscali.net [89.149.186.86]
7 26 ms 26 ms 28 ms 213.200.78.238
8 29 ms 26 ms 26 ms ldn-tch-i2-link.telia.net [80.91.250.214]
9 118 ms 28 ms 32 ms ldn-tch-i1-link.telia.net [80.91.250.217]
10 47 ms 163 ms 39 ms 83.231.148.20
11 221 ms 196 ms * ge-9-2.the.uk.euroconnex.net [217.112.81.2]
12 * * * Request timed out.
Trace complete.
C:\Users\Tony>
Trace complete.
C:\Users\Tony>
I've forwarded this information both to eUKhost and to Euroconnex. So far eUKhost is denying that it couldn't possibly be on their end, even though the traceroutes make it blatantly obvious that it's either them or one of their network service providers. I'm still trying to talk some sense into them. Hopefully Euroconnex will listen to reason.
Verio and Euroconnex both have problems going through the one router (217.112.82.21) which shows as belonging to eUKhost... anyone with a rudimentary education in network engineering would be suspicious that the problem could be there. Hopefully I can talk one of eUKhost's support guys into forwarding the information to an actual network engineer.
Thanks for the update..
More TR's if required
2 106 ms 85 ms 26 ms lo98.gr-acc-bras-5.as9105.net [212.74.102.20]
3 53 ms * 86 ms 10.72.4.91
4 176 ms 198 ms 28 ms 10.72.4.188
5 106 ms * 157 ms ge-6-1-0.lon22.ip.tiscali.net [213.200.78.233]
6 102 ms 37 ms 27 ms ge-2-1-0.lon22.ip.tiscali.net [89.149.186.82]
7 210 ms 100 ms 30 ms 213.200.78.238
8 62 ms 61 ms 27 ms ldn-tch-i2-link.telia.net [80.91.250.214]
9 69 ms 69 ms 246 ms ldn-tch-i1-link.telia.net [80.91.250.217]
10 142 ms 59 ms 229 ms 83.231.148.20
11 139 ms * 189 ms ge-9-2.the.uk.euroconnex.net [217.112.81.2]
12 158 ms 120 ms * 217.112.82.21
13 75 ms 35 ms 171 ms passionford1.passionford.com [92.48.66.100]
Trace complete.
C:\Users\Tony>
Trace complete.
C:\Users\Tony>
Anyone who hasnt given details over here, please do so.
https://passionford.com/forum/general-car-related-discussion/230986-pf-performance-issues-please-help.html
1 2 ms 1 ms 1 ms 192.168.1.1
3 30 ms 29 ms 31 ms lo98.sc-acc-bras-10.as9105.net [212.74.102.10]
4 30 ms 30 ms 31 ms 10.72.4.147
5 30 ms 30 ms 30 ms 10.72.4.126
6 31 ms 31 ms 29 ms ge-5-0-0.lon12.ip.tiscali.net [213.200.78.117]
7 30 ms 29 ms 29 ms so-7-0-0.lon22.ip.tiscali.net [89.149.186.22]
9 31 ms 30 ms 30 ms ldn-tch-i2-link.telia.net [80.91.250.214]
10 31 ms 31 ms 31 ms ldn-tch-i1-link.telia.net [80.91.250.217]
12 77 ms 37 ms 77 ms ge-9-2.the.uk.euroconnex.net [217.112.81.2]
13 59 ms 38 ms 39 ms 217.112.82.21
14 39 ms 39 ms 38 ms passionford1.passionford.com [92.48.66.100]
Trace complete.
Took ages to do this trace.... PF is bein terrible now. It was intermittent but now its every post/page.
Trace complete.
Here's my result:
1 1 ms 1 ms 3 ms 192.168.1.1
2 27 ms 27 ms 27 ms lo98.gr-acc-bras-4.as9105.net [212.74.102.19]
3 28 ms 27 ms 26 ms 10.72.4.93
4 27 ms 27 ms 26 ms 10.72.4.124
5 27 ms 27 ms 27 ms ge-5-1-0.lon22.ip.tiscali.net [213.200.77.177]
6 27 ms 38 ms 27 ms ge-1-1-0.lon22.ip.tiscali.net [89.149.186.78]
7 27 ms 28 ms 27 ms 213.200.78.238
8 28 ms 28 ms 27 ms ldn-tch-i2-link.telia.net [80.91.250.214]
9 27 ms * 85 ms ldn-tch-i1-link.telia.net [80.91.250.217]
10 36 ms 40 ms 39 ms 83.231.148.20
11 35 ms 35 ms 35 ms ge-9-2.the.uk.euroconnex.net [217.112.81.2]
12 36 ms 35 ms 35 ms 217.112.82.21
13 35 ms 35 ms 36 ms passionford1.passionford.com [92.48.66.100]
Did it again and the result is the same:
1 1 ms 1 ms 2 ms 10.0.0.1
2 * 10 ms 9 ms loop0.mxc1-albx.ip.cybercity.dk [212.242.2.141]
3 9 ms 11 ms 9 ms ge-1-1-2-10.mcr1-soex.ip.cybercity.dk [212.242.7
.157]
4 9 ms 9 ms 8 ms ge-1-0-0.br1-albx.ip.cybercity.dk [212.242.6.34]
5 9 ms 9 ms 10 ms 213.242.108.9
6 10 ms 9 ms 9 ms ge-0-0-0.mp1.Copenhagen1.Level3.net [4.68.125.18
9]
7 25 ms 25 ms 24 ms ae-1-0.bbr1.Frankfurt1.Level3.net [212.187.128.3
0]
8 25 ms 26 ms 25 ms ae-22-52.car2.Frankfurt1.Level3.net [4.68.118.48
9 25 ms 24 ms 25 ms telia-level3-te.Frankfurt1.Level3.net [4.68.111.
102]
10 25 ms 26 ms 29 ms ffm-bb1-link.telia.net [80.91.254.162]
11 32 ms 32 ms 32 ms prs-bb1-link.telia.net [80.91.249.45]
12 35 ms 35 ms 35 ms ldn-bb2-link.telia.net [80.91.254.210]
13 35 ms 35 ms 35 ms ldn-b1-link.telia.net [80.91.248.89]
14 35 ms 35 ms 35 ms ldn-tch-i1-link.telia.net [80.91.250.210]
15 36 ms 40 ms 39 ms euroconnex-117941-ldn-tch-i1.c.telia.net [213.24
8.104.226]
16 35 ms 35 ms 35 ms ge-9-2.the.uk.euroconnex.net [217.112.81.2]
17 37 ms 37 ms 37 ms 217.112.82.21
18 37 ms 36 ms 41 ms passionford1.passionford.com [92.48.66.100]
Looks like all information get a bit around
.157]
9]
0]
102]
8.104.226]
Got this message from Euroconnex, who I sent an inquiry to:
eUKhost has notified us of this issue, at this present time there is an issue between Tiscali and Telia link, the two companies are major world wide carriers. We have contacted tiscali in regards to this issue however they have not provided us an update. If you have any further questions feel free to let me know.
1 2 ms 1 ms 1 ms 192.168.0.1
2 36 ms 35 ms 36 ms lo98.sc-acc-bras-11.as9105.net [212.74.102.11]
3 36 ms 36 ms 35 ms 10.72.4.149
4 36 ms 36 ms 36 ms 10.72.4.190
5 37 ms 37 ms 42 ms ge-5-1-0.lon12.ip.tiscali.net [213.200.79.9]
6 37 ms 36 ms 37 ms so-7-0-0.lon22.ip.tiscali.net [89.149.186.22]
7 38 ms 37 ms 37 ms 213.200.78.238
8 36 ms 36 ms 38 ms ldn-tch-i2-link.telia.net [80.91.250.214]
9 37 ms 36 ms 37 ms ldn-tch-i1-link.telia.net [80.91.250.217]
10 50 ms 49 ms 49 ms 83.231.148.20
11 44 ms 43 ms 44 ms ge-9-2.the.uk.euroconnex.net [217.112.81.2]
12 45 ms 45 ms 46 ms 217.112.82.21
13 44 ms 45 ms 45 ms passionford1.passionford.com [92.48.66.100]
race complete.
:\Users\Gordon>
race complete.
:\Users\Gordon>
