PDA
View Full Version : Fiesta's Other !
Pages : 1 [2] 3
  1. 1.6 Zetec-S (MK4, Puma) Gearbox ratios
  2. Adjusting throttle cable
  3. EGR Valve
  4. MK6 Fiesta Remote locking
  5. 2 Litre into mk5 Fiesta
  6. fiesta zetec s
  7. Wiring xr2i spot/fog lights to mk3 fiesta?
  8. mk6 fiesta focus rs engine
  9. 1.4 tdci fuel filter, shall i?
  10. Mk6 Fiesta front bumper question.
  11. few questions about kent in mk3
  12. Grinding pistons
  13. Is my Ford Fiesta Zetec R Reg MK4 at the end of its run?
  14. Need Fiesta mk4 wishbone bolts
  15. help
  16. Front o/s brake line replacement
  17. 2003 tdci 1.4 fiesta coolant temperature light always on
  18. 2003 1.4 tdci clutch pedal issue...please help!
  19. Zetec S 2.0 bottom end?
  20. fiesta mk6 zetec s induction kit
  21. 1989 Fiesta 1.1 CL - 2 questions
  22. Mk 6 Fiesta zetec s Front Brake Upgrade
  23. What to look for when buying a fiesta ZS tdci?
  24. 2.0 zetec in a mk2 xr2
  25. mk1 fiesta xr2 find
  26. Pictures of Ford Fiesta Headlamp Protectors
  27. Spark Plug Gap
  28. Being offered a barn find today
  29. Fuel Filter Change
  30. Need Help Which car??
  31. Car Cutting Out
  32. fiesta tdci van
  33. Fiesta knocking from front
  34. Wanted pcd wheel code for mk1 fiesta
  35. Im new!
  36. 2004 Fiesta fog light
  37. Mk5 exhaust
  38. Fiesta 1.2L Freetyle Air Filter Location?
  39. 1991 xr2i ( power steering )
  40. Fixing Rust Issues On My Fiesta
  41. fiesta mk5 heating problem
  42. my new mk2 xr2
  43. Fiesta Rev Counter
  44. Fiesta MK3 1.8D
  45. 2006 Zetec:Strange Passenger Window ??
  46. taking the shock out of rear shock absorbers
  47. Fuel Cap Lock Issue. Advice Needed
  48. 1.8/2.0 zetec engine in to mk4 fiesta
  49. front suspension loose top mount
  50. Cambelt kit, which products are needed?
  51. Fiesta mk2 xr2
  52. radiator fan
  53. fiesta over reving
  54. Help!! Bra for fiesta xr2 mk2
  55. Show me your i.c.e installs
  56. 2005 TDCi wont start air in fuel pipes
  57. Heater always hot, even when it's on cold?
  58. 1.25 oil thirsty?
  59. Fiesta tdci diesel pump problems
  60. Start of a new chapter
  61. Recaro Seats In Mk5 Zetec S
  62. Replacing "middle" part of steering wheel
  63. Mk6 Fiesta Single Din Conversion
  64. Threads asking for Car Stereo codes are not allowed.
  65. Mk4 fiesta Mod?
  66. quick mods
  67. My pals ST Replica - What you all reckon?
  68. best place for recon gearbox
  69. 1997 Automatic Fiesta - Losing Revs - Help Please
  70. help me please...:(
  71. Mk5 z-s driveshaft removal
  72. Fiesta MK5 air bag light on solid
  73. Engine light on 2003 ford fiesta zetec 1.4
  74. Newbie, my mk5 fiesta
  75. Mk3 Fiesta electrical problem
  76. do all mk4 fiesta's have a hydralic clutch ?
  77. front mk5
  78. Anybody from moray area??
  79. Newbie :) mk4 fiesta adivce needed
  80. Newbie with mk 6 pre facelift question
  81. my r reg fiesta
  82. MK2 fiesta turbo
  83. help with my ford fiesta battery light
  84. Fiesta 4500 RDS EON Keycode
  85. Anyone here?
  86. Mk6 fiesta electric window problem help
  87. Mk4 Courier bodywork
  88. Rear wheel bearing
  89. t3 turbo kits question
  90. Fiesta mk6 airbag light
  91. Ahhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh hh help me lads
  92. How to tell if cambelt is origional.
  93. Mk5 ZetecS Tapping Noise
  94. mk 6 fiesta engine conversion?
  95. Fiesta mk6 racing seat
  96. ECU location and removal
  97. Fiesta mk6 Zetec/duratec head
  98. MK4 Fiesta's,what are my options?
  99. Water pump for F6JB
  100. Going to see a 54 plate 1.4 TDCi today
  101. What to look out for when inspecting and test driving a 52 Fiesta 1.4 TDCi
  102. anyone know of this mk1 FBW 263V
  103. In need of XR Restorer / specialist (north west)
  104. Fiesta door sensor issue
  105. mk7 zetec s
  106. mk6 fiesta brake lights.
  107. MK V Fiesta Seat Cable Replacement Query
  108. Newbie :/
  109. changed engine on 2002 fiesta 1.4, now won't start???????????????
  110. Help
  111. Mk1 Fiesta XR2
  112. Fiesta 1.25 mk4 flat and hesitating
  113. 1.7 puma conversion
  114. Replace Clutch - £500
  115. mk5 fiesta zetec s INNER REAR WHEEL HOUSING
  116. Fietsa Mk 5? 2003 Engine Revs
  117. MK6 Front Strut Brace
  118. mk6 ghia alternator change
  119. fiesta zetec s engine?????????
  120. Turbo for a 2006 Fiesta Zetec S TDI
  121. Fiesta auxiliary in fault
  122. XR2 Pepper pots
  123. Fiesta Zetec-S Central Locking
  124. as theres a forum for it , 1.25 thermostat , where?
  125. Ka / Fiesta Suspension
  126. Fiesta mk3 floor
  127. max power on std fiesta managment
  128. mk3 fiesta sills cost?
  129. Fiesta 1.25 Misfire on cylinders 1 & 3
  130. MK5 Fiesta zetec hanging revs.....
  131. Capabilities of the standard ECU on 1.3 ecotec mk4 fiesta?
  132. Lovely looking Fiesta..
  133. et28 on mk3 fiesta
  134. FiestaST engine into mk6 1.4 fiesta pre-facelift?
  135. Any Fiesta ST Owners on here?
  136. changeing a mk5 fiesta fuel pump
  137. Fiesta ST500 build number
  138. Ford Fiesta Championship
  139. fod fiesta battery light is still on after alternator change
  140. More Power diesel 1.8 td Fiesta
  141. Fiesta Cosworth on sale?
  142. Databse for fiesta rs turbo nuts & bots etc
  143. fiesta project mk1 GEARBOX
  144. Brembo : Brackets to fit a Fiesta ST.
  145. Mk 3 fiesta body repair in south Wales
  146. 2 litre fiesta
  147. Changing head unit in MK7 Fiesta
  148. price of fiesta st
  149. mk1/mk2 fiesta 4wd
  150. fiesta zetec s clocks
  151. fitting audi haldex system to ford fiesta
  152. My mates RWD MK2 Fiesta Cosworth...
  153. Can you make a TDCI Fiesta Zetec S Faster?
  154. drivers door mk3 fiesta
  155. Fiesta choice
  156. Fiesta Zetec S Mrk 6 tuning!
  157. Fiesta mk3.5 Lower Arms/Wishbones
  158. Fiesta Electric Widows
  159. modded fiesta on ebay lol
  160. Anyone know this awesome fiesta cosworth?
  161. New shape fiesta question
  162. 2.0 Zetec (black, silver), duratec => Fiesta mk4/5 - little help needed
  163. the fiesta's got a wet boot
  164. Fiesta RS1800 rear axle
  165. mk7 fiesta
  166. Fiesta Zetec S tdci starting problem
  167. Fiesta Zetec S tdci wont start!!
  168. RS Centre fiesta?
  169. HELP!! mfi fiesta
  170. HELP!! mfi fiesta
  171. Fiesta rs1800 Suspension
  172. mk1 fiesta idle
  173. ST170 engine in a mk5 Fiesta Zetec S
  174. Fiesta Zetec 1.6 strange noise
  175. fiesta mk2 brakes
  176. fiesta st brakes
  177. Fiesta wiring loom question
  178. Fiesta turbo wiring diagram
  179. Bike engined fiesta
  180. fiesta 1.25 zetec running problem
  181. Mk2 fiesta lowering kit
  182. mk1 fiesta
  183. ST170 Gearbox Conversion for RS1800 Mk3 Fiesta
  184. Fiesta Mk6/6.5 Suspension
  185. Fiesta Finesse need another key
  186. When should the Timing Belt be changed on a Fiesta Zetec S
  187. Fiesta t3 conversion help
  188. TURBO CHOICES T3, stg 3 t3, or t34....Fiesta Turbo
  189. ford fiesta air con
  190. help loss of power fiesta 1.25
  191. The blue MK2 fiesta Cosworth thread
  192. OEM 60mm Throttlebody for Duratec-HE 2L (like Fiesta ST)
  193. fiesta 52 plate mk6 blower
  194. fiesta jacking point cover
  195. 1.6 EFi in MK2 Fiesta died on me on the way home!
  196. mk1 fiesta got wrote off today:(
  197. fiesta st parts
  198. Stupid fiesta latches
  199. fiesta st tuners or packages
  200. powering looms up mk3 fiesta
  201. Focus alloys on a fiesta
  202. MK4 Fiesta ideas
  203. fiesta zetec s pics ?
  204. Fiesta Rs 1800 Fuel Consumption
  205. Coughing Fiesta, Help needed!!!!
  206. Mk4/5 fiesta engine bay pic req
  207. can someone check these fiesta part numbers?
  208. Water pump change on 1.25 Zetec Fiesta
  209. Fiesta help needed!
  210. fiesta springs
  211. just bought a mk5 fiesta
  212. mk5 fiesta fog lights
  213. Fiesta mk4 tape player change
  214. My Fiesta... :(
  215. Fiesta in the Park.
  216. my fiesta 12.5 zetec pulling to the left
  217. mk1 fiesta roof skin
  218. Why dont a lot of mappers touch Fiesta RS Turbo manegement?
  219. help with coilovers mk3 fiesta
  220. puma engine into fiesta
  221. fiesta mk1 what engine can i use
  222. mk4 fiesta 1.25 zetec misfire
  223. Fiesta zetec s
  224. good CV joint manufacturers? - fiesta rs turbo
  225. cv joint / knuckle query??? - fiesta rs turbo
  226. anyone have or seen this white fiesta turbo J116 JKN ?
  227. help my fiesta please?
  228. Front ended Fiesta st A1 northbound@team valley
  229. suspension diagram for a mk 6 fiesta
  230. '03 Fiesta clutch problem
  231. Fiesta mk1, mk2 single choke carb
  232. Fiesta radio
  233. Fiesta ib5 gearbox oil capacity
  234. Fiesta 1.1/1.3 bike carb conversion? help
  235. Fiesta Turbo Conversion
  236. Can a fiesta ST tow?
  237. mk1 fiesta equal length driveshaft
  238. Ford Fiesta ST engine conversion
  239. fiesta st gearbox
  240. Fiesta GTR........MISTAKE
  241. who can refurbish standard fiesta rs turbo suspension??
  242. My Fiesta.....a finished picture :)
  243. mk5 fiesta suspension mounts
  244. Will 13" Fiesta wheels fit a KA?
  245. can anyone refurbish a fiesta mk3 scissor jack?
  246. Puma conversion into 1.3 Fiesta helpppp!!!
  247. 1.1 Fiesta Mk2 help
  248. equal length shafts on mk3 fiesta ?
  249. 2.0 zetec e silvertop engine into fiesta zetec s
  250. focus, fiesta and mondeo ST's ripping up the A9!!! was it you???
