Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Fuel Cap Lock Issue. Advice Needed
Old Jan 24, 2012 | 08:51 PM
chrisb1357's Avatar
chrisb1357
Default Fuel Cap Lock Issue. Advice Needed
Hi all,
Just got back into work and had to get a cheap run around to get me from A to B so i decided to get a 2001 (Y Reg)ford fiesta freestyle 1.2 for a few months until i get back on my feet. Am i correct its a Mk4 if its a Y Reg.
One thing i forgot to check when i got the car was thefuel cap. Went to fill up today and found the lock was very tight and would not move and after some force i got it open. When i turn the keys in the fuel cap lock when its off the car the bottom part does not turn (Should the bottom part turn).
Is this a known issue and whats the best way to fix this
Had a look at the cap again, The key inserts and turns fine in the lock but should the lock turn in the plastic cap and also should the bottom half of the cap move when the key is turned. I know it sound stupid but am not sure as its my first ford
Not sure if the cap is locking correct as it seems to move a little from side to side when the key is removed and the cap in place
Chris
Old Feb 6, 2012 | 08:42 PM
Tonwah's Avatar
Tonwah
Quite common for the caps to fail, you can buy an after market cap from your local motor factor for about £12, but you could also try and soak the complete fuel cap in WD-40 as that can some times work.
If your car is a 2001 it will be a mk5 fiesta, identical to mk4 fiesta apart from the headlights, bumpers, grill and wings
JoeyBoyden
Jan 4, 2024 02:36 PM
ginner
13
Aug 30, 2015 08:40 AM
Seanyfarrell
Aug 14, 2015 11:37 PM
muffster
Aug 12, 2015 08:14 PM
col93saphcos
Aug 7, 2015 03:21 PM
