Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
Mk6 fiesta electric window problem help
Old Sep 19, 2011 | 05:41 PM
rabmc's Avatar
rabmc
Exclamation Mk6 fiesta electric window problem help
Guys a bit of help please
The other halfs fiesta electric window drivers side wouldn't go up the other day, stuck quarter way down, would go Down then back up to same position sounded if it was jamming sticking, a sort of grinding noise.
I took the door card etc off and noticed nothing jamming it,visually anyway.
Now in behind door card etc the cords or whatever you call them that connect and pull the window up on side is now loose sagging, question is. Is this the electric window motor guys? If replaced will those cords go back into place and be tight as they should? The reason they are loose Is I pressed and pulled runner and pulled them out as couldn't get window up, basically lost it lol.
Thanks
Old Sep 19, 2011 | 05:55 PM
Northants Ford Fan's Avatar
Northants Ford Fan
at a guess its the motor that is sticking mate all you need is to tap the motor, it should get it working as I have had the same problem with my mums c max the window gets stuck down.
Old Sep 19, 2011 | 05:59 PM
rabmc's Avatar
rabmc
Thanks mate I will try this, just was a bit worried about the metal wieres/cords that are on runners because in sheer anger I forced the window up! Argggggggghhh typical me
JoeyBoyden
Jan 4, 2024 02:36 PM
gordyshreds
20
Aug 10, 2015 02:59 PM
jimmy oldskool
Ford Focus (All Models)
Aug 4, 2015 06:54 PM
jimmy oldskool
Aug 4, 2015 07:06 AM
