Fiesta's Other ! This section is for ALL types of Fiesta models that are (NON RS / ST) Such as ZETEC S /S16000 / METAL /TITANIUM / GHIA etc
mk1 fiesta
Old May 29, 2011 | 01:20 PM
turbobill's Avatar
turbobill
Default mk1 fiesta
to those out there who has a mk1 fiesta 1.1, do you find that yours are econimcal or juicy??,i have a 1,1 with a vv carb and it seems to drink petrol, just cururious to know weither its right or if its mine,
many thanks
Old May 29, 2011 | 04:57 PM
richard youll's Avatar
richard youll
what does it pull like if its feels quite flatt and its heavy on juice get a vv repair kit pay particular attention to the diaphram if its split = heavy fuel and very slow also the low comp 1.1's were not very good on fuel either. My 1.1 high comp engine gets 40 mpg, my apprentice runs the same and gets about 44mpg
Old May 29, 2011 | 05:56 PM
Ryan_3's Avatar
Ryan_3
ditch the VV mate. they are shit carbs. fitted a weber of an uno fire in my 1.1 mk4 escort, its now VERY good on fuel and goes well too
Old May 29, 2011 | 08:31 PM
Even better fit a dellorto carb, if you can find one.
You can check the diaphragm in a few seconds, take air filter off, pull back slide, let go, if it snaps back instantly the diaphragm is holed/split, if it takes 2 secs or so and returns gently it's ok.
The VV is not a performance carb, but is a very good all round carb, giving few problems.
I've retrofitted some astras that have had weber carb conversions to the trouble some Pierburg 2E3, which when set up right gives better power and better mpg than the weber
carb, so don't just jump at a weber, thinking all is rosy.
Old May 29, 2011 | 10:23 PM
richard youll
thoses 2e carbs can be an utter utter c*nt when they are playing up on golfs and polo's but yes when they are right they are defo a good carb,
Old May 30, 2011 | 11:48 PM
turbobill's Avatar
turbobill
Thanks for all the advice, the car pulls away well and is responsivee, as for the carbrettor the slide once pulled back comes back in gently,
wowk
Mar 30, 2021 07:49 PM
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
Steve Escos
Oct 1, 2015 06:57 AM
Tank Mike
Sep 26, 2015 08:07 AM
