View Full Version : Fiesta
- 1988 XR2 Suspension arm bolts
- Supersport parts needed
- Mk4 engine in a Mk5
- MK6 fiesta trouble starting.
- Fiesta Mk7.5 1.0 Ecoboost Modifications
- Fiesta 51 plate rear speaker install
- When should the Timing Belt be changed on a Fiesta Zetec 1.25 16v
- Fiesta Mk5 wing mirror
- Front seats latch cable
- Zetec conversion
- MK6 Fiesta Seat Tilt Handle
- Mk5 fiesta fuel vapour canister
- 2004 fiesta 1600 starting problem.
- Mk6 using mk6.5 parts
- cam pullys
- 2005 mk6 suspension
- MK5 Fiesta 1.8d - Mass Help Required
- cutting out
- Help needed finding fuse for auto boot release
- mk5 zetec s final drive
- 2005 Ford Fiesta - remote central locking not going into learning mode
- Refuelling problem.
- fan switch settings help
- my first car
- Fiesta 1.4 tdci diesel leak- 4 times in garage help!!
- ford fiesta mk6 headlights
- Mk 4, 1.3l Studio, - brake disc change
- Fiesta 1.25 zetec alarm
- dash board running water?????
- water sound problem
- Mk6 Zetec S - Custom diffuser
- Lowering the mk5
- Mk6 Fiesta 1.4 TDCi whirring noise
- Help Needed please - Interior heating controls!
- Help????????
- Coolant Temp Sensor...
- 59 plate fiesta immobilizer problem IT RUNS!!
- Cosworth wheels on a fiesta m6
- Which is best hatchback should i buy?
- Zetec help please
- Mk7 fiesta zetec-s 1.6 tdci?
- Fiesta mk6 Engine swap help!!!
- 1.3 to 1.7 engine swap MK5 fiesta
- Fiesta 02 reg 1.4 'duratec'
- Rear lights
- fiesta 1.6 tdci 2009 thing to look out for
- Zetec s phase 2... idle problems
- Fiesta TDCI 1.4 'Silver' standard suspension?
- Ford Fiesta MK6 Wheel Spacers
- Ford fiesta 1.4tdci. 57 plate ?
- Mk2 fiesta - Dashboard switches loose
- Mk6 EML ??
- Ford Fiesta 1.4tdci
- 2006 fiesta 1.6 tdci revs stay at 1200 on changing gear
- Ford fiesta mk 6 1.4
- Fiesta mk6 steering issues.
- Fiesta Boot
- Ford techs - Fiesta ASM issue
- fiesta st engine into fiesta 1.2
- MK4 fiesta accersories
- Heater settings 1, 2, 3 keep dropping out??
- fiesta mk3.5 engine rebuild
- Where is this water coming in!
- wet fiesta boot, where's the water coming from?
- Mk7 Fiesta S1600 headlamp bulb.
- Ford fiesta zetec s
- Ford Fiesta 1.25 LX 54 plate HELP PLEASE!!
- Fiesta mk6 53 plate p0400 Exhaust gas recirculation flow malfunction help!
- Mk4 fez, keys lost. Reprogramming spare? Help can it be done?
- How easy is it to fit a new bonnet (mk5 fiesta)?
- Ford techs help!
- Difference between fiesta and fiesta van....
- bought a 59 plate fezza zetec
- Mk6 Zetec S Cigerette Lighter & Aux Cable Not Working
- Mk6 fiesta gearknob thread size help ?!
- Hole in Chassis
- changing heater blower motor
- Help needed. Engine only running on 3 cylinders?
- efi rs turbo mk2 fez. no spark no fuel????
- Fitting st side skirts to a standard fiesta
- Fiesta Mk4/5 Dial conversion?
- Fiesta 1.4 TDCi
- Fiesta mk tdci rattle/vibration
- Ford Fiesta MK6 Strange noise
- Mk5 fezz wing jw
- Fiesta mk6 1.3 exhaust
- fiesta tdci help
- Mk4 fiesta brake set up
- Fiesta durashift help!!
- Focus st 3 stereo in fiesta zetec s mk6
- MK6 54/2005 fiesta flame advice on upgrading to facelift kit
- 02 Plate Mk6 Fiesta Help!
- been offered n reg fiesta, advice please!!!
- Tries to stall when I hit the gas.
- what colour alloys on a silver mk4
- Fiesta MK7 2.0 Zetec possible ?
- Fiesta 1.4 TDCI Advice
- Fiesta 1.25 57 plate timing belt
- Analog to Digital Speedometer?
- who's got a NEW fiesta? ginge?
- repair the arches
- Bumper fit?
- Feista mk4
- MK5 Rear Axle / Adding ABS
- Why are MK5 Fiesta 2001 tax so high
- 15inch Alloys onto a MK5 Fiesta fun with 13inch wheels
- Mk6 zs exhaust....
- MK6 Fiesta Mist Jets
- fiesta 1.25 (58) light throttle hesitation
- 17s?
- Scratch removal?
- Internal Display
- Push to start button
- Changing wheel studs
- The girlfriends 1.25 mk 4 fez, idel problem. Help please
- Fiesta debadge guide [NO "TOOLS"]
- 2003 Ford Fiesta 1.4 16v, No spark on 2&3
- zetec s Change dash lcd colour
- Fiesta cutting out :(
- FRP Widetrack on a Mk4 fiesta
- '88 Mk2 Fiesta
- fiesta help !!
- Zetec s turbo conversion?
- Mk5 Fiesta Zetec-S Overheating
- Broken steering lock
- Help! Lowering my mk6 fiesta
- spongy brakes
- Fiesta rubbing
- xr2 engine
- Fiesta problem
- Fiesta stereo help
- Can anyone help me
- Mk3.5 runners
- mk3 door pins
- Mk6 Zetec-S Brakes help!
- mk5 clutch issues
- cleaning zetec s steering wheel up.
- Heating/Cooling Driecton knob MK6 2006
- Semi or fully synthetic oil? Fiesta 1.6 TDCI
- New to this site ..
- Fiesta zetec S extremely hard ride? Help
- diesel leak hell!!!
- ford fiesta purple colour
- fiesta st performance blue bumper wanted ???
- Wheel offset question
- Cheap induction system (pic)
- Jacking points on fiesta mk6 (pics?)
- Zetec coolant leak
- Airbag light stuck on help please
- 771 Engine
- ford fiesta mk5 and led lighting
- fitting Bucket Seats?
- Fiesta MK5 TDDi Rev counter...
- Mk5 zs puma conversion help?
- unknown fuel leak...
- Fiesta MK6 Zetec S TDCi Pros/Cons?
- Fiesta starting problems - won't turn over
- Fiesta mk5 transplant... But which engine?...
- Mk2 fiesta ST 170
- Mk4 1999 Fiesta Front Suspension advice
- 1.4 tunning
- Mk 6 fiesta xenon bulbs advise
- Coilovers
- Zetec over heating, HELP PLEASE
- turbo on 1.6 zetec se
- Core Plugs - reasonable price??
- ford fiesta wouldn’t start
- Mk5 Fiesta - can door locks be rebuilt?
- mk4 fiesta bootlock/wipermotor
- How change clutch Fiesta 1250 year 2002
- 53 plate fiesta leaking water
- Installing new stereo in MK6 Fiesta
- zetec sigma phase 1 an 2
- Fiesta 1.25
- Mk4 fesa fuse is being a b@#tard
- Few problems,, PLEASE help.
- Fiesta 1.6 tdci econetic 2012 remap advice
- Ford Fiesta 1.25 Zetec 2001 wont start
- Mk 4/5 fiesta 1.25 zetec
- interior
- Help - repair Cost
- no 345 and reverse gear
- Fiesta tdci 1.6 problem
- Anyone have any idea? (mk6 tdci fiesta - exhaust rubbers)
- Mk4 fiesta tail gate wiring
- '96 MK4 Zetec S Throttle Problem
- Fiesta Mk 4/5 Rear Lights onto Mk3
- Fiesta1.25 problem
- Breaking a Ford Fiesta 1.6 zetec s 2001
- zetec s/ zetec se
- Couple Of Questions
- JVC Headunit Resetting
- MK4 front windscreen demister problem
- i have a mk 5 fiesta zetec and how do i remove the rear windows
- Mk4/5 Rear Drum Replacement
- MK3 central locking probs
- fiesta mk4 1.3 8v 1999 full engine convert
- MK6 Fiesta Power Fold Mirror Issue
- Mk6 Fiesta Question.
- Puzzling central locking problems
- Mk1 Fiesta 1100cc 5 Speed Conversion
- MK6 Fiesta -How to remove bulb from high mounted brake light?
- MK5 Fiesta 1.6 Head??
- Fiesta Zetec - whacky flashing light problems help with diagnosis please
- Help with my new fiesta zetec 1.25
- Ford fiesta 1.4 zetec problem starting when cold
- Replace high brake light bulb?
- Car service in Liverpool?
- looking a bit of help with my 1.25 - 1.7 puma engine swap
- post your wheels!
- mk 5 fiesta zetec-s zvh turbo conversion
- 1997 fiesta, convert 2 button fob to a three button
- how long should a 2008 fiesta titanium 1.4 petrol engine last?
- earth problem
- ignition fault zetec 1.25
- Zetec S front bumper + parts
- Calling Zetec S owners!
- mk3 fiesta n/s rear quarter panel?
- best place to get body panels for mk3 fiesta
- Mk2 Fiesta Shell Value
- Ford fiesta mk1 reversing lamp
- Fiesta Zetec S TDCI Clutch
- Fiesta Zetec S TDCI Panel Filter
- Changing/replacing dash lights
- Mk6 1.3 Duratec Lacks Power and Misses
- Twin webers??? help please
- Fiesta Zetec S Mk 6 Plastics
- mk3 fiesta wishbone bushes
- mk 4 fiesta hcv hose position please help
- Fiesta 06 Mk5 Head Gasket, Radiator, Cam Belt etc :(
- Mk2 fiesta pop+ duratec on itbl
- MK 6 engine swap.
- Fiesta mk6 Zetec S advice
- '03 Fiesta duratec 1.3 EML help
- Holding the Flywheel
- engine cuts out when clutch is down
- Fiesta Zetec S kerb weight
- 2002 fiesta tdci diesel leak loss power then stalls helppp
- Fiesta Mk5 timing belt tensioner differences
- thinking of getting a new stereo mk5 fiesta
- 2WD Cosworth brakes (4pots) on 2000 Zetec S ?
- 2006 zetec s tdci
- fiesta rs turbo
- help needed please xr2 fuel problem?
- 2006 cooling fan nicked
- esc edis module
- Serpentine / aux belt
- Fan Switch
- Drivers side drive shaft issue after clutch change
- Changed coolant
