Ford IDS & key programming problem!
Old Jan 5, 2012 | 10:50 AM
actionman's Avatar
actionman
From: in a nice, small & quiet village near Huddersfield
Default Ford IDS & key programming problem!
Hi
i've got IDS & seem to be having a bit of trouble programming keys to canbus vehicles.
So far i've tried it on a 2007 Transit, 2008 Mondeo & 2006 Focus. It works perfectly with older models but when i try it with canbus vehicles it won't connect & i just get an error
anybody got any ideas?
Thanks
Craig
Old Jan 5, 2012 | 11:30 AM
Karl 3dr's Avatar
Karl 3dr
Have you got latest level disc installed? All updates installed? What fault are you getting?
Old Jan 5, 2012 | 12:33 PM
actionman's Avatar
actionman
it's V74 & i've got all the updates for it. It came with 2 discs. 1 had 4 different versions, the latest being V74 & then the other disc just had 1 file on it that said ids-dvd-full
off the top of my head i can't remember what the error code was. I usually store them on my phone but i broke it the other day & i'm waiting for my replacement to come
Old Jan 9, 2012 | 04:34 PM
bobster1982's Avatar
bobster1982
I take it you have a way of getting Incodes?
Old Jan 9, 2012 | 06:10 PM
actionman's Avatar
actionman
yes, several!
Old Jan 9, 2012 | 10:24 PM
bobster1982
Is it a genuine IDS or a clone? I've had problems getting PATS access with cloned tools. And I hope I'm not teaching you to suck eggs but your staying connected when you get the Outcode as they change on each connection.
Old Jan 10, 2012 | 09:46 AM
Karl 3dr's Avatar
Karl 3dr
I was going to ask that, you're not disconnecting the usb lead from ids when entering the details into etis are you? Will check part number for you
Old Jan 17, 2012 | 11:39 AM
kdavie86's Avatar
kdavie86
mk4 daft :P
Post Deleted
Old Jan 17, 2012 | 03:29 PM
bobster1982
Originally Posted by kdavie86
Is IDS and fordetis any good at 2002/2003> Key programming?
I've thought about registering with etis and getting up-to-date IDS for my auto locksmith business, but the cost involved may be too much. Esp as I may only do 2 or 3 Keys in a month?! Etis wants a monthly fee etc. As well as annoying forms for every key programmed.
I use an Advanced Diagnostics MVP for pre-coded access stuff (PATS1, PATS2, early PCM etc) and it works fine.
But I'm also having bother with CAN BUS protocol ECU's.
My Key programmer prompts an outcode, similar to IDS, and requests an Incode to be entered via the keypad on my device.
I've seen an INCODE / OUTCODE Calculator for sale on some chinese OBD website:
http://www.cardiag.co.uk/ford-outcod...00-tokens.html
And also an OBDII lead with an Incode display unit like this:
http://www.cardiag.co.uk/ford-mazda-incode-tool.html
Has anyone used this sofware/device before? I've seen a few reviews and it does seem to work.
CheeRS
Keiran Davie
Instakeys Auto Locksmith Edinburgh
http://www.instakeys.co.uk/
I have incode/outcode software to work with the ad100, t-300 and MPV Key programmers. It doesn't need tokens or a dongle or Etis.
Drop me a PM and I will sort you out.
Old Jan 26, 2012 | 12:40 AM
actionman's Avatar
actionman
well i've just bought Focom. Going to see how I get on with it. According to it's info it will program keys to vehicles up to 2010/11
I have also just bought some credits on www.patscode.com
Old Mar 13, 2012 | 12:59 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
Post Deleted
Old Mar 13, 2012 | 01:49 PM
actionman's Avatar
actionman
Hi mate
Focom as worked with everything i've tried so far so i'm pretty happy with it. Tested it on my mates 2006 Focus which the IDS wouldn't give me the outcode but the Focom gave me it quite quickly.
Then i just accessed www.patscode.com with my phone to get the incode! very simple!
Old Mar 15, 2012 | 10:35 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
Post Deleted
Old Mar 15, 2012 | 11:54 PM
actionman's Avatar
actionman
well once i'd decided I was going to buy Focom I sold the VCM. Didn't see the point in having 2 different things. Especially as Focom cost me knocking on for Ł300.
To be honest I honest i don't use Focom that often. I bought it mainly to program new keys to the newer Fords that my MVP key programmer won't work with. Such as the 2005 onwards Focus, 2006 onwards Transit etc
Old Mar 24, 2012 | 12:14 AM
actionman's Avatar
actionman
bit of an update. Tried using Focom to fully program a new key to a 2007 Focus yesterday but it wouldn't do it.
It gave the outcode ok as it did when i tried it on my mates so i got the correct incode from patscode.com. After the incode is entered Focom instructs you to put the new key in the ignition & then press "cancel" for coding
A communications status bar is there with the bar filling up repeatedly. I tried waiting for about 10mins with the status bar doing it's thing but that didn't change anything & then as soon as you click "cancel" as instructed it just gives an error message
I tried repeatedly for about 1hr with no luck. I've emailed the supplier & they've asked me to email them the debug files & also snapshots of the PCM & IPC info. Just waiting for a reply.
The annoying thing is it took 4 of my patscode credits trying to program the key. Hopefully they can give me some useful info as to why it wouldn't program.
Focom didn't tell me how many keys were already programmed to the car so it may be up to it's limit & i didn't want to risk erasing all the keys in case it still didn't program any as the customer would be left with no working keys
Old Mar 24, 2012 | 11:28 AM
kdavie86's Avatar
kdavie86
mk4 daft :P
Post Deleted
Old Mar 24, 2012 | 05:15 PM
actionman's Avatar
actionman
I read the transponder with my AD900 & it read the id ok. I know when i've come across faulty transponders before it just says transponder missing or something similar.
With Focom you have to add the VIN, ECU part number, serial number & reason for needing patscode.
I didn't get a full years subscription as I wasn't sure which way i'd end up going equipment wise. I'm wanting to buy an MVP Pro or AD100 Pro mainly for VAG precoding but will use it for Ford as well if it will do the CAN keys ok.
I'm still waiting for a reply from OBDtester & Secons to see if they have any idea why it failed. The customer want it sorting sooner rather than later so i've told them if I don't get a reply by Monday afternoon i'll put a TPX2 chip in their key & just clone it. I'm not really a fan of the idea of cloning but sometimes when needs must.
I've got a Galaxy & another Focus to do in the next couple of weeks so i'll see what happens with them & i'll put a comment on here to let you know if they went ok or not
Craig
Old Mar 26, 2012 | 09:43 PM
actionman's Avatar
actionman
bit of an update.
I've been back this aft & replaced the 4D63 chip with cloned tpx2 chip. The new remote with cloned chip initially didn't work in turning the immob off. I scanned it again with my AD900 & it verified it had exact same id as their original chip.
So i took apart the remote, put the blade in the ignition & held the clone chip next to the barrel. It worked perfectly. So basically i had to cut away some of the inside of the key head where the chip sits to make sure the chip sat closer to the end of the key & nearer the transponder ring.
So i think the reason the original 4D63 chip i tried to program failed is that transponder ring has lost some of it's range & possibly added to that that the remote cases i used may be thicker than their original key which may be getting in the way of the transponder signal
I've got another focus to do at the back end of next week so i'll see how it goes with that 1. At least if i encounter the same problem i'll know what it is this time & can modify the inside of the remote
Craig
Old Apr 12, 2012 | 11:48 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
Post Deleted
Old Apr 12, 2012 | 11:58 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
Post Deleted
Old Apr 13, 2012 | 08:21 AM
actionman's Avatar
actionman
where did you get the new key from? do you have a part number for it? every Vec C i do now is a flip style key. Even Vaux don't supply the original 3 button fixed blade type key anymore.
Also, try buying op-com from ebay. It's Vx diag software & extremely handy for how little it costs.
With Vec C the remote locking/alarm function is programmed in at the same time as the transpnder chip. With the older Vx you program the transponder 1st then you have to go into the body control module to program the remote locking
Old Apr 13, 2012 | 02:49 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
Post Deleted
Old Apr 13, 2012 | 05:39 PM
actionman's Avatar
actionman
I've bought keys direct from Vauxhall before but now i get all my keys etc through 3D Group in Nottingham.
The locked display on the dash is probably just because the key hasn't been programmed or the transponder is incorrect. I'd seriously recommend buying op-com. You can do a diagnostic to check why the id46 isn't programming to the car.
Where did you get the chip from? I checked on 3D Group website & they don't list id46 transponder as a seperate item. They're always built into keys. The id46 chips that are listed seperate are for Renault, Peugeot, Citroen etc
Also i've never used my MVP to program keys to Vec C. I always use op-com.
Old Apr 13, 2012 | 07:08 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
Post Deleted
Old Apr 13, 2012 | 07:12 PM
actionman's Avatar
actionman
you're welcome mate!
what do you use for Volvo & Merc keys?
Old Apr 14, 2012 | 03:48 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
Post Deleted
Old Apr 14, 2012 | 04:07 PM
actionman's Avatar
actionman
nope, neither AD100 or MVP can program Volvo keys. Mt AD900 can clone some Volvo & Merc transponders but not many.
Depending on how much athe Volvo & Merc key programming software works out it may not be worth it for me. May take quite a while to earn that money back with them being manufacturer specific.
At the moment i seem to be doing shed loads of Renault key cards. Wasn't doing many before as genuine key cards are quite expensive so by the time i've added my bit on for programming, cutting & travelling etc it can work out more expensive than getting 1 sorted at the dealers. Depending on how far I was travelling.
Now though 3D Group have introduced they're own Renault keys cards which are about half the price of genuine Renault cards i can give good quotes now which has given me more work. Done 3 today & doing another tomorrow.
Old Apr 14, 2012 | 04:42 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
Post Deleted
Old Apr 14, 2012 | 04:50 PM
actionman's Avatar
actionman
i know what you mean. Spending a fair few Ł100 or even Ł1000 is pretty pointless if you're not doing many jobs with that equipment.
Just been quoted Ł450 for some equipment that reads pin cods in Vx CANBUS systems. It also programmes Renault & some Volvo. I can already do most Renault so no bothered about that feature, although i could then sell my Renault programming software & get some cash back
http://www.obdiichina.com/opel-tool/531015.html
I reckon it'd be worth it for me just for the Vx CANBUS pin code reading
Old Apr 14, 2012 | 07:51 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
Post Deleted
Old Apr 14, 2012 | 08:41 PM
actionman's Avatar
actionman
I use True Code. It's a good bit of kit, easy to use & really quick. The longest part is having to wait for 2 mins before you start the car after adding a new key
It reads the pin code then just programs the new key at the press of a button
Old Jun 5, 2012 | 03:48 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
Post Deleted
Old Jun 5, 2012 | 04:09 PM
actionman's Avatar
actionman
Hi mate
no the Renault key cards don't need to be precoded. They just have to be brand new or if a used card is purchased the transponder will have to be replaced with a virgin transponder which means splitting the case open & also having to replace that.
3D Group have their own branded Megane cards now. They're Ł60 inc vat i think. Used a fair few & they seem good enough
Craig
Old Jun 5, 2012 | 07:28 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
Post Deleted
Old Jun 5, 2012 | 07:45 PM
actionman's Avatar
actionman
Yes they'll post to Scotland. Get an account set up online with them. They're on the ball with posting items. There's several postage options so choose what's best for you.
Depending on how much my order is i use 1st class recorded which if you order early enough they'll have it with you next day
I ordered the Vx canbus pin code reader the other day. Should hopefully be here in the next couple of days
Also you're welcome mate!
Old Jul 25, 2012 | 08:41 PM
actionman's Avatar
actionman
Just to add the "Truecode" packed up a bit ago & looks like it wasn't even truecode as i've been contacted by somebody from company that developed TC.
Probably same as IDS so glad got rid of that as well to buy Focom
Old Jul 26, 2012 | 06:52 PM
kdavie86's Avatar
kdavie86
mk4 daft :P
Post Deleted
Old Jul 26, 2012 | 09:40 PM
actionman's Avatar
actionman
Yeh, VX Canbus is going ok, tested it on my sisters Astra H & several other Canbus VX's my mates have & it worked every time.
I pretty much use my MVP Pro for everything now. It's very simple top use & there's the bonus of having tech support at the other end of a phone if needed.
Old Aug 1, 2012 | 11:07 PM
actionman's Avatar
actionman
done my 1st mk7 transit key with my MVP tonight, talk about quick. You don't need to get incode from patscode.com as the MVP does everything itself.
Took less than a minute to erase all keys then program his original & a new key. Certainly a lot quicker than using Focom or IDS.
It does use a token when erasing & programming pats keys. If you buy tokens in a big enough bundle the cost it works out for individual token is about same as what patscode.com tokens cost
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Bailes1992
Aug 16, 2015 07:14 PM
tankybaby66
Aug 9, 2015 07:13 AM
