- 1.4 black mk6 fiesta engine swap for 1.6 zetec s. can the gearbox cope?
- Fiesta mk2 XR2
- obd scanner
- engine light
- mk4 silver top conversion ???
- MKV Fiesta Relays location.
- duratec 2004 overheating issues
- advice needed please zetec engine
- Rev Counter feed for mk5
- mk6 zetec s squeeks
- 1.4 Zetec 2003 rattling noise when accelerating
- 2001 zetec-s issues
- Cat Back Exhaust will a 1.6 exhaust fit a 1.25
- What is this for?
- Ford Fiesta MkII 1986
- Fiesta MK 3 Zetec Build
- Best induction kit for a MK6? [OPINIONS]
- Fiesta debadge guide [NO "TOOLS"]
- Knocking under centre of car when turning
- XR2I/RS1800/RST steering turns lock to lock
- Gearbox problem?
- mk6 fiesta
- Mk5 rollcage
- mk5 1.25 intake hose the same size as a 1.6 zetec s?
- Knocking when turning right, slight creaking in steering
- Heater Bypass Valve Connector Plug
- Mk5 Zetec-S - cheap power mods
- mk5 zetec-s 18mm front ARB - did they all come with one?
- focus Ib5 gearbox in mk4 fiesta
- Mk 5 Fiesta 2.0 Zetec widetrack
- MK6 Fiesta Paint Code
- 1.25 zetec misfire
- mk3 fiesta engine in to mk2 fiesta
- 2001 Ford Fiesta Clutch/Gearbox issues
- Ofac 195
- fiesta mk 3 parts needed please!
- Ford fiesta zetec s mods
- Mk4 Fiesta Lights
- zs seats in mk4 fiesta
- Mk6 Fiesta Double Din Help
- Fiesta steering wheel
- Mk4 Fiesta Lowering ?
- alloys wheels does it increase the insurance?
- Cat back exhaust systems
- Is the MK5 a future classic?
- Ford 6000 radio help?!
- Thinking of Mk5 Zetec S?
- 130ps silvertop in a mk4 fiesta
- 1.7 Throttle body on 1.25 zetec engine - any other parts needed?
- 02 reg Ford Fiesta buzzing at high revs
- 2005 MK6 1.4 16V Fast Idle
- Fiesta MK1 automatic
- Fiesta MK5 Boot Spoiler
- Which ones do I need !!!!
- mk6 engine conversion
- Fiesta zetec s 1.6 exhaust
- Fiesta MK6 cooling fan problem
- HELP Central locking drivers door
- Fiesta Zetec S Engine Mods?
- Fiesta zetec s puma conversion
- 2006 Ford Fiesta 1.6 Ghia
- Ford fiesta mk4 1.4 zetec s conversion ????
- Help needed with 2002 1.25 SE engine
- Help - Engine Management Light on
- Fiesta zetec S, what would you do if you bought one?
- Single wiper conversion
- Mk5 Fiesta - Engine Management Light - Loss of Power + other issues
- Parts for frst needed pls
- Fiesta mk5 zetec turbo conversion
- Mk4 coilovers wanted!!!
- Ford fiesta 1.4tdci 2006 No RPM on crank
- S reg 1.25 zetec
- mk4 1.25
- ford fiesta si 2.0 althernator bracket.
- Fiesta mk3 xr2i engine mount conversion
- my xr2i to 2.5 v6 conversion help has any one on here done it
- how to fit an omex rev limiter on a puma's zs
- MK3 Fiesta XR2i Upgrades
- Mk6 1.6l Crankcase Breather help
- Fiesta zetec s suspension help
- puma speed mk5 fiesta.
- Fiesta rs turbo blue injectors??
- Newby with an x reg zetec s :)
- Fiesta mk5 dashboard changes
- freeing up stubborn spark plugs
- fiesta tddi mk5 anybody tuned one
- Colour Coding Bumper Trims?
- Petrol FUEL SAFE replacement MK6
- Mk4 fiesta brakes
- HELP! Problem with Ford Fiesta 1.2cc Zetec engine
- MK5 revs goes up but speed is not changing
- MK6 ECU Wiring diagram
- Water inside the car
- Can you fit electric windows onto a MK6 finesse?
- Will a 1.3 KAs hubs/steering knuckles fit on a 1.2 mk5 fiesta?
- Requires a locksmith - Car diggi won't unlock automatically
- Zetec S Interior Light
- mk6 fiesta 1.4 - is this a gearbox or clutch issue?
- Failed MOT due to emmisions
- mk1 fiesta engine conversion to 1300 escort
- XR2 boot hinge
- XR2i Restore
- Water inside the car-side conductor
- Battery high voltage error code b1317
- Mk4 uprated shocks?
- Ford Fiesta Idle speed control valve?
- mk5 fiesta error codes
- mk4 fiesta cutting out
- buying a fiesta mk4 ?
- Fiesta mk5 heating
- 2003 Fiesta TDCI Turbo Pipe Blown
- Fiesta mk4 coilover help!
- Will a 1.25/1.4 bumper fit a Mk5 Zs ?
- Ford Fiesta MK 5 interior change
- Fiesta D starting wont start
- Bonnet Catch
- Fiesta 2000 - Radio Installation
- lowering spring problem ..
- 771 Engine
- mk1 fiesta engine change
- fiesta mk5 door handle problem, its broke..
- mk 6 zetec s et for 18" best fitment?
- 1400/1600 zetec
- puma'd zetec s fiestas..any good?
- CD Player Error Msg
- Fiesta xr2 question
- front suspension desperate!!!!
- Please help me find out the cause of this...
- fiesta gearbox
- rs1800 running bike carbs into a mk2 van
- 1.4tdci not starting when it's really cold
- Rear Bush Opinions
- Fiesta Mk6 1.6 Zetec S gearbox oil seal
- Sparks coming from the exhaust
- 2.0 zetec in mk2 xr2
- 06 Fiesta OEM radio swap
- Pcv hose - fiesta 1.4 2003 reg HELP!
- Mk6 semi auto gearbox any good?
- Lots of issues!
- Ford fiesta 1.4 zetec 2003 - crankcase breather pipe
- Mk2 FIESTA...ADVICE ON NEW EXHAUST...plz help
- Window Fiesta MK1 in à MK2
- 2003 ford fiesta
- Ford Fiesta mk6 engine swap need help
- fuel consumption?
- Fiesta discharging battery?
- Just got this E reg Ghia
- Mk5 driveshaft
- Brembos, MK5, Possible?
- mk 1 steering wheel boss?
- Ford Fiesta - Screech/Squealing sound from engine at higher revs.
- What engine should i get for my fiesta mk6?
- Help - advice about parking sensors
- ST150 B12 Suspension Fit 5 Door 1.4 MK6
- 09 Zetec s Throttle problem
- help please
- Fiesta vented brakes?
- mk4 front wheelbearing
- timing chain/belt
- Snapped under bonnet release arm.
- fiesta mk6 aftermarket electric windows
- fiesta mk6 central locking problem
- My crazy sleeper project!
- Fiesta MK 3.5 Exhaust Front Pipe Replacement. Advice needed
- zetec s exhaust
- Water coming from wrong pump
- 2 litre blacktop into a mk3 base model
- Engine swap
- zetec s
- Fiesta Mk6 facelift Bulb Upgrade
- mk1 fiesta hub nut size???
- Fiesta mk6 gear linkage
- Xrv gearbox
- HELP Mk2 fiesta wide arches?
- Which engine??
- thoughts on this fiesta cost to repair
- HELP PLEASE! Fiesta washer motor problem!
- Fiesta 1.3 to 1.7 puma engine
- need advice on this part
- hi can anyone help plz
- Zetec Zetec Timing pin location and crankshaft pulley bolt
- will 1.6 CVH fit in 1.1 ? (mk3)
- Fiesta xr2i timing belt issue
- mk2 fiesta XR2 body kit? any one got one and advice on fitting
- Puma inlet on ZS
- wiring colours to upgrade to remote central Locking
- mk6 fiesta
- Instrament Cluster Swap
- mk5 turbo
- Does a mk2 xr2 engine fit straight in a mk1 fiesta???
- Ford RS steeringwheel boss for mk1
- help!!!! mk2 xr2 twin 40's loss of power
- Mk2 xr2 arches fit mk1???
- Wobbley Gearstick
- Help!! Problems with some electrics on Fiesta Mk5 1.6
- Fiesta 1.25 Zetec woes
- 1.25l Zetec 16v Fiesta '95 conrod bearings
- To fix up or not to fix up, that is the question
- Turbo help
- Which AFM for Zetec 1.8?
- Running probs
- PLUGS
- RS Turbo Stainless Boost pipe
- Swapping a Mk6 steering wheel
- 2.0 blacktop into mk5 (zs)
- Fiesta zetec s or metal
- Thinking Of Buying A XR2, Need Some Advice
- Anyone know anything about H654 XTO?
- Mk5 Lights on warning buzzer in a Mk4?
- internal fuel cell help!!
- Fiesta zetec s turbo engine mount
- xr2i engine conversion
- types of diesel fiesta engines
- S1 RST wheels on a mk2 fiesta
- Mk6 Fiesta 2.0 duratec turbo help
- Where Can i go To Sort Out Rust On My MK5 Fiesta Zetec s
- New Fiesta Zetec-S Ideas
- Mk4 fiesta Mod?
- Mk3 Fiesta UJ
- 03 Fiesta Ghia remote boot lock problem
- 2.0 blacktop into a mk 3.5 fsi??
- help with my fiesta battery light
- Engine change fiesta mk6
- engine mods xr2i 1800
- Engine cutting out Zetec
