Where Can i go To Sort Out Rust On My MK5 Fiesta Zetec s
basically what is says above do most garages to do it. is it expensive. any help wil be appreicated
Thanks
Dan
Thanks
Dan
There's a place in Kent which is about £200 per corner but they do it properly.
You need it to be rolled and seam welded/sealed properly tho or it will rust straight away again. Best off asking any local places if they have done a mk5 before as i know quite a few people have had issues with garages not doing it the right way
Yes, most garages will do it.
It can be expensive if you want a 'like new' quality job involving buying panels, measuring, cutting, welding, filling, prepping, painting and polishing. A lot of hours would be involved.
If you want it to pass an MOT, patches are acceptable and obviously much cheaper. They can then use any old piece of steel sheet and blob some paint over it afterwards. Only problem is the rust will come back within a year or so.
Best to work out exactly what you need then call a few places and ask for a quick quote.
while your at it, check the inner rear wheel arches < mine where total rotten and failed its mot for this reason, just whip the rear panels inside of for a look.
JoeyBoyden
04-01-2024 02:36 PM
borboyous
22-08-2015 11:17 AM
