mk2 fiesta XR2 body kit? any one got one and advice on fitting
as above really bought a 27000 miles genuine milage 1.1 and want to xr2 rep it
BLU is the new black :)
If I was you I really wouldn't bother, especially if the body work is sound!
If you really want to its a case of sourcing the parts, try to get a kit that has all the studs attached if you can! The arches bolt on through the wings/rear quarters, the front and rear aprons are riveted under the bumper and the skirts /rear spoiler are fitted using threaded studs that push into special plastic sockets inserted into the bodywork. In other words a shit load of holes (carefully measured) need drilling. Remember to treat the drilled holes to prevent rust.
Or you could bodge (stick) them on with tigerseal
