Fitness / Weight Training Discussions Don't drive around with 4 chins! Chat to like minded folk in here and get yourself back to a decent health and fitness level in no time.
How Much Can You Bench Press?
Old 05-10-2009, 03:45 PM
  #41
saul1988
saul1988's Avatar
been training a year now and stuck at 125kg max rep. any suggestions fellas
Old 07-10-2009, 02:30 PM
  #42
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
100kg is my best, I managed 8 reps to which was good.
My goal is 140kg.
Old 07-10-2009, 03:34 PM
  #43
Coldo
Coldo's Avatar
Are people using a smith machine with 2 plates a side here? Or a proper olly bar with 2 plates on a side?
Seems to be alot of people pressing 100kg or more which is surprising tbh.
Old 07-10-2009, 03:41 PM
  #44
Kieron
Kieron's Avatar
I use a free weight bar, the same width as the big olympic bar (6ft is it?) but its small size thickness if you see what I mean. I don't use the Olympic weight, just standard plates and I never count the weight of the bar itself.
I find the wider the bar the better/easier it is to press and I also like using the loympic bench down our gym as it has a wide bit to lay on. Some of the other bences are thin and dig right in to my shoulder blades.
Old 07-10-2009, 03:42 PM
  #45
Charlie Chalk
Unknown.
Bench and bar for me, I'm only doing 80kg at the moment, 100kg was when I was on gear.
Old 07-10-2009, 04:36 PM
  #46
kiddie
kiddie's Avatar
Bench and bar, 2" olimpic bar, don't include the weight of the bar.
So 100kg is a good weight to be stuck at? lol
Old 07-10-2009, 05:58 PM
  #47
Benni
Ban[B][/B]ned
Benni's Avatar
I can lift more on the normal bar and reading up so can lots and lots of others. Apparently a lot of it is to do with not being able to cheat and having to use good form. A quick quote:
One of the main controversies between proponents and detractors of the Smith machine is whether or not it is inferior to free weights. While there seem to be benefits of free weights over Smith machines, they may be overstated. Researchers at Drake University, Iowa tested the premise[citation needed] and found that lifters were able to lift greater amounts on free weights than they were on a Smith machine. As reported in the Journal of Strength and Conditioning Research[citation needed], bench press strength was about 16% higher for the free-weight bench press as compared to the Smith machine bench press. However, squat strength was about 4% greater for the Smith machine as compared to the free-weight squat.
For those who concerned
Benni.
Old 07-10-2009, 09:54 PM
  #48
dave cos4x4
dave cos4x4's Avatar
i was thinking that too.
i'm out of shape a bit, been working away and just getting back into it and tbh i'm struggling lifting 120kg x 8-10 reps. i'm 85 kg in weight and reading the replies on here , you lads are doing really well, are most of you on steds or something as thats a lot of weight to bench a good few times.
there are a few lads that lift a good bit of weight in our gym but they are BIG lads, a lot more body weight than me lol.
well done if its just down to pure strength.
Old 07-10-2009, 10:56 PM
  #49
BigErn
BigErn's Avatar
I have never been comfortable benching with a smith machine, a couple of lads I know used to prefer it but its something personally I cannot get away with. Its just not a natural motion. Free weight allows the slight movement you need for a good press. Bench and olympic bar every time for me. I think Id struggle with 2 plates a side for 8 reps nowadays.
Old 08-10-2009, 08:12 AM
  #50
Coldo
Coldo's Avatar
The reason it surprises me is that in the gym i use there are very few people who can press 100kg for reps, literally only 4/5 that i know of. On the smith though, i see people with 2 plates a side a bit more often but in reality - depending on smith machine - its only maybe 90-95kg give or take a bit.
Old 08-10-2009, 10:48 AM
  #51
dp1958
dp1958's Avatar
Thumbs up
think you have to include the bar though,20kg...has to be included i know i do.....
Old 08-10-2009, 11:46 AM
  #52
Kieron
Kieron's Avatar
I would say that in the gym I use over 50% of the members do 100Kgs & over. Then again its a small private gym (25 ish members) and its purely a weight lifting gym, no thrills, old machines, spit and sawdust kinda place.
I remember when I first started out @ 16 odd the chap that used to own the gym I went to always said 100Kgs was the benchmark (excuse the pun) and that he was going to have a plaque on the wall with peoples names on that could press 100Kgs convincingly for atleast one rep. At the time I thought that I would never get there and that only one or two people would get their names on it. If doing that now I think it needs to be set at 150 or 200Kgs in my gym. My old training partner used to do over 200Kgs for 3-4 reps. Mind you he is 20+ stone of animal.
The trick is to get strong enough that you don't need to count the bar. Next you'll be adding the weight of your gloves and watch. Only joking, with an Olympic bar its worth including as its 20Kgs odd but for a normal bar without the sleeves on the end I wouldn't bother.
Mine is natural, have been for 2 and a half years odd now. Although my weight fluctuates between 235 + 245lbs depending on training and how much protein I take so I am relatively heavy. I think my body is naturally at its limited and I grow when feeding it but it all drops straight back off when I don't so for me to get bigger means living the full on bodybuilders lifestyle. Something I dont have the time, money or willpower to do.
Old 08-10-2009, 12:17 PM
  #53
kiddie
kiddie's Avatar
I am using tren e & sust so yes I'm cheating!
Old 08-10-2009, 12:41 PM
  #54
Charlie Chalk
Unknown.
I always count the bar, 20kg, is 20kg lol
Old 08-10-2009, 02:05 PM
  #55
dp1958
dp1958's Avatar
my old gym was all in lbs, and to be in the gang you had to press 300 or more,stopped training for around 12yrs and been back for just under 2 yrs my aim would be 3 plates a side thats around 308 lbs if i hit that al be pleased....
Old 08-10-2009, 02:44 PM
  #56
DANO.0161
DANO.0161's Avatar
i use flat bench, but i would say am better on free weights MASSIVE lol
Old 08-10-2009, 03:03 PM
  #57
saul1988
saul1988's Avatar
My goal is 140kg.
if you can manage 8 reps on 100kg surly you should be able to do 115 120kg 1 rep max.
Old 08-10-2009, 03:40 PM
  #58
JamboRS
focus rs 1672
JamboRS's Avatar
im 5ft 5 12 stone and do 100kg with a spotter(includin bar),been training naturally for over 2 year where i was a measely 9 1/2 stone,can 1 max rep 115,again with a spotter
Old 08-10-2009, 06:50 PM
  #59
GribbiN
GribbiN's Avatar
5 sets of 6 reps at 90kg on incline. 110 1 rep.
24years old training 1 year. 12stone
Old 08-10-2009, 09:02 PM
  #60
gibbo frst
gibbo frst's Avatar
with olyimpic bar heavy last set at 120kg inc bar for 8 reps or dumbells normally 8 reps with the 50s.. im 5ft 9 and 15 and half stone been trying the 55s for a while now and can sometimes get 5 out..
loads of polish dudes doing well over 150kg in my gym they are like monsters
Old 09-10-2009, 12:10 PM
  #61
DANO.0161
DANO.0161's Avatar
Wanna see some of the monsters in my gym (Better Bodys In Manchester) they make Arny look small. They come in built like a brick 5hit house & bench 200 Kg + it's crazy weight but i gess u can if u do it for a living. It make ya laugh cos u jus finish ur max set and they warm up on it
Old 09-10-2009, 04:40 PM
  #62
Lee_R21Turbo
Lee_R21Turbo's Avatar
I made the mistake of in my first year of training using the Smiths machine to bench press & I really wished I hadnt now as I think its stopped me from doing much better a couple years on using the olympic bar.
I weigh 78kgs (12.5stone ish) Currently at 85kgs for 8 reps - and slowly moving upwards - would love to crack 100kg next year.
Lee
Old 11-10-2009, 09:10 AM
  #63
B13 JUS
B13 JUS's Avatar
2 years back i was doing 2 reps of 170kg (thats 3x 20kg plates and a 15kg either side) on a flat bench. at the time i was 14 1/2 stone, i could never get the 180kg (4 plates)
never trained for 2 years and went back and built back upto 1 rep of 140kg after 8 weeks.
i was always the smallest looking out of use who trained but the strongest for some reason.
my mates were 16 1/2 and no where near me.
Old 11-10-2009, 01:03 PM
  #64
RUBY123
RUBY123's Avatar
you cant judge much on this topic because you need to no if someones natural or not 100kg natural is good but if on gear 100kg is very poor. and by natural i mean never taken gear because even if you have been off it a while you will still have strength benefits a natural person wont have
me personally 1 or 2 reps on 120kg including the bar and cant seem to get past that and natural
Old 11-10-2009, 02:59 PM
  #65
snedboy
snedboy's Avatar
How you finding the tren e m8? How long you been on it for? Im kinda surprised your on this already as previous posts from you suggest your pretty new to steds BUT even though tren is meant to be the beast of steds i honestly think its overated sides wise etc and is no worse than running higher test deca cycles although never used only going by what friends say
Im eager to try it just dont want bad sides i.e aggression as im a crabbit cunt best of times
Old 11-10-2009, 03:19 PM
  #66
Benni
Ban[B][/B]ned
Benni's Avatar
Any updated pics of you Sned, I wouldn't mind seeing the difference the 'roids has made from the last time?
Benni.
Old 11-10-2009, 03:26 PM
  #67
kiddie
kiddie's Avatar
Sned, the only problem is night sweats. I have been on Tren for nearly 6 weeks, I came off Sust (750mg/wk) which had been 12 weeks and instead of PCT I crused on 125 mg/wk of sust, then back to Sust 750mg, tren e 400mg for a 12 weeker. I was going to use tren ace but the tren e was kicking in pretty soon, and I didn't frontload it as was worried about the sides.
I bloated on test, however not this time with the tren. However I have been eating very clean this time around.
I know it's frowned on by alot of people, but it's my body and I'm the happiest I've ever been with it.
Old 11-10-2009, 05:57 PM
  #68
Benni
Ban[B][/B]ned
Benni's Avatar
Pics, Kiddie, pics!!
Old 11-10-2009, 07:35 PM
  #69
kiddie
kiddie's Avatar
Benni I am open about what I do, but as it's a public (car) forum I won't be posting pictures. For all I know, friends, family or work mates could see and I'd rather keep what I get up to behind closed doors my buisness!
I'll get a shot soon and pm you a before and after pick as long as it's not posted so you can see the difference.
Old 11-10-2009, 09:35 PM
  #70
Alg1k
Alg1k's Avatar
I used to train in the olimpian gym in Coventry with Barington patterson
this chap
http://video.google.co.uk/videosearc...d=0CBAQqwQwAA#
I was 14 stone ripped with a six pack and the best i ever got to was, Flat bench 140 kg for 10 reps with an olympic bar steroid free
I recently went back after 18years off and went straight into 100kg
so im well pleased and hope to get back to my pb !!!
Its going to be a struggle but i shal persever,
Old 11-10-2009, 09:48 PM
  #71
Benni
Ban[B][/B]ned
Benni's Avatar
No worries mate, I completely understand what you are saying.
Benni.
Old 17-10-2009, 02:34 PM
  #72
rstel1
rstel1's Avatar
my max is 150kg's
i do 60kg warmup 15 reps
100kg x 10 130kg x 10 140kg x 8 or 10 if i can then 150 for 3-4 reps
Old 17-10-2009, 02:37 PM
  #73
rstel1
rstel1's Avatar
im the same not the biggest im 5'8 & 14 stone and natural
Old 17-10-2009, 03:05 PM
  #74
iftikhar
iftikhar's Avatar
i've done 1 rep with 184kg 2 years ago was 23stone at the time
Old 17-10-2009, 08:36 PM
  #75
Pete frst
Pete frst's Avatar
theres no doubt about it,theres quite a few big lads on here,christ if we all got together it would look like a scene out of 300....lol
Old 17-10-2009, 09:05 PM
  #76
iftikhar
iftikhar's Avatar
or 300 cossies
Old 17-10-2009, 09:09 PM
  #77
Benni
Ban[B][/B]ned
Benni's Avatar
Fair play mate! That's some strength. I bet you was itching for 200, lol.
Benni.
Old 18-10-2009, 12:59 AM
  #78
iftikhar
iftikhar's Avatar
yeah at the time lol i've lost 6 stone since so probably never now
Old 18-10-2009, 01:07 AM
  #79
Charlie Chalk
Unknown.
I probably could, But I like to do a decent amount, rather than just 1 rep. For me to do 140kg, I want to be able to take it down and lift it back up more than once. I don't see the point in lifting it once and saying you've done '140kg', In my eyes, thats not properly lifting it, Each to their own though.
I've not been to the gym for a while now though, broken hand from a year or so ago giving me jip
Hoping to get it operated on before xmas so I can have a fresh start.
Old 18-10-2009, 05:58 PM
  #80
iftikhar
iftikhar's Avatar
gud luck mate !!!
Quick Reply: How Much Can You Bench Press?
