Mk2 granada; phantom driver, starts by itself - help!
Old Jan 4, 2013 | 02:50 PM
Bisonadam's Avatar
Bisonadam
Default Mk2 granada; phantom driver, starts by itself - help!
Hello.
Mk2 2.8 V6 granada 1982.
Has been fine, started a few days ago and started fine, then starter motor engaged and stayed engaged whilst the engine was running, turned off and removed key and engine stopped then restarted a few seconds later with starter continually running (key fully removed). I have disconnected the battery to stop it. There are 2 wires connected to the positive terminal, a thick red one which I assume is for the spark and a thinner black one which seems to operate the lights etc... Including the starter motor. I have eliminated the ignition barrel by disconnecting the wiring; the the engine starts and runs normally once the thinner black wire is a disconnect from the battery.
Any ideas?
This is my first time on a forum so apologies if this in the wrong section.
Thanks in advance
Adam
Old Jan 4, 2013 | 02:59 PM
Hi and welcome.I would be trying an ignition switch first.It might be badly worn.
Old Jan 4, 2013 | 03:07 PM
Bisonadam's Avatar
Bisonadam
Thanks Glen, I disconnected the ignition switch from the loom and it still starts by itself :-( if the switch was worn, fully disconnecting it would stop power getting to the starter right? I am only a novice mechanic so please tell me if I am wrong
Old Jan 4, 2013 | 03:16 PM
Bisonadam's Avatar
Bisonadam
Old Jan 4, 2013 | 03:47 PM
james kiely's Avatar
james kiely
ignition relay could be crossing itself
Old Jan 4, 2013 | 03:54 PM
Bisonadam's Avatar
Bisonadam
Thanks for the help. Would the ignition relay be in the main fuse box under the bonnet? Anyway I can test the relays operation? Thanks
Old Jan 4, 2013 | 03:59 PM
james kiely
im not sure mate where its situated with ford it could be anywhere but if you do find it open it up and have a look inside to see if it f^&ked
it will get veryhot if it stays on ,so best find it
ps ,thats if it is the problem
might be worth changing the starter /solenoid aswell
Old Jan 4, 2013 | 04:02 PM
Bisonadam's Avatar
Bisonadam
Just had a look at the fuse box and I assume the ignition relay is marked with a lightning bolt in a triangle. I swapped the relay for the horn relay as they are the same and it still starts by itself :-(
Old Jan 4, 2013 | 04:13 PM
james kiely
have alook under your dash and see where the wires go to ,the relay could be under the dash somewhere
Old Jan 4, 2013 | 08:20 PM
martysmartie's Avatar
martysmartie
No, the heavy duty wire will connect to the solenoid, there will also be another wire going to this, this is the switched feed to the starter, I don't think there will be a relay.
The other wire from the battery will feed the whole electrical system, assuming it's OE.
If it were me I would disconnect the said wire from the starter (thinner one) disconnect battery before doing so, if it still starts then you have a problem with the solenoid.
Martin
3drRich
Sep 13, 2015 07:32 PM
Bailes1992
Sep 3, 2015 02:17 PM
RSmark84
20
Aug 24, 2015 02:17 AM
borboyous
Aug 22, 2015 11:17 AM
Red_bull
Aug 9, 2015 08:34 AM
