Cosworth fuel pump problem
Old Nov 24, 2009 | 08:08 PM
hughy's Avatar
hughy
Default Cosworth fuel pump problem
hi, right on my ecos the fuel pump is by passed i hav a switch so i can turn it off, prob is when going to fire car up i turn on the pump the car starts then starts to die so i turn of the pump and it stays started for awhile and if i leave the pump on it WILL die out could it be that the fuel pipes are connected wrong as i had the car totally stripped all summer only been built up in last 2 months? any help be great people, thanks hugh
Old Nov 24, 2009 | 08:14 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
check the fuel pressure, it may be high.
the other option is the fuelling is massivly rich, so when you shut the pump off the pressure in the line drops, so the car runs ok ish untill it runs out of fuel in the line
the feed out of your reg is the return line
Old Nov 24, 2009 | 08:31 PM
hughy's Avatar
hughy
hi james, yes the car is over fuelling big time iv had to get a new L8 green label one this time my old one was red label, do i need to get a lamaba sensor, see im not sure if i hav the correct vacum pipe on the 3 bar map sensor either could that cause it to over fuell badly, cheers hugh ps James could you pm me your email address, as iv'e still not sorted that thanks
Old Nov 24, 2009 | 08:38 PM
JTECH James
Passion for Fords!
what was up with the other ecu?
the red and green label L8s are exactly the same either can run closed loop depending on the chip fitted.
the rich running is your fault, its not fuel pump related at all
Old Nov 24, 2009 | 08:51 PM
hughy's Avatar
hughy
james the old red L8 just wont work for me think it might be down to the inject driver would it be worth fixing? off hand James would you have any idea's of my the cause's of over fuelling? probably loads of things? hugh
Old Nov 24, 2009 | 08:56 PM
JTECH James
Passion for Fords!
fuel pressure,
chip matching engine/injector type
sensor fault/operation
loads of posibilities
Old Nov 24, 2009 | 09:50 PM
hughy's Avatar
hughy
anyone know which vacum pipe i need to use on the map sensor? cheers hugh
Old Nov 24, 2009 | 09:51 PM
JTECH James
Passion for Fords!
any from the plenum, makes no odds which
Old Nov 24, 2009 | 10:14 PM
hughy's Avatar
hughy
thanks James the one on it at the min is not coming from the inlet might have something to do with it over fuelling?
Old Nov 24, 2009 | 10:18 PM
JTECH James
Passion for Fords!
yes! wheres it from lol
if its not reading vaccum at idle it will assume its comming onto boost lol
Old Nov 24, 2009 | 10:28 PM
hughy's Avatar
hughy
lol its coming from a box in the left hand inner wing lol, and i don't need a lamaba snsor if i don't have closed loop,one more thing James could i use 55lb siemen's injectors on a chip that is meant for greens? thanks for your help james, hugh
Old Nov 24, 2009 | 10:44 PM
JTECH James
Passion for Fords!
maybe the carbon canister,
the car will run on the 55s with a greens chip but you will not be able to use it or run it for long periods like it, as the fuelling will be miles out.
if you want a 55s chip give us a ring. we do cracking 55s packages
you dont need a lambda, but its well worth while for the price of a sensor, especialy if you are getting a new chip
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
dlwarrior
Aug 5, 2015 10:19 AM
CabrioTurbo
Aug 1, 2015 11:04 AM
