Pectel monitors/data logging
Old Dec 13, 2010 | 08:56 PM
wrcjim's Avatar
wrcjim
Default Pectel monitors/data logging
This has probably been ask a million times. is it still possible to get data onto the lap top or is the technology to old. any software/data lead available?
when turned on,the monitor comes up with-
PECTEL CONTROL SYSTEMS
INTERNAL RAM-128k
SOFTWARE VERSION 1.32e
ECU LEVEL 8
EPROM NAME-PECTEL T6
LOGGING ON 8CHANNELS
cheeRS JIM
Old Dec 14, 2010 | 07:14 AM
ECU Monitor Enthusiast
That has a wired RS232 port so yes logging is available from that monitor.
I have never seen the soiftware myself but there is an application going around but IIRC it is a DOS application !
Give Mike Rainbird a PM as he will be able to point you in the right direction.
Is your ecu a T6 then ?
Old Dec 14, 2010 | 09:04 AM
wrcjim's Avatar
wrcjim
Yeh the car is on T6.
Dos, sounds like I need to go to a muesium! Al try mike see what he says
Old Dec 14, 2010 | 10:17 AM
Its quite rare to have thsi style monitor on a T6 outside genuine works cars from my experience.
As you have a T6, I reckon you could buy a cheapo net book for about Ł180 to keep in the car and use the proper windows package software supplied with PI DescPro to do what you want.
Old Dec 14, 2010 | 12:53 PM
wrcjim's Avatar
wrcjim
The monitor is in our grpa rally car which is a works spec car ran by mike Taylor developments back in the day.
At least its another option. Will have to look into that.
Old Dec 14, 2010 | 02:37 PM
GARETH T's Avatar
GARETH T
i did own the software, but i cant find it on any of my backups DOH
Old Dec 14, 2010 | 03:17 PM
ian sibbert's Avatar
ian sibbert
Software is 'datalog'...it is DOS based and can only be run on a very old lappy.....i should have a copy if you need one....
Old Dec 14, 2010 | 05:03 PM
wrcjim's Avatar
wrcjim
Hi Ian
Would be interested in a copy if possible. I take it its not possible to run through windows 95/98??
How's the rallying..you get the turbo sorted?
Old Dec 14, 2010 | 07:22 PM
xpackboy's Avatar
xpackboy
hi i have the descpro software for t6 also got the data logging software called dart used to own a pectel t6 monitor myself great piece of kit
Old Dec 14, 2010 | 08:42 PM
wrcjim's Avatar
wrcjim
The software you have,is it for dos or will it run on 95/98 windows?
Old Dec 14, 2010 | 09:21 PM
fraser9764's Avatar
fraser9764
win 95/98 is fine. after that it becomes a problem, although you still might be able to get it to run using DOSBOX or another emmulator.
Old Dec 16, 2010 | 09:08 AM
ian sibbert
Jim,
follow the links pal..
https://lunar.sharefile.com/d/sba05fe5fc89467c8
https://lunar.sharefile.com/d/s0ee921c7b7844548
Datalog will only work with a very old system on Windows 95 it's clunky but still very
useful..
It was an engine failure at Blyton, not done anything since although I am in the process of building 2 new engines...
HTH
Ian
Old Dec 16, 2010 | 10:56 AM
wrcjim's Avatar
wrcjim
Smile
Thanks Ian, al give it go
Old Dec 16, 2010 | 01:06 PM
martysmartie's Avatar
martysmartie
Has anyone tried running on XP? There is a "Compatibility Mode" built into the OS which emulates running on a old OS, I run DOS based applications fine on XP...
Failing this there are DOS emulators available.
Martin
DixieTheKid
11
Jun 6, 2020 11:20 AM
jessie_rs
62
Aug 6, 2019 09:27 PM
jay030787
Sep 25, 2015 01:38 AM
gambo08
Fiesta RS1800/RS Turbo
Sep 16, 2015 08:10 PM
Steve Cooper
Sep 15, 2015 04:39 PM
