Head Gasket Failure?
My FRST hasnt been running that well recently and because I thought it was ignition related I changed the plugs, coil and Distributor cap but this didi not solve the problem. Took the car out for a gental run today and when I got home and checked the oil filler cap I found this.
There is no oil in the header tank and no water in the oil. Is my problem related to the head gasket? I am running a standard Ford RS turbo gasket on a 1905cc block.
Originally Posted by Christian and Beccy
Although its got a Felpro head gasket hasn't it?
The problem I am having is that cylinder number 4 isnt working at about 3K and over. it idles perfectly well and drives normally upto 3k but after that it splutters and sounds like a missfire. I have checked all spark plugs and there is no oil or fuel present. Its not burning any oil at all and there is no smoke of any kind (black or white) leaving the exhaust.
I know I am going to have to take the head off to see whats wrong but for the life of me I can not work this one out.
I am using a Bailey Breather.
for me.
for me.
I was gonna give you a
But couldnt be bothered to click on the "View More Emoticions" Link
try a new lead and plug in there to start with, what colours the plug when you take it out?
Originally Posted by Alvyn
done a compression test?? check the inlet manifold gasket.
I'll check the inlet manifold gasket and see. Now that you mention this as when I usually cover up the free hole on the breather the engine chokes and stalls. Today when I covered up the hole it kept running as normal. Could this be causing the problem then and how would that effect it?
Engine stalls when holes covered up on breather?
strange, is there a vacuum from your inlet to the breather?
Sounds like a sticky or semi burnt out valve to me
Does anyone know what may of caused this? Looks I need like I need a new cam and a set of anti pump lifters.... and an oil change!!
as above get yourself a newman cam, just make sure you blow out all the crap down the oil gallerys and remove the sump and clean it
What would be the difference with the one that is quoted to be only suitable for a ZVH? This one is rated up to 7K.
How do you adjust the followers that will have to be bought together with the cam (quote "8 x EN40B Billet Mechanical Cam Followers Easy Adjustment No Shims") as I'll be fitting it myself and then driving up to NMS to get it mapped.
Mc5506
Oct 5, 2015 09:57 PM
