Escort Rs S2 engine Swap from Italy! Help
Old 19-08-2016, 02:23 PM
akronos
akronos's Avatar
Default Escort Rs S2 engine Swap from Italy! Help
Hello i have destroy my original S2 engine from 1986 , with 200.000 Kilometer.
In my country it's very hard to find a 1.6 cvh turbo engine. Can i swap with another ford engine?
it is not necessary to install a turbo engine , I just even a simple aspirated engine
Old 19-08-2016, 03:55 PM
VEEDUBBED
VEEDUBBED's Avatar
Ciao,
Immagino che l'Italiano lo parli?
Old 19-08-2016, 04:05 PM
akronos
akronos's Avatar
Certo sono Italiano!!
Old 19-08-2016, 05:47 PM
VEEDUBBED
VEEDUBBED's Avatar
Non volevo sembrare una presa per il kulo..
Comunque, vai su Subito.it, ci sono una marea di annunci di rs turbo, vetture complete, motori, cambi etc, etc.. Andrebbe bene anche il motore della fiesta rs turbo, forse ancora piů difficile da trovare pero..
Perché non rifai quello tuo?
Old 19-08-2016, 07:19 PM
rallycross
rallycross's Avatar
Buon giorno
In inglesa a popular choice is ZVH which you can build using cvh and zetec - someone will explain how this can be done.
Can you still find RS turbo in Italia with no rust? In the UK all our cars suffer from rust badly compared to Italian old cars.
Old 19-08-2016, 10:27 PM
akronos
akronos's Avatar
Sei italiano anche tu ? di dove sei? Se hai face ti aggiungerei volentieri vorrei farti qualche domanda
Old 20-08-2016, 07:37 AM
VEEDUBBED
VEEDUBBED's Avatar
Ciao, sorry guys For talking the Italian lingo only..
Basically he has a buggered engine and needs to replace it.
Yes mate, I'm in Rome. I don't use Facebook though..
Ask whatever you want in this forum, that way other users can chime in and help.
Almost forgot, I've emptied my inbox so if you want, use that for messages too.
Cheers-Andrea.
Old 20-08-2016, 09:14 AM
rooos
rooos's Avatar
ciao bel !
da quel che ne so, potresti usar qualunque 1.8 o 2.0 zetec silvertop o blacktop o cvh.
il giro bulloni sul cambio non dovrebbe cambiare, ma non posso parlare per esperienza diretta...
anche i supporti motore dovrebbero andar su dritti.
i primi zetec sono una evoluzione dei cvh, quindi gli attacchi al monoblocco dovrebbero combaciare.
se vuoi tener il volano e kit frizione, forse devi allargar i fori sul volano...
ho dovuto farlo anch'io che sto passando da cvh a silvertop in un sierra...
https://passionford.com/forum/restor...-thinking.html
ti serve solo una donatrice sana con impianto elettrico e centralina.
non buttar via niente del vecchio motore.
hi mate!
as far as i know, you could use any cvh or 1.8 or 2.0 silvertop or blacktop.
the g'box bolt pattern shouldn't change, but i can't talk by direct experience.
also the engine mounts should be a direct fit.
first zetecs are an evolution of the cvhs, so the mechanical block connection are the same...
if you want to keep your flywheel and clutch kit, you may have to drill out the flywheel holes. i had to do the same, while swapping a cvh with a silvertop on my sierra.
...link...
you just need a sane donor with complete loom and ecu.
don't trash any of the old engine...
Old 20-08-2016, 09:30 AM
rooos
rooos's Avatar
Originally Posted by rallycross
Buon giorno
yes, as far as i've seen, up there you have a lot to struggle with rust.
down here you can find rusty cars just because they just weren't loved too much by their owner.
even near the sea or on the alps they just need a little maintenance, (but some fiat and alfa could need more).
if they had been in my hereabouts, a lot of car i've seen in this forum, they would've been just trashed...
very sad seeing lots of interesting car being dumped for just some holes.
but the manpower's hours taxation are too severe in here, so economically they aren't worth the restoring.
and the people mentality awfully follows...
that's what i see...
Jakey46
24-03-2016 05:26 PM
Danielbetty
14-03-2016 10:55 AM
JoeyBoyden
07-03-2016 04:54 PM
The Youth.
01-12-2003 07:23 AM
Quick Reply: Escort Rs S2 engine Swap from Italy! Help
