Cossie Fuel Tank
Old Jan 26, 2006 | 10:14 AM
stonehavencossie's Avatar
stonehavencossie
Default Cossie Fuel Tank
My car (stage 3 saff.) is running lean over 4500 rpm in 4th and 5th gears
STU from MSD thinks it may be my intercooler (has a small hole) or wrong fuel tank ie. non ford item. Trying to rule out the fuel tank.
What i want to know is how do i tell if it is the right one ?
Would the worng tank cause my car to run lean?
The tank is silver. Are ford tanks not black?
Wheres the cheapest place to get a proper ford tank if i need one ?
Old Jan 26, 2006 | 05:18 PM
CosKev3's Avatar
CosKev3
Theres a lot of saphs fitted with pattern part tanks these days,including mine
Can't see any reason for the tank making the car run lean,because the cosworth fuel pump is just gravity fed,not as if there is a swirl pot or lift pump or anything like that in a Ford tank
Pattern tanks are available for £49 delivered to your door,Ford are in the region of £200
Old Jan 26, 2006 | 05:33 PM
stonehavencossie
Guessing thats whats on mine then ?
I was told there was a swirl pot in them
Old Jan 26, 2006 | 05:40 PM
CosKev3's Avatar
CosKev3
Not positive there is'nt m8
But thought gravity fed fuel pumps didn't need a swirl pot
Will have to wait for someone to reply that has cut open both types of tanks to see whats inside
As you said though,they list them for a Cosworth,so should be compatible
Old Jan 27, 2006 | 11:36 PM
CHRIS82's Avatar
CHRIS82
hiya mate,
the only thing inside the fuel tank on a sapphire cosworth is a float to measure how much fuel is left thats how the fuel gauge works. can't see how a non standard fuel tank will make a car run lean.
Old Jan 28, 2006 | 10:06 AM
stonehavencossie
Originally Posted by CHRIS82
hiya mate,
cheers
Old Jan 29, 2006 | 07:21 PM
opposite lock's Avatar
opposite lock
hiya mate,
This seems strange as the rs turbo escort is gravity fed but has a swirl pot. I always thought they also had a swirl pot as i had a mk2 fes tank modified with swirl pot from which i recall the fabricater that did it said itwas 2wd swirl pot. be interested to see what others reckon.
Old Jan 29, 2006 | 07:28 PM
stonehavencossie
Anyone else ?
Old Jan 29, 2006 | 08:02 PM
bigad4x4's Avatar
bigad4x4
Check the power to the fuel pump, is it workin correctly? Are any of the wires corroded?
Old Jan 29, 2006 | 08:12 PM
stonehavencossie
New pump and wires.
I dont think it is the tank causing my 'lean' issue i just wanna rule it out for sure
Old Jan 29, 2006 | 08:13 PM
markk's Avatar
markk
there is a chamber in the tanks
Old Jan 29, 2006 | 09:05 PM
stonehavencossie
meaning ? excuse my stupidness !!
Old Jan 29, 2006 | 09:29 PM
bud-weis's Avatar
bud-weis
Football Cwazy
if Stu says it may be the fuel tank then i'm afraid it may be the fuel tank, does sound more like an intercooler leaking boost but stu knows more than almost anyone on here so i'd trust his experience
Old Jan 29, 2006 | 09:42 PM
stonehavencossie
I do trust stu believe me. Thats why im trying to get to the bottom of it b4 i travel down to see him again.
As stu and others on here have highlighted , it could be the tank but last on the list of possibilities. Hence, i dont wanna spend £200 + on a ford replacement if i dont have to.
As its more likely to be the intercooler ive ordered a new Pro alloy one
Still no nearer to knowing if the tank could be a problem though ?
Old Jan 29, 2006 | 09:46 PM
rsnissan's Avatar
rsnissan
the 3dr tank is deffo gated or chambered as i have just taken mine off and emptied all the petrol out vial the pump out let yet there was still half a gallon of petrol still in there when i hung it up to paint
i would presume the saph is the same too
Old Jan 29, 2006 | 11:04 PM
twitchyrear's Avatar
twitchyrear
mine is stamped FORD
Old Jan 30, 2006 | 12:30 AM
jon@work's Avatar
jon@work
I had an original Ford tank on my car - it looked to be in good condition and wasn't dented, but for some reason there was was an internal blockage preventing the "trap" from filling fast enough so the fuel pump was sucking air through. Replaced it with a pattern tank and problem solved.
Old Jan 30, 2006 | 07:44 AM
foreigneRS's Avatar
foreigneRS
Testing the future
take your tank off, open up the fuel sender thingy and have a look inside. hours job, tops (if the bolts aren't too rusty)
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
15
Oct 7, 2015 03:43 PM
mint_s2
Sep 2, 2015 08:58 AM
ekjim
Aug 17, 2015 08:57 PM
