Zetec cams fitted wrong way round
Old Feb 8, 2010 | 10:10 PM
mastic_man's Avatar
mastic_man
Question Zetec cams fitted wrong way round
Ive picked up a 2.1 zetec silver top unfinished project to place in my cossy managed 1.8 escort gti. I got the build back to my garage to finish off and when I came to time in the cams I noticed they had been fitted the wrong way round. I had already rotated the engine to see if if was turning smoothly and it seemed fine. I am now wondering if any serious damage may have happened to the valves due to the cams being fitted the wrong way round when the engine was rotated?
Can anybody give me some good news or is this likely to be a head strip down?
Old Feb 8, 2010 | 10:24 PM
liam-rst's Avatar
liam-rst
shit happens
if u didnt feel anythin make contact with anythin else all should be fine
Old Feb 8, 2010 | 10:26 PM
botters's Avatar
botters
competant bodger
+1 i agree
Old Feb 8, 2010 | 10:33 PM
BigErn's Avatar
BigErn
Get them in the right way round and turn it over by hand, see how it feels. if it feels ok see if it will run. If it does then Id do a quick compression check to make sure all is good.
Old Feb 8, 2010 | 10:46 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
you will fined it very hard to bend valves buy hand. how have you notised the cams are the wrong way round?? vire the lobes on the inlet cam for the tdc sensor?
Old Feb 9, 2010 | 05:44 AM
mastic_man's Avatar
mastic_man
Originally Posted by clarke5700
you will fined it very hard to bend valves buy hand. how have you noticed the cams are the wrong way round?? vire the lobes on the inlet cam for the tdc sensor?
Yep! Lobe on the cam was on the opposite side to the sensor hole in the cylinder head. engine seems to turn free so fingers crossed there's no damage!
Old Feb 9, 2010 | 09:17 AM
It will be fine, they are very soft cams, so plenty of clearance, so long as dialled in with keyways on rear will be ok no trouble.
Old Feb 10, 2010 | 06:54 PM
mastic_man's Avatar
mastic_man
Do you mean by 'dillaed in' by the cam locking tool in the rear of the cams? Also the cams are Ian Howels profile (UNDER 400BHP type).
Many Thanks!
Old Feb 10, 2010 | 07:45 PM
Yes by locking tool, didn't realise they were uprated jobbies, could be different depends how much lift they have.
Old Feb 13, 2010 | 11:00 AM
mastic_man's Avatar
mastic_man
They are (Inlet) 260/400 and (Exhaust) 240/300 profiles or the FFMZT 1 as advertised on Ians site.
JoeyBoyden
Jan 4, 2024 02:36 PM
Porplus12
Sep 10, 2015 07:20 PM
Red_bull
Aug 9, 2015 08:34 AM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
