moonstone 3dr small update
Old Mar 25, 2012 | 07:50 PM
  #281
cozzy jeff's Avatar
cozzy jeff
get some pics up mate.
Old Mar 25, 2012 | 07:55 PM
  #282
jaimesdna's Avatar
jaimesdna
looks fantastic, top work
Old Mar 27, 2012 | 07:45 PM
  #283
cozzy jeff's Avatar
cozzy jeff
tonights work,spent a little time cleaning the last of my nuts and bolts,hope to have them plated by the weekend.
Old Mar 27, 2012 | 07:46 PM
  #284
Or dear where the fooook do all them go lol.
Old Mar 27, 2012 | 07:48 PM
  #285
rik-rs's Avatar
rik-rs
thats whats left over after hes put it all back together...
Old Mar 27, 2012 | 07:57 PM
  #286
fezzajsy's Avatar
fezzajsy
Old Mar 27, 2012 | 08:04 PM
  #287
cozzy jeff's Avatar
cozzy jeff
glenn they've all been measured and wrote down so hopefully i wont fuck it up.
i hope not.
Old Apr 1, 2012 | 05:42 PM
  #288
cozzy jeff's Avatar
cozzy jeff
todays work,wet flated the engine bay and give it a coat of high build primer.
ran out of paint to finish the drivers side ill get more tommorrow.
had a play with the fuel lines just to check how they will sit incase they needed adjusting before they go for powder coat.
brazings not my strong point,i have checked them for leaks and their fine but think im going to redo them.
Old Apr 1, 2012 | 06:00 PM
  #289
BRAMMER's Avatar
BRAMMER
looking good Jeff
Old Apr 1, 2012 | 06:02 PM
  #290
adam151082's Avatar
adam151082
Hopfully see this driving about soon??
Old Apr 4, 2012 | 08:25 PM
  #291
cozzy jeff's Avatar
cozzy jeff
won't be any time soon mate iv'e alot more money to spent on it to get it road worthy.
anyway picked my bolts up today.
also picked up my alloy steering rack bushes from the post office.
Old Apr 5, 2012 | 08:10 PM
  #292
scottyrs's Avatar
scottyrs
DURHAM RSOC
jeff been months since ive been on here still looking cracking like whats the finishing date then?? lol
Old Apr 5, 2012 | 08:28 PM
  #293
cozzy jeff's Avatar
cozzy jeff
where you been hiding mate?as for the finish date,are they ever finished?your guess is a good as mine
Old Apr 7, 2012 | 08:42 AM
  #294
mick83fulton's Avatar
mick83fulton
Hi, what are u using to clean the diff and gearbox and what paint Did u re paint it with pal? Mick
Old Apr 7, 2012 | 07:04 PM
  #295
cozzy jeff's Avatar
cozzy jeff
the diff and gearbox were degreased then i used a wire wheel on them,etch primed and used a high temperature paint,gearbox not painted yet.
Old Apr 8, 2012 | 04:52 PM
  #296
cozzy jeff's Avatar
cozzy jeff
small update,sorted out the bolts today with a little help from my eight year old daughter(she wrote out some of the stickers).
and stored with the rest till it goes back together.
and a big thank you to karl (special k) for making these for me,even drove up to drop them off for me,top man
Old Apr 10, 2012 | 09:57 PM
  #297
scottyrs's Avatar
scottyrs
DURHAM RSOC
Haven't been hiding mate just didn't really come on here much when I sold the saff lol really want another 1 but still haven't found a job I'm fed up applying for loads but nowt!
Old Apr 10, 2012 | 10:00 PM
  #298
Rsmat's Avatar
Rsmat
Looking good mate..!!!
Old Apr 12, 2012 | 06:28 PM
  #299
cozzy jeff's Avatar
cozzy jeff
got a couple of PAS pipes back from the platers today.
also got this bit and fitted up.
Old Apr 12, 2012 | 06:33 PM
  #300
BRAMMER's Avatar
BRAMMER
Looking Good Jeff
I wanted to ask you a question mate, do you have any tipps about stripping the underside down - mainly around the beam is their any tips when removing - i don't want to remove it whole then struggle to under once off the car how did you dismantle yours?
Old Apr 12, 2012 | 06:47 PM
  #301
cozzy jeff's Avatar
cozzy jeff
i dropped it down in one go,put a jack under the diff then undone the bolts them lowered the jack.
it was a bit of a struggle by myself but once its from under the car you can start stripping the beam.ill deffo need a hand to put it back in so i dont scratch it.
Old Apr 12, 2012 | 06:56 PM
  #302
fezzajsy's Avatar
fezzajsy
Old Apr 12, 2012 | 07:46 PM
  #303
Cossy Mike's Avatar
Cossy Mike
Originally Posted by BRAMMER
Looking Good Jeff
Done that with mine too,
Unbolt prop to rear diff, 4 bolts.
Cut all brake pipes and disconnect handbrake.
Take hub nuts off the car before you drop the axle off, it's easier.
Petrol tank off.
Fuel pump cradle off.
Drive shafts out.
I unbolted the shockers off at the top with a trolley jack underneath then let it down.
Then removed the shocker altogether. (both sides)
Unbolt anti roll bar.
Then take beam plates off, 2 bolts.
stick trolley jack under diff.
Unbolt the bolts that go through the beam mounts.
Then unlbolt the 4 bolts on the diff hanger
Let your jack down
and down she comes.
Old Apr 12, 2012 | 07:52 PM
  #304
Cossy Mike's Avatar
Cossy Mike
Forgot to ask Jeff.....I forgot to put a load of stuff in for zinc last year after getting most of it done.
That place down Hebburn, does he do the Zinc with the Yellow passivate as well as the Blue/clear like yours?
Old Apr 12, 2012 | 08:00 PM
  #305
cozzy jeff's Avatar
cozzy jeff
i think thats what i asked for mike mine does have a yellow/blue finish to it,heres the web address and contact number give them a call.01914839213
http://www.electroplaters.org.uk/
Old Apr 12, 2012 | 08:23 PM
  #306
Cossy Mike's Avatar
Cossy Mike
I put a load of stuff in to a company down Middlesbrough who where very good but they are very very slow.
It took 3-4 weeks to get my stuff back. Now after starting to put bits back together there's loads I've forgotten to put in.
The bracket on the pic is Zinc with Yellow passivate, I was after the same thing, I'll give him a ring and ask him,
Thanks Jeff
Old Apr 12, 2012 | 09:51 PM
  #307
BRAMMER's Avatar
BRAMMER
Petrol tank off.
Drive shafts out.
Let your jack down
and down she comes.
Cheers for that, I'm doing mine on a 2 post ramp so should be easy then
Old Apr 15, 2012 | 05:46 PM
  #308
cozzy jeff's Avatar
cozzy jeff
cleaned up a couple of items today.
cleaned and fitted the sunroof drain rubbers.
collected my rear beam which has been stored at my sisters since be powdercoated going to try and fit this up tommorrow.
Old Apr 15, 2012 | 06:25 PM
  #309
BRAMMER's Avatar
BRAMMER
Glad your documenting all this Jeff as i can copy what you are doing, kind of
Old May 16, 2012 | 07:11 PM
  #310
cozzy jeff's Avatar
cozzy jeff
small update for today:
had my -6 fittings brazed onto the fuel lines today,ready for powdercoat now.
also rubbed down the boot floor and etch primed it.
fitted up the rear beam,i know it needs to come back off to fit the trailing arms but was sick of tripping over it,heres some randoms.
also a pic of the cover i build for the car over the bank holiday weekend.
Old May 16, 2012 | 08:00 PM
  #311
jaimesdna's Avatar
jaimesdna
looks fantastic
Old May 17, 2012 | 04:19 PM
  #312
fezzajsy's Avatar
fezzajsy
Old May 17, 2012 | 07:34 PM
  #313
Top work matey Karl is mint at fabricating parts.How much were the brake disc backing plates.
Old May 17, 2012 | 07:36 PM
  #314
What are cossies like with these solid bushes in the rear axle??do they handle better???
Old May 19, 2012 | 04:25 PM
  #315
cozzy jeff's Avatar
cozzy jeff
glenn your best off contacting karl directly as the price varies,depends if you want them powder coated or not,these ones are bigger than the standard ones so if you decide to fit 300mm rear discs in the future they will fit no problem
glenn ive never driven the car with these bushes in ,ive only drove the car for 500 miles home from buying the car two years ago.
i bought the bushes from B13 JUS he told me he could'nt tell the difference between these and poly bushes
Old May 26, 2012 | 04:39 PM
  #316
GINGExR2 T's Avatar
GINGExR2 T
Wicked job your doing there mate, can i ask you a question/favour, You couldn't measure your new dust guards for me could you???? please
I've just bought a new pair NOS ones off ebay but i'm sure there smaller than my originals. Looking at one of your earlier pics, it looks like the disc sit out from the actual dust guard. Can you confirm this or have any other pics i could have a look at.
Ginger
Old May 26, 2012 | 08:24 PM
  #317
cozzy jeff's Avatar
cozzy jeff
hi mate i'll measure my new guards for you tommorrow,i cant measure the original ones for you,these where thrown out after they where shot blasted because there was not much left of them,but heres a couple of pics of the originals before i removed them from the car.
Old May 26, 2012 | 09:11 PM
  #318
special-K's Avatar
special-K
Ginger
now ginger the discs are supposed to sit out matey its for cooling the sheilds you will have bought of ebay will be XR4I 1's which are smaller than cosworth sheilds hope this helps....K
jeff your doing a great job with the car keep it up....K
Old May 26, 2012 | 09:40 PM
  #319
cozzy jeff's Avatar
cozzy jeff
thanks karl,hope alls well with you matey,you should get on here more often.
Old May 27, 2012 | 08:08 PM
  #320
cozzy jeff's Avatar
cozzy jeff
[QUOTE=GINGExR2 T;5927023].
I've just bought a new pair NOS ones off ebay but i'm sure there smaller than my originals. Ginger
hi ginger as promised,the dust guards that karl made me measure 310mm.
