moonstone 3dr small update
Old May 27, 2012 | 09:07 PM
  #321
Originally Posted by rik-rs
thats whats left over after hes put it all back together...
Ha ha fookin brill...
Old May 30, 2012 | 04:31 PM
  #322
cozzy jeff's Avatar
cozzy jeff
picked up my fuel pump today(thanks jay),also got -10 and -6 fittings from torques,has anyone else used these?there seems to be quite a large gap between the -6 fitting and the pump,i know i can use the standard fitting or cut this one down but just thought id ask.
Old May 30, 2012 | 07:51 PM
  #323
special-K's Avatar
special-K
yeh it should have a copper washer in there jeff to seal it...K
Old May 30, 2012 | 08:08 PM
  #324
cozzy jeff's Avatar
cozzy jeff
karl i know they should have washers in there mate but in the pics that fitting is screwed right in which would mean id have to use a really thick copper washer to make it seal.
Old May 30, 2012 | 08:43 PM
  #325
gjh's Avatar
gjh
Making great progress. Going to be a stunner when its on the road.
Old May 30, 2012 | 09:00 PM
  #326
SMILER258's Avatar
SMILER258
This is stunning, quality work. How did you clean the bolts btw?
Old May 30, 2012 | 09:06 PM
  #327
ranutter's Avatar
ranutter
this is a great thread and a credit to you.inspires me to do my own. keep up the excellent work
Old May 31, 2012 | 04:06 PM
  #328
cozzy jeff's Avatar
cozzy jeff
not this year mate,i would like it painted before it goes back on the road,i would be happy to get it back on its wheels and maybe the engine bay painted this year.
the nuts and bolts are put in a vice and cleaned with a wire wheel,then zinc plated
thank you
Old May 31, 2012 | 05:23 PM
  #329
BRAMMER's Avatar
BRAMMER
Can't help regarding the AN6 as i have left the original banjo/pipe jobby on mine but it looks like you will just have to get a correct thickness copper washer Jeff - i'm sure you'll find one - looks like 3 or 4mm
Old May 31, 2012 | 05:32 PM
  #330
cozzy jeff's Avatar
cozzy jeff
leaving the original banjo in is an option i was looking at them from burtons this morning,mines been cleaned up for zinc plating but mite just buy a new one.
Old Jun 3, 2012 | 06:50 PM
  #331
cozzy jeff's Avatar
cozzy jeff
not much of an update until my trailing arm bushes turn up but heres what little work ive done this morning.
bought a 044 pump off (JAY) so thought id trial fit it into the cradle.
cleaned up and painted the steel mounts for the rubber bushes.
also painted the gearbox mount
also won this off ebay a couple of weeks back.
so i put it in the collection.
thats it for now hopefully a bigger update when my bushes turn up.
Old Jun 3, 2012 | 10:04 PM
  #332
BRAMMER's Avatar
BRAMMER
Looks a tidy cradle Jeff - how shit are those rubber mounts on the pump side and Ford NLA - does yours move around a little?
Couple of little bit's i was told the pipe went under the cradle and have you fitted a copper washer on the AN10 fitting?
Old Jun 3, 2012 | 11:28 PM
  #333
Fantastic job
Old Jun 4, 2012 | 08:14 AM
  #334
Rsmat's Avatar
Rsmat
Jeff fuel pipe wants changing to run on the outside mate... I'll dig a pic out for you mate.
Old Jun 4, 2012 | 08:17 AM
  #335
Rsmat's Avatar
Rsmat
Old Jun 4, 2012 | 09:05 AM
  #336
cozzy jeff's Avatar
cozzy jeff
Originally Posted by Twins
Fantastic job
cheers twins
yeah the rubbers are shit mate,i do get movement in the pump,ive bent the craddle to take up some of the slack but still have a little movement.
ill change to route of the fuel pipe,ive taken a look at some photos ive taken and you are right,chris i need new copper washers all round mate there on the to do list.
matt i was just looking through some pics when i noticed your post,thanks for the pics,looks to me the steel caps are missing from your rubber mounts in the first pic mate.
Old Jun 4, 2012 | 09:15 AM
  #337
Rsmat's Avatar
Rsmat
That's all I got in the poly bush kit...I poly bushed the fuel cradle mate.
Old Jun 6, 2012 | 07:35 PM
  #338
cozzy jeff's Avatar
cozzy jeff
picked up my hubs from mb motorsport today.
Old Jun 8, 2012 | 03:22 PM
  #339
cozzy jeff's Avatar
cozzy jeff
the bank account took a hit this week,great service from GGR with next day delivery.
trailing arms and bushes are at mb motorsport being pressed in should have them back monday.
Old Jun 8, 2012 | 03:40 PM
  #340
Rsmat's Avatar
Rsmat
Very nice bushes mate..
Old Jun 8, 2012 | 07:27 PM
  #341
BRAMMER's Avatar
BRAMMER
So much money for something that is hidden away - but they are what you need Jeff, did they send you the dust seals too??
Hubs look great
Old Jun 8, 2012 | 07:29 PM
  #342
Cossy Mike's Avatar
Cossy Mike
Ł320?? Fook that
Very nice though
Old Jun 8, 2012 | 07:32 PM
  #343
Cossy Mike's Avatar
Cossy Mike
I ordered Ł280 worth of stuff from GGR Wednesday, still yet to turn up :/
Old Jun 8, 2012 | 09:21 PM
  #344
cozzy jeff's Avatar
cozzy jeff
Hubs look great
no mate no dust seals,take it i need the ones you bought for yours?
Old Jun 8, 2012 | 09:30 PM
  #345
whizzisat114's Avatar
whizzisat114
Can you just take a few mm off the fitting so it screws in more?
Great build, real credit to you
Old Jun 8, 2012 | 09:38 PM
  #346
cozzy jeff's Avatar
cozzy jeff
thank you,yes i could have done that but ive decided to re-use the original link pipe from the pump to filter instead of using braided hose,im waiting on a new non return valve from burtons.
Old Jun 8, 2012 | 09:54 PM
  #347
BRAMMER's Avatar
BRAMMER
Are they genuine Ford items as they look different to the originals mate - your look like they are sealed - i could be wrong but it doesn't look like you could fit a dust seal like i did
Old Jun 8, 2012 | 10:04 PM
  #348
cozzy jeff's Avatar
cozzy jeff
no mate not geniune ford,didnt GGR have these made to there own spec?ill give a call tommorrow and ask about it.
Old Jun 12, 2012 | 06:38 PM
  #349
cozzy jeff's Avatar
cozzy jeff
got my trailing arms back today,also had confirmation from ggr that the bearings contain dust seals
also cleaned up my driveshaft bolts ready for paint.
Old Jun 12, 2012 | 06:43 PM
  #350
whizzisat114
Bearings look a nice part
Were they pressed in?
gonna be a proper clean car after all this work a real credit to you
Old Jun 12, 2012 | 07:16 PM
  #351
cozzy jeff's Avatar
cozzy jeff
cheers,yeah they where pressed in.
Old Jun 30, 2012 | 09:20 AM
  #352
cozzy jeff's Avatar
cozzy jeff
very little happened this month,due to weather,money and a holiday,i have got round to fitting the trailing arms,diff and rear coil overs(pics to follow).
also painted the driveshaft bolts.
cleaned up ready for etch.
etch primed.
and a couple of coats wedgewood blue.
also had a polly diff mount delivered from MSD going to fit this sunday if weathers ok.
Old Jul 1, 2012 | 08:32 AM
  #353
Moonstone Mart's Avatar
Moonstone Mart
Great resto thread.
Mart.
Old Jul 1, 2012 | 09:50 AM
  #354
Minirotty's Avatar
Minirotty
Lucifer II - 666
Great thread!
Proves driveway builds can be just as good as any other, top work.
Old Jul 1, 2012 | 11:18 AM
  #355
ossie cossie's Avatar
ossie cossie
Awesome rebuild thread, great work, keep it up.
Old Jul 1, 2012 | 05:01 PM
  #356
fezzajsy's Avatar
fezzajsy
looking good
Old Jul 1, 2012 | 05:02 PM
  #357
BRAMMER's Avatar
BRAMMER
Looking really good Jeff, its getting there now
Old Jul 1, 2012 | 06:42 PM
  #358
cozzy jeff's Avatar
cozzy jeff
thanks for the comments guys,im really happy with todays work,heres some pics for you.
after fitting the diff and mount i turned to the front of the car.
Old Jul 1, 2012 | 06:48 PM
  #359
Cossy Mike's Avatar
Cossy Mike
Looking mint Jeff, how did you find the front anit-roll bar to re fit?
I've been told it's a nightmare to put back on....
Old Jul 1, 2012 | 06:55 PM
  #360
cozzy jeff's Avatar
cozzy jeff
yeah mate was a pain in the arse doing it by myself,i gave up and waited till my dad came in from the club,hes been a great help today even though he was half cut.
