moonstone 3dr small update
Old Jul 1, 2012 | 07:10 PM
  #361
Cossy Mike's Avatar
Cossy Mike
Originally Posted by cozzy jeff
yeah mate was a pain in the arse doing it by myself,i gave up and waited till my dad came in from the club,hes been a great help today even though he was half cut.
Sounds like me
I got offered loads of help and when I asked.....they were busy.
It's a good feeling though when you step back and can say you've done it ALL yourself
Old Jul 1, 2012 | 09:45 PM
  #362
james kiely's Avatar
james kiely
fantastic work jeff ,
Old Jul 2, 2012 | 02:37 PM
  #363
BRAMMER's Avatar
BRAMMER
Ratchet strap if your doing it yourself mate Jeff where did you get the SD sticker from for the diff?
Old Jul 2, 2012 | 03:10 PM
  #364
Cossy Mike's Avatar
Cossy Mike
PM Billiam of RSOC BB he does them. There printed on paper labels so need lacquer over them or they'll fade when wet.
Print your own I've got the scans on my computer at home if you want to print your own off?
Old Jul 2, 2012 | 03:37 PM
  #365
cozzy jeff's Avatar
cozzy jeff
rs matt very kindly sent me one of his.
Old Jul 2, 2012 | 05:00 PM
  #366
gjh's Avatar
gjh
Just read this thread start to finish, top work
Old Jul 2, 2012 | 05:09 PM
  #367
BRAMMER's Avatar
BRAMMER
pm sent Mike
Old Jul 22, 2012 | 05:57 PM
  #368
cozzy jeff's Avatar
cozzy jeff
started on the hydraulic clutch today,pedal box was already off so no issues there.
first job is to remove the clutch pedal.
then cut off the pedal stop.
measure 50mm from the centre hole.
use a 8mm drill and drill right through the pedal.
but the pedals back together and fitted to the car,i marked where i needed on the bulk head and drilled a pilot hole.this is as far as i got as i need a hole cutter to cut the main hole out.
also done the steering bearing mod.
just need some more washers and lock nuts and thats another job done.
Old Jul 22, 2012 | 07:08 PM
  #369
peteh's Avatar
peteh
ooo ill be watching this like a hawk, what master cylinder did you use?
Old Jul 22, 2012 | 07:45 PM
  #370
Jack and the Beanstalk's Avatar
I am also intrigued on this hydraulic clutch mod, I wanna do the same to mine, but im not 100% sure how to do it.
I saw on earlier pics of what appears to be some hydraulic fitting at the back of the clutch bearing on the drive shaft. Is this part of the mod as well?
Awsome job on the restoration so far. Looks flippen brilliant. Keep on going.
Old Jul 22, 2012 | 08:21 PM
  #371
cozzy jeff's Avatar
cozzy jeff
i used this one from burtons,im not 100% sure its the correct one to use but at least i can go up or down on the bore size if i need to,wont find out untill its all back together.
http://www.ebay.co.uk/itm/1506255185...84.m1439.l2649
yes the centre push bearing in the gearbox is part of the mod too.
if you want to do a hydraulic conversion on your car you could buy a similar kit from martin at reyland.
Old Jul 22, 2012 | 08:29 PM
  #372
peteh's Avatar
peteh
cheers mate, ill look into it, also how did you know where to go through the bulk head?
i found reyland thoroughly rude to talk to when i rang him about this conversion, he'd sell just the parts i need which is basically the master cylinder and a rose joint to connect it to pedal and wanted Ł160!!!
Old Jul 29, 2012 | 08:49 PM
  #373
cozzy jeff's Avatar
cozzy jeff
continued work on the hydraulic clutch today,looks like everything worked out ok.
35mm hole punch for the centre.
which left this.
also made up a back plate the same way.
job done.
Old Jul 29, 2012 | 08:53 PM
  #374
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Nice work.
Old Jul 29, 2012 | 09:29 PM
  #375
fezzajsy's Avatar
fezzajsy
Old Aug 18, 2012 | 02:10 PM
  #376
cozzy jeff's Avatar
cozzy jeff
just a small update:
i was given some heat proof matting from saphcosmike(cheers mate)wich was left over from his car.mines no where near ready for this but thought id get it ready for when it is.
firstly made a template:
which resulted in this:
i know it needs some fibres trimmed around the edges but this will done before its glued to the car.
i re-fitted the abs block and brake master cylinder to check to make sure the brake lines are going to clear the clutch master cylinder,which they did after bending slightly.brake lines now ready for powdercoat.
also picked up some pwdercoated parts on friday.
Old Aug 18, 2012 | 04:40 PM
  #377
gjh's Avatar
gjh
Top work
Old Aug 18, 2012 | 05:29 PM
  #378
whizzisat114's Avatar
whizzisat114
Great work
Old Aug 18, 2012 | 05:52 PM
  #379
Cossy Mike's Avatar
Cossy Mike
Looking well Jeff, cv's and the driveshafts look like they turned out really well
Old Aug 18, 2012 | 06:14 PM
  #380
BRAMMER's Avatar
BRAMMER
Great update Jeff - yours is one of those builds like Gav's when every single part gets referb'd or replaced - i can't wait to see it complete i will pop over one day and have a nosey mate
Old Aug 18, 2012 | 06:15 PM
  #381
cozzy jeff's Avatar
cozzy jeff
Yes mate really happy with them,hopfully get the shafts build up tommorrow
Old Aug 18, 2012 | 07:59 PM
  #382
fezzajsy's Avatar
fezzajsy
coming alomg nicely
Old Aug 18, 2012 | 08:23 PM
  #383
cozzy jeff's Avatar
cozzy jeff
thanks chris your welcome to come round anytime you want,fetch that alloy with you
Originally Posted by fezzajsy
coming alomg nicely
thank mate.
Old Aug 20, 2012 | 04:19 AM
  #384
borjaman34's Avatar
borjaman34
Great JOB!!
Come ON!!!
Old Aug 20, 2012 | 03:58 PM
  #385
cozzy jeff's Avatar
cozzy jeff
well after pulling out the last of my hair the driveshafts are back together,just waiting for some better straps coming.
more pics when there fitted to the car.
Old Sep 22, 2012 | 09:14 PM
  #386
cozzy jeff's Avatar
cozzy jeff
over due update:drive shafts have been fitted,i have new bolts to go on but need zinc'd first.
abs block repainted:
also recieved my diff oil from graham @ car parts express and magnetic fill plug from MSD
just waiting for my rear anti-roll bar bushes to turn up then thats another job done.
Old Sep 22, 2012 | 09:35 PM
  #387
Cossy Mike's Avatar
Cossy Mike
I'm liking the diff plug, might just invest in one of these myself
Old Sep 22, 2012 | 09:56 PM
  #388
cozzy jeff's Avatar
cozzy jeff
mike the magnet really is strong much better than the standard one.
Old Sep 23, 2012 | 01:23 PM
  #389
fezzajsy's Avatar
fezzajsy
coming along nicely
Old Sep 23, 2012 | 04:54 PM
  #390
gjh's Avatar
gjh
Great work!
Old Sep 23, 2012 | 07:40 PM
  #391
BRAMMER's Avatar
BRAMMER
Looking good Jeff - will the car be finished before the start of the show season in 2013?
Old Sep 23, 2012 | 07:55 PM
  #392
lowman's Avatar
lowman
this is candy for my eyes!!cheers from norway
Old Sep 23, 2012 | 08:52 PM
  #393
dingla rs's Avatar
dingla rs
were did the bearing come from for steering colume mate intrested in one for mine as rubber a bit stiff in mine .all looking good btw
Old Sep 23, 2012 | 09:56 PM
  #394
BRAMMER's Avatar
BRAMMER
Just quoted from my thread mate - all the info is their what you need and a 25mm bore - the link should take you right there
I'm going to have a look at the column bush this week and have been contemplating using a bearing style fitting that was brought up in another thread on here the other month
The parts
http://www.ebay.co.uk/itm/1306862969...84.m1438.l2649
http://www.ebay.co.uk/itm/3706300511...84.m1438.l2649
The conversion thread
http://www.sierra-freunde-deutschlan...chlager#267246
Has anyone gone down this route as it looks more like a fix and forget option?
Old Sep 24, 2012 | 03:36 PM
  #395
cozzy jeff's Avatar
cozzy jeff
i would like to think so it mate only doing bits and pieces for the rest of the year,hopefully get it painted next year,got do some saving
cheeers mate
cheers chris saved me the job
Old Oct 28, 2012 | 06:40 PM
  #396
cozzy jeff's Avatar
cozzy jeff
heres a couple of pics of work ive done recently:
anti-roll bar bushes and droplinks fitted.
handbrake cable fitted.
Old Oct 28, 2012 | 06:49 PM
  #397
cozzy jeff's Avatar
cozzy jeff
had my bits and pieces back from be zinc'ed(thanks again to saphcosmike)
brand new driveshaft bolts(thanks again mike)
driveshaft bolts now fitted.
Old Oct 28, 2012 | 07:06 PM
  #398
Cossy Mike's Avatar
Cossy Mike
Old Oct 28, 2012 | 09:10 PM
  #399
gjh's Avatar
gjh
It looks stunning underneath. Top work.
Old Oct 29, 2012 | 07:16 AM
  #400
BRAMMER's Avatar
BRAMMER
Looks stunning, has Mike got a yellow zinc kit?
