moonstone 3dr small update
Old Jan 25, 2014 | 07:56 PM
  #641
cozzy jeff's Avatar
cozzy jeff
Originally Posted by BRAMMER
So you got the clutch, did you get the full kit or plate and standard cover?
just got the plate mate and mike gave me his standard cover,it'll do me for now.
Originally Posted by cossie891
Jeff car looks the bollox mate one question tho any idea when I can get a pair of inner glass rubbers for the front and bk screen
I re-used mine mate,im sure the window fitter told me he could get some of the seals but I cant remember which ones,i could ask if you like,do you just require the two inner seals?
Originally Posted by Jay,
Looking like a real top job
Is there a way of lining up the mast cylinder for the clutch peddle Jeff ?
pm on its way jay
Old Jan 25, 2014 | 10:11 PM
  #642
cossie891's Avatar
cossie891
Yes mate just the inners the window guy cut them up taking the glass out and said he can't get any more
Old Jan 26, 2014 | 06:06 PM
  #643
cozzy jeff's Avatar
cozzy jeff
today update:
got the flywheel fitted and torqued up:
couple of pics off last weekend,saphcos mike popped round and done the last brakeline that runs across the bulkhead,just need painted then the engine can be dropped back in,thanks for your help with these mate
also found time to waxoyl the front crossmember and sills today hopfully help preserve it.
Old Jan 26, 2014 | 06:10 PM
  #644
cossie891's Avatar
cossie891
Looking the nuts mate
Old Jan 26, 2014 | 06:48 PM
  #645
scottyrs's Avatar
scottyrs
DURHAM RSOC
Can't wait to see this finished
Old Jan 26, 2014 | 06:49 PM
  #646
scottyrs's Avatar
scottyrs
DURHAM RSOC
Can't wait to see this finished mate
Old Jan 26, 2014 | 06:54 PM
  #647
cozzy jeff's Avatar
cozzy jeff
cheers mate
you must be so excited you said it twice
Old Jan 26, 2014 | 07:08 PM
  #648
BRAMMER's Avatar
BRAMMER
Does look mint in that bay, so virtually ready for the motor to drop in
Old Jan 26, 2014 | 07:43 PM
  #649
mk2cossy's Avatar
mk2cossy
Looking very well mate.
Old Feb 2, 2014 | 06:02 PM
  #650
cozzy jeff's Avatar
cozzy jeff
couple of little jobs today:etch primed the brake lines,i took one of the original brake lines to my paint supplier on Friday to match up the original colour,and we decided on nato green,this will be applied as soon as we get some decent weather.
after looking over a few threads regarding the hydraulic clutch conversion it seems common sense to put a spot weld on the bolts to make changing the master cylinder easier at a later date.
trimmed the carpet around the steering bearing.
abs ecu back in place.
not the biggest of jobs but progress all the same.
Old Feb 2, 2014 | 06:18 PM
  #651
BRAMMER's Avatar
BRAMMER
Looking good pal, i'm welding my bolts to the plate tomorrow - did you manage to get the pedal box in and see what needs to be done with the clutch pedal?
Old Feb 2, 2014 | 06:19 PM
  #652
siscossie's Avatar
siscossie
3-door moonstone
Coming on nicely fela looking great
Old Feb 2, 2014 | 06:34 PM
  #653
cozzy jeff's Avatar
cozzy jeff
looks like I needs a trim mate to get the full travel.
Old Feb 2, 2014 | 07:43 PM
  #654
Looking good Jeff.
Old Feb 3, 2014 | 06:45 AM
  #655
cozzy jeff's Avatar
cozzy jeff
Originally Posted by Glenn_
Looking good Jeff.
Cheers lads.
Old Mar 9, 2014 | 07:37 PM
  #656
cozzy jeff's Avatar
cozzy jeff
small update:not done much on the car recently but been doing bits and pieces to the engine,still not got round to painting the brake lines mainly due to the weather and motivation
new rear crank seal and spigot bearing fitted along with the clutch:
new exhaust gaskets with new nuts and washers:
exhaust manifold fitted:
when I bought the car the turbo was running a restrictor my plan was always to replace the front housing with a standard one,so I won this one off ebay a few years ago so decided to fit it today:
guess what?it does fit but locks the blades so looks like im stuck with the original housing for now
new studs and nuts the exhaust housing.Name:  20140309_144424_zpsb67280c0.jpg
shot blasted the front housing:
fitted the actuator/bracket and oil return:
home made exhaust flange:
restrictor fitted:
that's it for now hopefully have the engine in in a couple of weeks.
Old Mar 9, 2014 | 07:44 PM
  #657
Looking good matey. Ive got no motivation either.
Old Mar 23, 2014 | 07:54 PM
  #658
cozzy jeff's Avatar
cozzy jeff
found some today glenn:
weathers been good today so thought id get these brake lines painted:
that's another job I wasn't looking forward to doing but it turned out well.
also got some zinc back so I could but some bits back on the car/engine:
also had my roose hoses and powerflex bushes turn up.
looking at putting engine and box back in soon,that will be another milestone reached
Old Mar 23, 2014 | 08:09 PM
  #659
Wow thats looking mint. Ive been off 4 days this week and I couldnt be arsed to do any work on the cossie lol.
Old Mar 23, 2014 | 08:11 PM
  #660
cozziegav's Avatar
cozziegav
restrictor fitted:
Hi there...loving the build
Very interesting for me plus I can get some tips from you.
You are also motivating me to do something with mine.
Is the other t34 housing surplus? Nudge wink.?
Old Mar 23, 2014 | 08:23 PM
  #661
cozzy jeff's Avatar
cozzy jeff
could well be if the price is right,will have to renew me gold membership aswell.
Old Mar 23, 2014 | 08:44 PM
  #662
cozziegav's Avatar
cozziegav
Tell me what the right price is "cj"
What's the gold membership for?
Old Mar 23, 2014 | 08:47 PM
  #663
Jay,'s Avatar
Jay,
Sponsor
Just awesome Jeff just awesome
Old Mar 23, 2014 | 09:06 PM
  #664
cozzy jeff's Avatar
cozzy jeff
to sell parts on here you need to purchase a gold membership.
cheers jay.
Old Mar 23, 2014 | 09:35 PM
  #665
boy-racer-1's Avatar
boy-racer-1
everything on this car looks amazing, certainly a top job id be too scared to push the car when its done let alone drive it after all the money and hard work thats gone into it
Old Mar 24, 2014 | 06:42 AM
  #666
gingerturbo's Avatar
gingerturbo
The annoying ginger guy
Looking better and better every day
Old Mar 24, 2014 | 08:51 AM
  #667
Mr RS500's Avatar
Mr RS500
simply superb mate
Old Mar 24, 2014 | 09:21 AM
  #668
I wish people wouldn't quote all the f#$ king pictures again lol.
Old Mar 24, 2014 | 08:18 PM
  #669
nicodinho's Avatar
Winters over time to work
Ahhh remains the best thread on the site. Have taken the winter off with not a thought for my pain in the arse... err i mean project but with the longer days I will drag it out.
Thanks for the inspiration
Old Mar 24, 2014 | 08:57 PM
  #670
siscossie's Avatar
siscossie
3-door moonstone
Looking great mate top stuff
Old Mar 24, 2014 | 09:18 PM
  #671
cozzy jeff's Avatar
cozzy jeff
I know glenn I hate it also but saying its on my thread ill let it slide
Originally Posted by North Yorks RS Spares
simply superb mate
cheers lads,thanks your very kind words.
Old Mar 24, 2014 | 09:25 PM
  #672
cozziegav's Avatar
cozziegav
Sorry mate
That was me
I'm just starting to sus it out...
Got a turbo housing out of it anyway lol
Old Mar 24, 2014 | 09:58 PM
  #673
nice_head's Avatar
nice_head
Looking great jeff. Can't wait to see my old car back on the road
Can't believe it's nearly 4 years ago that I sold it to you
Old Mar 24, 2014 | 10:01 PM
  #674
cozzy jeff's Avatar
cozzy jeff
cheers jon,yeah four very long years next month lol.
Old Mar 25, 2014 | 08:03 PM
  #675
cozzy jeff's Avatar
cozzy jeff
spent and hour or so on the car tonight got the brake lines fitted up:
also fitted the washer bottle and power steering tank bracket,using rivnuts instead of screws.
Old Mar 25, 2014 | 08:58 PM
  #676
BRAMMER's Avatar
BRAMMER
Looking good mate, so whats left to do before you drop the motor in?
Old Mar 25, 2014 | 09:10 PM
  #677
cozzy jeff's Avatar
cozzy jeff
not much mate,put the new loom through the bulkhead and it pretty much ready to drop in.
Old Mar 26, 2014 | 07:35 PM
  #678
Sorry mate
That was me
No bother matey lol. Cool news about the turbo housing.
Old Mar 30, 2014 | 06:02 PM
  #679
cozzy jeff's Avatar
cozzy jeff
fitted the map sensor today
decided on the alloy one.
Old Apr 11, 2014 | 08:05 PM
  #680
cozzy jeff's Avatar
cozzy jeff
ive done a couple of jobs over the last few days so id thought id share the progress.
fitted the fuel lines:
fitted the bulk head panel:
fitted the ignition amps+bracket:
and the clutch fluid reservoir:
and after nearly four years the engine and gearbox are back together,hopfully will be back in the car sometime over the bank holiday weekend.
