moonstone 3dr small update
thanks for the kind word lads:made another gasket for the steering bearing as i wasnt happy with the paper one:
and fitted along with the master cylinder for the clutch:
fitted new vapour barrier to the doors and re-fitted the door cards
gear lever surround and new gaitor fitted and a set of very good side repeaters kindly donated by saphcos mike
also had the exhaust manifold blasted,came out nice i think.
I only used a strengthening plate for master cylinder not the bearing, ill knock you up one at the weekend and get back to you.
Me too mate its been a long time coming.
not a lot to be honest mate,mikes done a couple more brake pipes for me since I last up-dated,only one more to do,they'll look nice once painted up and clipped in.
the cars back on axle stands,needs a good clean under there,still covered in dust from the body shop.
and as stephen says below ive dropped off the steering rack to be re-furbished which should be back soon.
a day off how did you manage that,i thought they where slave drivers down there lol!
I hope so adam all depends on the money really.
Dont throw out your rack mate just take it to your local motorists discount store and they wil sort the re-furb for you.
Al have a look as I' still should still have the colour for the bolts too (blue) if it's there your welcome to it if you want it ?
http://www.ebay.co.uk/itm/UCFL-Metri...item4aaaf9d70f
select the 25mm one from the drop down menu.
no problem mate.
thought id do a small update:
got the steering rack back a couple of weeks ago but wasn't 100% with the way they slapped the paint on so stripped it all off and re-done it.
how it was returned to me,with new hard pipes fitted
rubbed down:
etch primed:
and painted:
also changed the rear crank seal and spigot bearing:
flywheel ready to be bolted on along with new ap six paddle:
rubbed down:
etch primed:
and painted:
absolutely stunning, on another level completely
thanks to mike for that.
