RST engine problem oppinions please
Old Dec 12, 2005 | 01:39 PM
SPADGE's Avatar
SPADGE
Default RST engine problem oppinions please
A friend of a friend has just bought an RST
When driving it back from Liverpool it lost most of its power and started to smoke under load and use oil.
It has a new turbo fitted.
I just went to have a look at it and the intercooler was full of oil as where the boost pipes.
The engine sounds a little lumpy but ends arn't knocking.
I did a comp test and the results were as follows:-
No1 = 70
No2 = 125
No3 = 100
No3 = 120
I have my own oppinion as to what is wrong but would like to hear yours!
Cheers Spadge...
Old Dec 12, 2005 | 01:41 PM
thebigyin's Avatar
thebigyin
rings,just for starters
Old Dec 12, 2005 | 02:04 PM
Rick's Avatar
Rick
is she breathing heavily?
Old Dec 12, 2005 | 02:21 PM
COMEDY DAN's Avatar
COMEDY DAN
No1 Blower.
Does it only smoke under load or does it smoke on tick over??
If a piston or a ring has failed then the oil will be blown into the airflow meter through the breather system and sucked back in by the turbo, thus filling up the cooler and pipes.
Is the car misfiring at all?
Old Dec 12, 2005 | 02:22 PM
well loss of compression could be quite a few things, but the prescense of so much oil sounds very much like rings.
Old Dec 12, 2005 | 02:23 PM
Stavros's Avatar
Stavros
DEYTUKURJERBS
good call, could be athsma
bolt one of these to the crossover pipe
Old Dec 12, 2005 | 02:29 PM
Mr.h.'s Avatar
Mr.h.
I would say that it sounds like its the rings!
Nick
Old Dec 12, 2005 | 02:32 PM
Did you try a "wet test"?
Old Dec 12, 2005 | 02:36 PM
Shings's Avatar
Shings
similar results to when mine nipped a ring.
Old Dec 12, 2005 | 03:49 PM
SPADGE's Avatar
SPADGE
My conclusion was the rings are fecked but i didn't even think to pull the oil cap off to see if it was breathing much
Dan where is Jamsport is it in MK?
Cheers Spadge...
Old Dec 12, 2005 | 03:51 PM
Westy's Avatar
Westy
northampton Jules..
not too far off of the M1
Old Dec 12, 2005 | 03:52 PM
Westy's Avatar
Westy
plus look at his sig...
the old eyes must be getting tyred
Old Dec 12, 2005 | 03:53 PM
SPADGE's Avatar
SPADGE
Probably right lol
Old Dec 12, 2005 | 08:19 PM
DazC's Avatar
DazC
Spadge, put some oil down the bores with an oil can and do the test again.
If the results are the same, it is probably head gasket or vlaves. If the compression comes up, it's rings/piston related.
Old Dec 12, 2005 | 08:39 PM
rs nuts's Avatar
rs nuts
sounds like its cracked the piston between the rings too me resulting in bad compression which results into the oil being forced through the breather system in too cooler
ive had this problem many times before years ago with rs turbos
Billy_RS
16
Oct 11, 2025 09:41 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
A.t.p
Aug 15, 2015 11:37 AM
Sjieter
Aug 5, 2015 09:47 PM
dlwarrior
Aug 5, 2015 10:19 AM
