St sitting uneven 🤨
Old 09-01-2019, 05:35 PM
  #81
Caddyshack
Caddyshack's Avatar
Originally Posted by RSBryden
hey sorry I have just came back from the garage! I’ve had it on the geo and had all the angles adjusted and rear toe ! The mechanic says I need to replace the rear driver side swing arm as he says the bolt is rotten and looks like a different swing arm to the new one! Hence why the link is pushed out he says???? I’ve just paid £100 for the set up and it hasn’t changed!!!
thinking about cutting my losses and getting rid of it!!!!! Bloody headache
Dont give up now, you are nearly there, just change the bad arm and get it set up, you will have refreshed suspension and it will drive well.
Old 09-01-2019, 05:37 PM
  #82
jonfoc
jonfoc's Avatar
Neither of your last posts sound too positive, thanks for the heads up on redline.
The problem with your car is that it is in need of professional work. I mean that you have changed the dampers and springs, the rear arm, it's got uprated roll bars on it etc etc. The rear end is clearly not right, even the recent mechanic says so. There is a visible difference on the rear arms, a roll bar drop link out of line etc. It's easy for a garage to "line up" the wheels and get it pointing in the right direction. It's not easy to get the geometry correct for the modifications you have.
If you've only ever noticed the difference visually due to the mud flaps I wouldn't worry too much. If you like the way it drives, it doesn't wear tyres etc, then enjoy driving it. Change the rear spring arm and bolt (should really be done in axle pairs) and enjoy the car. Do a bit of research, make some enquiries and if you want to get it set up properly at a proper suspension specialist then do so.
Old 09-01-2019, 05:49 PM
  #83
RSBryden
RSBryden's Avatar
I have just ordered a new rear lower swing arm and a new rear link! Gonna try it and see what happens! The guy at the garage said bring her back when I done the arm and he will adjust the new one for free!
the car drives perfect for me! She pulls like a weapon! Cp320 map, every time I drive her I get excited and can’t help but smile!the new mud flaps rub in the floor if I go round a corner and that has put a downer on it for me! .... it’s a love hate relationship at min
Old 09-01-2019, 06:04 PM
  #84
RichieST
RichieST's Avatar
That's the exact reason I got rid of mine, it needed a clutch, driveshaft, tyres, bit of paint on the bonnet and front bumper and had a niggling fault where it kept going into limp mode, I changed everything trying to cure it but it never went away.
Traded it in for a 1.8 diesel mondeo and it was the second worst decision of my life, I really should have sorned it, bought a cheap daily and fixed it up as I could afford it then used it as a toy.
It's up in Edinburgh now, lad who owns it tracked me down on Facebook.
Old 09-01-2019, 06:08 PM
  #85
Caddyshack
Caddyshack's Avatar
‘I had a wonderful m135i BMW which had an annoying judder and wander at speed, I was a bit bored and chopped it in, the car had some lovely upgrades and I should have just put it in a bmw specialist and got it fixed, I wouldn’t have been much....I do miss that car.
Old 09-01-2019, 06:11 PM
  #86
RSBryden
RSBryden's Avatar
I had the 120 m sport and that had clutch judder! Only every now and again! Spent a fortune on her and sold her! Miss like crazy! Worst descicion I’ve done for a long time! This is my 2nd st as I regretted selling my first 🤨
Old 09-01-2019, 07:10 PM
  #87
ajamesc
cossie fan (unluckerly)
ajamesc's Avatar
I’ve an st225. I just got a full polly bush set I’ve done the fronts but rears I’ll do when I can be arsed lol. The bolts are known for seizing in the bushes and needing cutting out. I got a full rear bolt kit ready to do the job for 50 off eBay
Old 09-01-2019, 07:17 PM
  #88
RSBryden
RSBryden's Avatar
That is cheap as mate! What kinda mods have u on your st, I love the look of the ST
Old 09-01-2019, 07:24 PM
  #89
ajamesc
ajamesc's Avatar
Not had it long I got it cheap 2500. It’s on 143 thousand miles. Pulls well it’s meant to be 280. I’ve done the front bushes fitted a cat back mongoose system. Full service fixed the drivers seat. I’ve tidied up a few bits it drives fault less I really do like it far more than I thought I would. I’ve replaced the missing under tray as well. Just ordered a new stereo and dab aerial for it and the loom to still use the volume stalk. I think next it will be 20mm rear and 15mm front wheel spacers and a bigger front intercooler. I’ll not go too mad as I’m more interested in my Sierra.
Old 09-01-2019, 07:42 PM
  #90
RSBryden
RSBryden's Avatar
lovely looking car mate ,don’t see many in black down my kneck of the woods dude.
i had spacers on mine but the wheel nuts kept coming loose, ended up getting the st3 wheels for mine as they r wider! Et 45 I think! I don’t no for sure. Fit flush with the car now.is urs a st-3
u got a saph?
Old 09-01-2019, 08:02 PM
  #91
ajamesc
ajamesc's Avatar
Yeah pre face lift st3 so it has leather and the fancy head lights lol. I’ll get the proper hub centric ones
Old 10-01-2019, 03:59 PM
  #92
Received 1,044 Likes on 998 Posts
I thought German cars never went wrong. German reliability and all that lol.
Old 12-01-2019, 03:30 PM
  #93
RSBryden
RSBryden's Avatar
Quick update guys!
brought 2 new rear swing arms and drop links fitted those and still no change!
So the car has
new front rear shocks
new springs
new drop links front and rear
both rear lower swing arms
the car is still sitting on the piss! The left side is still lower than the right!
Old 12-01-2019, 03:33 PM
  #94
RSBryden
RSBryden's Avatar
Old 12-01-2019, 03:34 PM
  #95
Caddyshack
Caddyshack's Avatar
Time to get a good mechanic / engineer, technician to look at it, who who knows setup. Mark Shead is not a million miles away from you.
Old 12-01-2019, 03:37 PM
  #96
RSBryden
RSBryden's Avatar
we’re about a is he!
i had a couple garages look at it n they say it might have hit a kurb once before and could possibly have damaged the lower control arm on front maybe ?
Old 12-01-2019, 04:11 PM
  #97
Caddyshack
Caddyshack's Avatar
Old 12-01-2019, 06:22 PM
  #98
gcfcos
gcfcos's Avatar
The left arm looks like it's hanging down a lot more than the right to me or a different arm?
Where it's bolted
Old 12-01-2019, 06:29 PM
  #99
RSBryden
RSBryden's Avatar
Where it's bolted
that’s just we’re its be been off and the spring as been put it! When lowered to the floor with the wheels on they sit identical! I measure the distance between most of it! Had the toe adjust to suit also
Old 12-01-2019, 06:31 PM
  #100
RSBryden
RSBryden's Avatar
both arms purchased form fords today! £80.12 each! Must just be the light showing they appear different
Old 16-05-2019, 10:24 AM
  #101
SapphireIRL
SapphireIRL's Avatar
Just reading this thread and found it interesting, did you ever get it sorted ? Mark.
Old 16-05-2019, 11:21 AM
  #102
ajamesc
ajamesc's Avatar
I just fitted polly bushes to the upper and lower rear control arms on mine what a cunt lol. I’ll do the proper rear arms when I get some lower springs as mine looks like a big foot with wheel spaces on standard springs
Old 17-05-2019, 07:55 AM
  #103
Were all the bolts tight as fook and rusty??
Old 17-05-2019, 08:10 AM
  #104
ajamesc
ajamesc's Avatar
Mine wasn’t to bad luckily lol I had a full bolt kit in case I had too cut them off
project rs
22-05-2007 07:48 PM
jconstant
04-05-2007 07:03 AM
Matt
34
13-02-2007 05:49 PM
clivest170
Ford Mondeo Including ST
15-08-2006 08:36 PM
daviddunlop83
10-02-2006 07:43 PM
Quick Reply: St sitting uneven 🤨
