gripper diffs..?
Old Aug 19, 2011 | 01:01 PM
gibbo frst's Avatar
gibbo frst
Default gripper diffs..?
hello..
i have a new gripper diff in my 2wd saff and it has a banging noise coming from it.. when you come on boost and the car starts to pull properly it bangs like its taken some slack up.. driving normally round town has no bang.. ive removed my solid beam mounts which has made the bang quiter as i thought it was the beam moving at first. it does the clunking on tight bends which im not bothered about just wondered if anyone had any advice on this.. i did buy it s/h but looked like it had never been used inside or ever had oil in before.. ive got castrol saf-xj 75 / 140 fully synthetic oil in it..?
thanks for any advice..
Old Aug 19, 2011 | 01:05 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
if it was a banging noise coming from the diff it would only be a back lash problem due to worn diff bearings or the pinion moving about due to worn pinion bearings (or bearing adjustment to lose) and would do it when ever you take up drive i carnt see it being the diff if it only dose it when coming on boost have you checked the prop center bearing the prop u/j,s and the diff mount
Old Aug 19, 2011 | 01:08 PM
Staffi's Avatar
Staffi
Sorry to HI-JACK Gibbo,
but i await cossie4i
Old Aug 19, 2011 | 02:27 PM
DAN-Saff's Avatar
DAN-Saff
Have you checked your cv joints for play?
Old Aug 19, 2011 | 02:30 PM
dojj's Avatar
dojj
Resident Wrestling Legend
cossie 4i had the same problem
apparently he put some oil in it and it fixed it for a while
then he put the corerct oil in it and it fixed it better
Old Aug 19, 2011 | 02:59 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Mine don't make any banging nosies when coming on boost, it just grinds when turning left and right.
I have 80/140 fully synthetic oil in mine.
Steve
Old Aug 19, 2011 | 03:30 PM
Staffi's Avatar
Staffi
Is yours ok now Steve??
Old Aug 19, 2011 | 03:36 PM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
No idea, its on my work bench lol
Will fit it over the weekend as im off work.
Steve
Old Aug 19, 2011 | 03:45 PM
TimC's Avatar
TimC
Gripper, or plated diffs to be precise have a tendency to make knock and clunk when moving at slow speeds around corners, whether it should do it at high speed in another thing though
Old Aug 19, 2011 | 06:23 PM
gibbo frst's Avatar
gibbo frst
hi.. its hard to explain the noise its not a backlash slack type of noise more of a clunk and its only the once so pulling through the gears its only one klunk on initial pull. say open up in 2nd and normal driving no klunk then start to pull harder and it happens then not again until go round a roundabout and pull again.. 1 clunk..
ill look into it more next week but guess it could be cv joint related..
like i say its used to be a bang until i took the solid beam mounts off for poly ones and now a klunk noise... fucking cars doing my head in
Old Aug 19, 2011 | 07:20 PM
DAN-Saff's Avatar
DAN-Saff
Why did you take the solid beam mounts out?
Old Aug 19, 2011 | 07:28 PM
gibbo frst's Avatar
gibbo frst
took them out as i thought the noise could have been the beam moving on the mounts as when i jacked the car up i could lift the beam on the mounts.. i know they do this but thought the metal to metal noise was a bit much.. now back to poly mounts and its nicer to drive around these shitty bumpy roads...
Old Aug 19, 2011 | 08:22 PM
DAN-Saff's Avatar
DAN-Saff
Red face
My beam doesn't move on the solid mounts :/ I did the same I swapped back to polys but Ive now swapped back to solid ones.
You could also check the diff is still bolted tight in the beam and rear diff bolts
Old Aug 20, 2011 | 06:33 AM
gibbo frst's Avatar
gibbo frst
I thought the beam should move on the mounts up and down a bit when off the floor as the mounts are cone shaped and that's why some people use a flat poly rubber between mount and body to minimise the movement. The metal bush don't bolt the beam flush to the body.
Either way it's much nicer back on rubber I'm getting too old for a bumpy car
DaveCrack
11
Aug 12, 2015 05:20 PM
scoooby slayer
Mar 31, 2009 01:11 PM
scoooby slayer
20
Mar 23, 2009 07:59 PM
smitsturbo
Jan 9, 2008 11:51 PM
smitsturbo
Jan 8, 2008 07:18 PM
