Corsa XE conversion question? - Chip?
Old Feb 27, 2008 | 10:25 AM
XRT_si's Avatar
XRT_si
Default Corsa XE conversion question? - Chip?
I know a few people have done this on here, but I ve got a mate who is currently fitting one but he's been told you need a quick shift gear linkage as it pops out of hear round corners if you dont?
I used to have a XE nova and have a mate who's built one himself but never heard of anything like it before on Corsas? Is this right?
Old Feb 27, 2008 | 10:26 AM
Cowboi's Avatar
Cowboi
i'll put it on vauxsport for ya mate.
someone will know!
Old Feb 27, 2008 | 10:29 AM
Chip's Avatar
Chip
*** Sierra RS Custard ***
Yes what he has heard is correct, you have to chop a bit out of the linkage to change the gearing/position of the linkage if using an F28, thats what I did on my mates recently.
www.vauxsport.com is certainly the best place to get details, there is an awesome thread on there with everything you could ever want to know about XE'ing a corsa:
http://www.vauxhall-sport-forum.com/...orsa-t106.html
Old Feb 27, 2008 | 10:30 AM
Cowboi's Avatar
Cowboi
he is just using the f20 chip.
does it still apply?
he was told that if he goes to fast round a corner in 2nd or 4th it'll pop out of gear unless he get a quick shift
Old Feb 27, 2008 | 10:32 AM
Chip's Avatar
Chip
PS
Corsa linkage is the one of the left.
Its about 10mm ( IIRC but check on vauxsport ) that you take out of the side of the seesaw that is at the top in this picture
Cowboi, yes same issue with the F20 too as far as im aware although ive never tried one on a standard linkage in a corsa personally to see exactly what happens, but basically you dont have enough throw on the standard linkage, so when the engine rocks and moves, it can cause issues.
Old Feb 27, 2008 | 10:42 AM
Cowboi's Avatar
Cowboi
yeah i can see the problem, on the nova you can turn the nylon bit round and 180 degrees which extends the linkage.
but the corsa one is sideways and dont look possible to do that with.
do you know of any decent guides for a let into a nova?
its already been an xe so a lot of it is done, but it would be nice to have a bit of info on welding the f28 mount on, and things like the intercooler.
cheers
XRT_si's Avatar
XRT_si
Excellent help cheers Chip!
Old Feb 27, 2008 | 10:49 AM
Chip's Avatar
Chip
cheers
F28 mount is available off the shelf from chris astley mate, its honestly not worth messing around making one.
Order from here:
http://www.chrisastleymotorsport.com...29a9f5792fb29f
Or drop him a PM on VS, as im not sure if he can do a bit of a deal on that or not, worth an ask!
The Intercooler thing is impossible to do a guide on really, as everyone uses a different intercooler, and obviously the fitting is entirely dependant on what you use.
You arent spoil for choice space wise on where to fit it though!
Old Feb 27, 2008 | 10:52 AM
Cowboi's Avatar
Cowboi
was always gonna buy one.
just wondering how people do it.
is it a case of bolting the engine in on 2 of the mounts and using a jack on level it up.
mark where the mount will sit, remove the engine and weld it in?
or are there measurments as to where it should be?
its not the easiest thing lifing an engine like that into a nova so i didnt want to have to do it more than necessary lol
Old Feb 27, 2008 | 10:55 AM
Chip's Avatar
Chip
Yeah you just attach it to the box, lift the box up to where you want it, tack the mount in place.
Then unattach the end of it that goes onto the box, and get on with welding it up properly. (access is awkward for some of it if you dont split it apart and take the box half back off)
No drama though mate, its all straightforward, you can do it with the engine in place still.
Old Feb 27, 2008 | 08:40 PM
Cowboi's Avatar
Cowboi
cheers mate.
hopefully i'll be able to sell my elec f28 and get a mechanical one soon then i can get it up and running.
Prickly_buzz
Dec 7, 2017 09:52 PM
Cosnada
Jan 7, 2016 05:30 PM
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
liamT74
Sep 23, 2015 10:24 PM
