Engine is running
Old Aug 29, 2006 | 07:13 PM
Default Engine is running
..after installing FPR and oil pressure gauges..oh and the EEC4 plenum cover
..never seen oil pressure like it...fooking 85psi at idle when cold
...Hi pressure pump?
After getting to drive this car a while i am more disliking the greys setup...its an old style map..so fuel consumption is crap driving round town...co is about 10% ...and the L6 is shite for throttle response....roll on L8 and 1000cc injectors
Old Aug 29, 2006 | 07:29 PM
ECU Monitor Enthusiast
What engine ?
Which car ? (you have so many)
Dont drive it hard until youve had it remapped as you will melt it ....
Old Aug 29, 2006 | 07:30 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
When you going for a GT series turbo then Phil?
Old Aug 29, 2006 | 07:33 PM
Simon i doubt it will melt at how rich it is,more like flood Infact you have to hold it at 3k until the plugs warm up to stop fouling The old school days.
Its safe enuff,have all gear to moniter it
pee vee's Avatar
pee vee
I thought you had grown out of gauges ??? lol
an oil lamp to tell you the engine was already fukked was all you needed the other night ..
still, fukkin ace motor though!
Old Aug 29, 2006 | 07:35 PM
pee vee..i know i know..i had gauges there looking at me and bank holiday monday So they went in
Pennywise.....map is comming courtesy of Karl ...just looking for the cheapest GT35 setup
Old Aug 29, 2006 | 07:37 PM
Charlie Chalk
Unknown.
Nice one
Old Aug 29, 2006 | 07:40 PM
Rene's Avatar
Rene
Another one bites the dust
And another one gone, and another one gone
Hey, Im gonna get you too
Old Aug 29, 2006 | 07:41 PM
Originally Posted by MAD YUM
Oh dear its going to end in tears
Dave, for once I will back Phil on this and dont see why it should go
wrong as long as he does what he says he is doing.
Old Aug 29, 2006 | 07:45 PM
PMSL @ this post.
I thought you were going to say "on a GT35" or something like that
When in fact you had an engine that was running, you fitted a new fuel pressure reg and a new plenum and it still runs, its hardly news worthy
Looking forward to hearing about it on the GT35 setup when you have it done though, any plans to take it to either a set of rollers or brunters to see what its actually putting out?
Old Aug 29, 2006 | 07:49 PM
Chip its news....had a few issues with the new setup..cause of old map.
Yum...never had an engine blow ....so no tears..as i moniter my engines
...the thing is i dont hide if anything goes wrong its a bonus..as new thread
Old Aug 29, 2006 | 07:52 PM
What issues?
Is it on the same map now as it was before?
If so its a shame you changed the FPR as well or it would have made for some really interesting comparitive data (assuming the map was safe enough on both setups) to have done 6000rpm at 2 bar on both plenums and see how the AFR changed between them as it would have shown you which one flowed better and how much by, rather than just taking other peoples word for it etc
Old Aug 29, 2006 | 07:55 PM
...issues of..i got a massive spec engine and on MAD previous setup it was running a higher fuel pressure to compensate the xtra air consumption..and i have no idea what it was set at....but Mark is gonna tell me when i send old FPR as i cant test 2wd pressure.
Plus fouling plugs issue!
As said roll on GT35!
..and yes it will be doin things.
Old Aug 29, 2006 | 08:03 PM
Phil, you should have just asked for advice mate!
All you needed to do was have it idling till you got a steady AFR reading out of it on the old FPR (still on old plenum)
Then take it out and note the AFR at 6000rpm @ 2 bar or whatever
Then change to new FPR, and adjust till you got the same steady AFR at idle, and problem solved you have (to within a few psi) the same pressure, which you can then adjust to get the same at 6000@2 bar and you know that its almost identical then
Then change the plenum over, run it up on the same chip and at the point the AFR starts to lean out a touch you know you have just found the point at which it flows better, obviously then richen it up a touch from there.
These things are really straightforward if you have a methodical approach and you would have learnt a lot more about the relative flow of the two plenums too
Old Aug 30, 2006 | 09:22 AM
..surge..what surge?
..have no clue really mate..i would think i may get a flutter at 5-6k revs..not sure really but you will all be the first to know!!!
..will be very interesting to see how it goes...it will be a fairly safe map from the ignition side so not running full potential until its tweaked..have all monitering equipment so cant really blow to be fair.
Old Aug 30, 2006 | 09:42 AM
Ryan's Avatar
Ryan
phil maybe we can get 2 GT35's cheaper?
Old Aug 30, 2006 | 11:56 AM
fordsportjay's Avatar
fordsportjay
Default Re: Engine is running
mine runs 90 psi from cold oil pressure since i fitted the hp pump.
get the car to msd and get their 850cc siemens injectors in it and get it live mapped on a l8.they have just done mine and its flying now.
Old Aug 30, 2006 | 12:12 PM
..i think my 1000's and L8 with gt35 and a karl map will suffice
Old Aug 30, 2006 | 12:14 PM
fordsportjay
ok
Old Aug 30, 2006 | 12:16 PM
bud-weis's Avatar
bud-weis
Football Cwazy
Phil,are you gonna have it Live Mapped,or just get him to send you a suitable map?
get the work done and i'll buy it off you.....cheap
Old Aug 30, 2006 | 12:18 PM
...karl will send me an off the shelf map with a couple of degrees ignition retard over a std map....the fuel map will be virtually spot on...all in his opinion..and as i got all monitering equipment i can tweak it fot ultimate safety...i am yet to decide what happens after..all depends on my plans
Old Aug 30, 2006 | 12:21 PM
bud-weis's Avatar
bud-weis
Football Cwazy
Sounds good
Old Aug 30, 2006 | 12:23 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Phil,
whats wrong with the throttle repsonse on a L6?
Old Aug 30, 2006 | 12:27 PM
bud-weis's Avatar
bud-weis
Football Cwazy
Originally Posted by CossieRich
Phil,
Change to L8 and you will see
in all seriousness though,when i upgraded to L8 the difference was amazing,so much more dosile at low speeds,smoother pulling out of junctions,and definitely felt smoother when going back on the throttle..also had a lot less black smoke with L8 when jumping back on the throttle
Old Aug 30, 2006 | 12:42 PM
Porkie's Avatar
Porkie
...issues of..i got a massive spec engine .
would hardly call it massive!
ported head, cams and low comp???
Old Aug 30, 2006 | 12:52 PM
YBP's Avatar
YBP
Phil,
You changed the ecu and retained the exact same map? Unless u did your comparison is useless I´m afraid.
(Not saying there can´t be a difference between the two.)
Bosch-Man:
Why go GT-35 and ruin the car´s drivability totally? You also need to change the inlet and everything again to make use of that turbo.
Lars.
Old Aug 30, 2006 | 01:15 PM
I believe L6 has less resolution on the map.
I already think L8 is too restricted really compared to modern ECU's, so i certainly wouldnt want to go any less.
Porkie, i did think that but was worried Phil would take it personally if i pointed out the obvious that his spec is pretty tame in the grand scheme of things, its not like its dry sumped on a custom crank and rods and running nikosil liners etc
As far as i can gather from whats been posted its:
standard lifters
standard block
standard crank
standard rods
standard pistons (machined a little)
standard valves
standard sump
standard oil pump with a firmer spring
standard dizzy arrangement
ported head
hotter cams
probably a decent head gasket
As you and me both well know though, the standard engine is so good that it really doesnt mean that spec wont be good for some pretty monster power (500bhp+ seems very realistic) but it does make you wonder what Phil would think about the various engines some of us build in terms of how "massive" their spec was in terms of the number of modified parts!
Old Aug 30, 2006 | 01:30 PM
Porkie's Avatar
Porkie
I think it uses new Cosworth racing pistons actually rather than machined standard ones. Nothing wrong with spec, and the standard parts can make HUGE power!
but to call it a 'massive spec' is silly!
Old Aug 30, 2006 | 01:35 PM
Unusal choice for a road engine needing to do high milages (due to needing a larger P2B clearance)
Cheers for correcting me on that though if thats the case
Indeed, as i just mentioned above too
Or more to the point just shows how little Phil knows about the difference between a basic uprated build like his and a "massive spec" engine in the first place!
Old Aug 30, 2006 | 01:39 PM
Thats not massive Dave, it isnt even on solid lifters
Old Aug 30, 2006 | 01:42 PM
But it hasnt got much of the standard parts left in it has it
Heavily modded block
Steel rods
Custom pistons
Custom crank
WRC inlet
Custom exhaust manifold
Not much standard there mate
Old Aug 30, 2006 | 01:46 PM
......when i say massive spec i mean massive enuff to hold 600bhp with ease ..so far from std Chip...thats the problem with guessing to try win more browny points with other forum members
Porkie..you seem to be the same as Chip..do you ressemble him in other ways too?
Mad Yum...i have no idea on power 600 would be nice....and with this spec engine and that turbo and enuff boost maybe just maybe on pump fuel
YBP if you read my other posts the EEC4 cover is a temporary thing to restrict power until diff and gearbox uprated...it will run a modest 500bhp to start with. ..although i may well see if a the std box/diff will take full power...i test not read books
Old Aug 30, 2006 | 01:50 PM
Would be interesting to see if thats also Mark@MAD's opinion on it
In what ways?
Feel free to correct any item on that list i put up which is wrong (like porkie did the fact you have the basic upgrade of cosworth pistons not standard ones.
you seem interested in talking about your car, so im sure you will enjoy sharing the spec
Old Aug 30, 2006 | 01:52 PM
...oh your wrong on pistons BTW ..runs the CP ones as per Rods old engine before incident. ...oh and iskys...oh and long studded block..etc etc...its a massive spec to me and 600bhp is massive BHP to me...
How about Chip would you call him a massive bloke?..I would..but he aint that massive compared to sum..but still massive to the smaller person..ROFL
