EEC4 TB/ISCV & Antilag ???
04-05-2006, 08:00 PM
Can an EEC4 throttle body and idle speed control valve etc be modified for anti-lag??
Lee
Lee, have you thought about a remote ALS valve?
04-05-2006, 08:03 PM
Not really, wont need one if the eec4 stuff can be modded as my iscv isnt used for idle speed controling now
Lee
04-05-2006, 08:09 PM
are you running the closed loop
04-05-2006, 08:13 PM
04-05-2006, 08:15 PM
I don't think he is Basky.
Just a thought Lee. If the EEC 4 one can't be used/modified then you could just get a fitting for the end of the normal ALS/idle valve which just has 2 push on pipe fittings.
04-05-2006, 08:19 PM
I'm listening...
explain a little more for me please daz?
Lee
04-05-2006, 08:23 PM
lol , your not allowed als
04-05-2006, 08:24 PM
2 seconds Lee. I'll look for a picture...
04-05-2006, 08:31 PM
how much air would you like to flow sir ????
enough to hit the limiter with the throttle closed and no retard ???
04-05-2006, 08:42 PM
Quote:
Lol,
I'm sort of hoping i'll need it when the tyres are on
These extra valve ideas are cool and i will certainly look down that path if the eec4 ones cant be done,
Lee
04-05-2006, 08:48 PM
you should be able to open the eec unit with a voltage to fully open relativley easily, this will defo give you some help.
04-05-2006, 08:52 PM
My iscv is already used for anti lag (kenny mapped it with an antilag file etc) allbeit very mild (approx 3-5psi increase due to the iscv and tb being standard) i'm actually wondering if it is possible to machine/modify for a greater increase like the traditional valves and tb can be?
Lee
04-05-2006, 08:54 PM
is it fully open when its being used ? i would have though a fair bit of air might flow through them ?
you couldnt really make the valve flow anymore air because of its internal dimensions really.
04-05-2006, 09:04 PM
is it fully open when its being used ?.
Not sure mark... do they not just fully open and fully close?
Lee
04-05-2006, 09:12 PM
Lee
no they dont , they can do any where in between, by pwm or duty cycle
Tay69
16-01-2007 02:19 PM
20-02-2006 11:37 PM
39
20-02-2006 03:49 PM
cossiedave
11
15-01-2006 09:14 PM
