My new engine spec what do you think?
EEC4 block
Linered
Forged racing pistons with cut outs
Big ported head 25mm in 26mm out
Secret cams
Brand new std crank
Balanced rods
Std genuine bearings
All Grp A bolts
WRC long studded
WRC 4 layer head gasket
Std 2wd sump
4 x 1000cc injectors
EEC4 inlet manifold and throttle body
RS500 Intercooler
GT30 with external wastegate.
7.9-1 comp ratio
Weber Level 8 ECU
Mapped by Karl Norris
Apparently this will feel like a T34 .63 so spool up time not too bad but rev to 8k making around 550bhp The ultimate road engine?Was going GT35 BUT realistically on pump fuel i am only going to get 550bhp because of comp ratio so a bit pointless having the xtra lag.Of course on race fuel i'd be knocking on 700bhp with the 1.06 housing but i couldnt get that on the road as 102ron is expensive
Linered
Secret cams
Brand new std crank
Balanced rods
All Grp A bolts
WRC long studded
Std 2wd sump
RS500 Intercooler
7.9-1 comp ratio
Weber Level 8 ECU
Originally Posted by Bosch-Man
Thats a tidy spec mate BIG UP THE BOSCH MAN
I like only having me as an audience
Keep up son The Escos is a solid 370ish BHP on a 38000 mile engine,my new Saff is on a low comp hi spec 10000mile stage 3 job.. the engine mentioned in this thread is my DIY effort thats ready and built just waiting for turbo ...3 VERY strong YB's baby
Sponsor
yes remember now sounds like its guna be fun phil
cheers jay
Originally Posted by 3dr-rally-slag
get it in the car with the turbo you have- it needs to be run in anyway
Will be in very soon,just trying to locate a EEC4 plenum cover,rs500 type intercooler,waiting for injectors,thats about it bar the turbo..so as you say i will most probably just bung the rally turbo i have on the Saff currently, on it to run it in as the map i have from Karl is for this engine but on a gt35 so will be no bother off boost
Originally Posted by andrek12345
sounds good phil... will we see any of your cars at the shows this year?
I tried a Skyline but didnt do owt for me (R32 GTR) nearly went STi Scooby (new shape) but i couldnt get away from Cosworth hence the Escos
*******C O S W O R T H---------R U L E S********
Re: My new engine spec what do you think?
EEC4 block
Linered
Secret cams
Brand new std crank
Balanced rods
All Grp A bolts
WRC long studded
Std 2wd sump
RS500 Intercooler
7.9-1 comp ratio
Weber Level 8 ECU
Linered
Secret cams
Brand new std crank
Balanced rods
All Grp A bolts
WRC long studded
Std 2wd sump
RS500 Intercooler
7.9-1 comp ratio
Weber Level 8 ECU
What with the 1000cc injectors, your chosen mapper wont touch it when he realises they were mine. Remember those injectors will expect to see Torque & guess why that aint going to happen .
Rod
Rod
Strongest block which runs oil jets for better piston cooling,the plenum is bigger than the 4x4 thus allowing upto 550bhp whereas the 4x4 around 460bhp Larger throttle giving better off boost drivability...etc etc
It would be prudent to get the fuelling checked.
The oil squirters are a very good idea though, if im building a big power turbo engine and there arent squirters already i will machine the block to install them, its something people often overlook!
Compression is too high in my opinion. You will have to run capped boost or (like you ) heavily retarded ignition.
It wont be a problem at high rpm.
That may fit in with what Phil wants, it certainly suits me with how i like to spec FWD turbo engines and anything with a fragile gearbox!
Originally Posted by DogSmoke
Phil, why the secret cams? Are you worried the tuners will rip off your ideas?
A) they are specced by a tuner who doesnt want details given
B) phil has picked a couple of off the shelf cams and doesnt want to say what
C) phil is having a laugh, by poking fun at tuners who give spec lists that are bascially useless info as they dont give cam details
JoeyBoyden
04-01-2024 02:36 PM
09-10-2015 07:38 PM
oilman
Trader Parts for Sale.
30-08-2015 08:37 AM
