Tourqe settings for sump plz ?
As above troops any help even tips appreciated , doing it tomorrow for 2nd time , each time leak gets less so fingers crossed
doing it dry this time
usually just ranked the sump bolts up but iLL do it right this time
arrghh doing my head in
![Clap](https://passionford.com/forum/images/smilies/9c-clap.gif)
Iv'e been there mate, did it three twating times before i got it to seal
Definetaly do it dry mate, maybe just the slightest smear where the oil pump meets the block.
As for torque settings:
5-8 nm, leave for a minute or two to settle then 5-8 nm. Thats just a half deasent nip if ya dont have a good torque wrench
SHIT !!!! Put on block first
dont see how that would work though what i mean is that is so much harder whats the script with item 7 on that sheet
![Surprised](https://passionford.com/forum/images/smilies/shocked.gif)
Easiest way i found was to remove sump and old gasket, clean as much oil as you can from gasket face on the block. Put a small ammount of silicone around the groves in the oil pump and the rear main seal carrier. Offer up the gasket and hold it in position with a few bolts, press the gasket into place around the oil pump and rear main carrier. Allow the silicone to dry then remove the bolts.
The gasket should now be stuck in position, refit the sump and use the above torque settings/sequence.
Originally Posted by ballin
mate its a little more complicated than that i think, have a look at this:
![](http://www.aseo23.dsl.pipex.com/sump.gif)
stage 1 : 6-8Nm
stage 2 : 8-11Nm
stage 3 : 8-11Nm
Hope that helps![Top](https://passionford.com/forum/images/smilies/smile011.gif)
stage 1 : 6-8Nm
stage 2 : 8-11Nm
stage 3 : 8-11Nm
Hope that helps
also be sure to keep an eye on the gearbox side of the sump as it is usally the one that slips out of its groove.
weld the sump on
Best thing you will ever do i had my engine taken out and its still leaking. Going to be taken out the 2nd time so this time i'll be using genuine gaskets. Please use genuine gaskets as i have found out the hard way.
I always clean the block and sump mating surfaces, put some sealant on the pump joins etc then smear grease along the block mating surface, that way when you put the gasket on it sticks to the block and all you have to do is put the sump on
Make sure you put the sump in place real quick because after about a minute the grease loses its stickyness and the gasket will start to come off
Ive used this method for both the one piece and four piece gaskets and never had any leaks
YAAA dancer !!!!! finally got it after 3rd attempt it was a nightmare of a day though , but got it this time
hope i never go through that again , spent nearly £60 on sump gaskets now
but thats it can look under my car and have a dry road now
![Banana](https://passionford.com/forum/images/smilies/banana_dance.gif)
