Overheating
Old Sep 25, 2018 | 07:35 AM
Mathias's Avatar
Mathias
Default Overheating
Hi,
the RS Turbo S2 from my friend Is overheating dramatically. Normal driving through the village is already a problem.
Attempts to solve the problem:
-) original Ford water pump
-) radiator from airtec
-) coolant circuit vented forever
-) Spal fans
-) switches to start the fans very soon
-) driving without thermostat
-) head gasket check and fine
-) head was sent to a company, 100% okay
Car runs hot original and with chip. Performance of the engine is great. Lambda values perfect.
We honestly don´t know how to go ahead.
Are some engines known to have troubles with coolant circulation? Installation of an electrical water pump?
Opening up of the head gasket holes to the cylinder head?
Old Sep 25, 2018 | 08:50 AM
focusv8's Avatar
focusv8
Is the engine actually hot is is it just the gauge indicating hot, when it isn't?
Old Sep 25, 2018 | 10:11 AM
Mathias's Avatar
Mathias
Engine is hot. Water in the tank is boiling as hell. You feel unsafe standing next to the engine bay.
I know that the gauge can´t be taken as realistic measurement.
I have checked the forum here very detailed. There are a lot of threads regarding this topic, but I haven´t seen one where the problem got solved. On the other hand there are highly tuned cars on the road without
any troubles.
Old Sep 25, 2018 | 11:49 AM
nigel b's Avatar
nigel b
have you tried a new expansion bottle cap?
Old Sep 25, 2018 | 12:58 PM
Mathias's Avatar
Mathias
bottle cap new. more or less everything is new. As sad as it sounds, we where hoping that the head gasket or head where foowked...
Old Sep 25, 2018 | 05:14 PM
GVK.'s Avatar
GVK.
Is the return hose to the bottle blocked?
Seen it before where the return on top of the bottle has a brass pipe in the plastic which gets blocked and causes loss of circulation
Old Sep 26, 2018 | 05:18 AM
Mathias's Avatar
Mathias
HI,
"bottle" is the expansion tank? It is also new and works.
Old Sep 26, 2018 | 07:55 AM
Mark Shead's Avatar
Mark Shead
any troubles.
check the temperature correctly and don’t guess.
Mark
Old Oct 5, 2018 | 05:31 PM
Rsmat's Avatar
Rsmat
Mark
beat me to it ...take readings before guessing.
Old Oct 18, 2018 | 05:55 PM
kevin john bird's Avatar
kevin john bird
Hi,
-) Spal fans
not f800 yhb in grey is it
Old Oct 19, 2018 | 10:23 PM
GVK.'s Avatar
GVK.
What, in AUSTRIA?
Old Oct 23, 2018 | 08:05 AM
Mathias's Avatar
Mathias
Hi,
no...
Bigger radiator organized, new intercooler setup, mocal oilcooler, 88°C fan switch,... installation in the next couple of weeks.
Jim Galbally
Jun 21, 2004 09:08 AM
Toe Knee
Dec 7, 2003 05:26 PM
Toe Knee
Nov 24, 2003 04:51 PM
RS-adam
Sep 25, 2003 08:33 PM
