Rs turbo ofab conversion
I have fitted a fiesta rs turbo engine loom to my s1 rs turbo to convert to efi but was wondering if you have to change the pins on the ecu or is it you only have to change them if you use the xr3i loom
Escort RS Turbo
HI Mike,
I have just done this conversion on a 1.1 bonus and will be firing up at the weekend,
If all goes well, i will share my detailed wiring diagram with you.
I have used an XR3i EFI main harness and an OFAB ecu, with XR3i EFi fuel tank but you can use the S1 tank, Do you have an OFAB Map sensor and Air charge sensor?
Thanks
Rich
Thanks
Rich
paceo
14-07-2009 11:51 PM
GUZZLER
29-05-2007 05:02 PM
