Dax kitcar turbo zetec project - 400hp+ goal
Just got the engine back from the engine shop after I had dropped it off semi built needing a head job!
The spec is as follows
2 litre silvertop engine
Farndon forged conrods
Forged low compression pistons (JE iirc)
Metal headgasket
Block - stripped, cleaned and re-bored to suit the new pistons
Area Six cylinder head job with oversized valves and area six valve springs
Stock cams
New parts throughout the engine inc ACl main bearings etc etc
Here's a few starting pictures
I have most of the other bits, big injectors, Bosch 044 fuel pump etc etc
I discovered this on getting the engine back home....
which I am severely pissed off about, especially seeing as it was expensive work anyway
I can't be 100% it wasn't like that before it went but hey, if you building an engine up you would surely tell the customer the gearbox mount on the sump was cracked?? It looks like it has been dropped to me, but I cant be sure.
I am going to take this up with the engine shop, but is it worth welding this or trying to get a new silvertop 2 litre sump and getting a new oil fitting welded on etc?? talk about backwards steps
Metal headgasket
Stock cams
Shame about that. I doubt you'll have any redress on them as you've taken it away from them. They claim you did probably.
Where in the mighty Sheffield are you? I'm a Halfway lad myself
I'm from Millhouses mate. I know halfway well
Should be fun, I built a big spec RWD Zetec turbo, if you need to know anything let me know
And regard the sump; will you even be using that sump in a RWD kit car? Usually have to fit a Raceline sump or similar for something like that.
Thanks for the input guys. I will defo call upon your knowledge as soon as I am balls deep into it
Focus RS I think mate.
Rads are already in, they are custom ones behind each rear arch but they are a bit manky so I will be replacing them with something suitable.. Not sure on the intercooler but it's decent quality and suitable size.
It was over engineered for the current setup (mocal oil coolers etc). Will post some pictures of it all in the next week or so when I start stripping it down.
A bit of background:
This is how it was/is (although I have done a lot of new wiring on it and put hydraulic struts on the doors, it is mainly stuff that isn't visible)
In the flesh people generally love it... in pictures some love it , some hate it
But I love it and always have since I test drove one years ago when I couldn't afford to build it hence why I bought it as a project.
It is currently running a 1.8 silvertop zetec with a turbo conversion on it.
It was dynoed at 240hp on dyno dynamics. I have no idea how as they map on the ecu is not very efficient by all accounts (ahmed bayjoo sorted me a new Pectel T2 when the other one cooked itself).
Anyway, I am basically ripping it all out and starting again, new engine bay loom (I have done the rest of the car), new proper fusebox and relay setup.
Strip the suspension and shotblast, powder coat and replace as required.
I have new wheels to go on it, some billet image split rims I bought ages ago and am going to get polished before they are on.
The engine setup is effectively the same layout as they current one.
The sump should work as its only the same as it what it runs now.
Dry sump is an option I may do but I have already blasted my budget to get to this stage
so another £2000?? is not really that tempting. I will be running an oil pressure alarm and if I do blow the engine I will rebuild it with a dry sump
Unless anyone is selling a kit second hand??
Gearbox is currently a ford diesel one. I am going to fit a Focus RS one and suitable clutch, and then get the (right hand) gearchange linkage modified as required.
I'm sure there's a tonne of obstacles on the way. One of them being the exhaust manifold may not quite fit when on the engine, and I may need to get a custom one (crazy cage..!)
XRT_si - cheers mate I will defo need all the help I can get!!
update/// The sump is getting sorted. Im taking it back to the machine shop who are going to repair it as good as new which is good of them.
Aah Millhouses, I used to live in a apartment opposite Michelle's bar. The good old days. Keep up with the build and updates.
anyhow back on topic.... is there any alternative to dry sumping?
From my reading it seems that some people have run 400hp+ with no oil pump failure, but more have had oil pump failure!?
Seems to be pot luck on the oil pumps, as you've said there's some that have run without issues, iirc it's harmonics that do the deed in the end, you can get uprated gears but it's not uncommon uncommon for those to fail too.
If I get too scared I will go down that route. Likewise if the oil pump fails and I save the engine, I will go dry sump!!
Ah, that's why it doesn't need a RWD sump
When you said Dax I immediately thought of a Rush.
Up to 400bhp and a moderate rev limit I'd be happy on a standard oil pump, though Black Tops seems to cope better. Anything over 400bhp is a ticking time bomb, just depends how lucky you are before a catastrophic failure occurs and wipes out the engine IMO!
I've known cars last awhile at 400+bhp but only Black Tops and it will always be on your mind. Failures happen regularly and billet gears do nothing to help it.
Your dry sump alternative is the single stage external oil pump kit by OPI. By far the best thing on the market and if I was doing one agin I wouldn't think twice about ordering one.
Some info about them here:
http://www.burtonpower.com/opi-exter...e-opidsk3.html
That looks a nice kit. They are out of stock for 2 weeks to a month though it says...
Dry sump kits - http://www.burtonpower.com/catalogue...4-page-34.html
For the titan - its 1175+ vat for the 3 stage one... Does anyone know if this comes with everything needed??
I am unsure what to do now loll
A decent tank is £150-250, and the fittings cost around £15-20 each and you need a lot of them! The line costs about £15-20 a metre in the bigger sizes! It soon gets very expensive, I ended up selling my dry sump kit again
Why did you sell the kit again mate?
Are you running without it now?
As for blowing an engine up, depends which bit as someone has probably had an engine failure somewhere in the world with one.
If it blows up it's going to get replaced with a YB engine, no doubt at all.
I could have built a YB engine to a slightly lesser spec for what I have spent on this motor !!
Mid engined rear wheel drive
Yeah, it should be pretty rapid with 400.
I have got my eyes on some 1/4 mile action though so it will be slow compared to some real quick cars on there!!
I think it will be an ever evolving project!
JoeyBoyden
Jan 4, 2024 02:36 PM
Matt Baxter
Sep 16, 2015 08:30 PM
