2000e Fuel pump issue plz help!!
Old Jul 19, 2014 | 01:12 PM
doga-ot's Avatar
doga-ot
Default 2000e Fuel pump issue plz help!!
I have saph boa in 2000e shell fuel pump is not workingso got a cossie pump but cant find the 2000e pump, i can see the fuel filter
Old Jul 19, 2014 | 01:19 PM
mk2grp1's Avatar
mk2grp1
going sideways in a fwd
pump maybe in tank
Old Jul 19, 2014 | 01:35 PM
martysmartie's Avatar
martysmartie
As said, it will be an intank pump.
Martin
Old Jul 19, 2014 | 03:05 PM
doga-ot's Avatar
doga-ot
Old Jul 19, 2014 | 03:41 PM
costina's Avatar
costina
Live long and prosper!!
Dont forget there is a cut out switch located drivers kick panel on later sierras not under the spare wheel
Old Jul 19, 2014 | 05:13 PM
doga-ot's Avatar
doga-ot
Mines under spare wheel in boot and that's all ok!
Old Jul 19, 2014 | 05:50 PM
focusv8's Avatar
focusv8
Maybe a crossover model and got both...
Old Jul 19, 2014 | 07:52 PM
iansoutham's Avatar
iansoutham
OCD Victim
Only hooded dash Sierra models had the cutoff behind the kick panel. All others were in the spare wheel well
Old Jul 19, 2014 | 08:45 PM
doga-ot's Avatar
doga-ot
So if i got 2000e tank and internal pump what do i need if i want to fit cossie pump? I have the pump, filter and bracket
Old Jul 19, 2014 | 10:56 PM
stevieturbo's Avatar
stevieturbo
C**t
Complete tank/sender etc from the external pump car..
Really..it would be easier just to buy the correct pump for the car you have.
Old Jul 20, 2014 | 12:49 AM
Cossie Sean's Avatar
Cossie Sean
big floppy donkey dick
Very dunk here so bear with me here
if you can diagnose your fuel pump problem at this stage,
use the in-tank twincam pump, on a seperate relay`d wiring loom to feed an external swirl pot, and use the cosworth pump to feed from the swirl pot to the engine.
both pumps relay`d and reliable once the issue is sorted.
i take it the fuel filter has been changed recently?
Old Jul 20, 2014 | 03:44 PM
Good tip that Sean..
Old Jul 20, 2014 | 03:56 PM
anglia105e hinson's Avatar
anglia105e hinson
Or.................
Recently my mates sierra estate twin cam keep blowing fuel pumps we actually had to change 2 full sender and pump units , then on the 3rd time we couldn't get one .
After having taken it in and out the tank a few times, we realised that it looked the same as mk3 fiestas and mk5 escort pumps.
So we had the whole unit out of the tank pulled the pump off the bracket carefully you have to bend a tag out the way that supports it then unclipped the wiring .
We then put a mk3 fiesta SI pump back in
( we crossed referenced part numbers and they were the same )
What I'm trying to get at is that people put escort Cossie pumps in fiesta turbos .
So surely what we have done can be done with a escort Cossie pump.
Meaning that you ain't gotta change the tank/lines/filters add a swirl pot.
Old Jul 20, 2014 | 04:26 PM
stevieturbo
C**t
All very well saying add an external pump, or a swirl tank...
But surely the reason he's asking is because the in-tank pump is fucked, and needs replaced regardless ?
So anything external or add on, is a total waste of time.
Old Jul 20, 2014 | 07:26 PM
mk22door's Avatar
mk22door
Fart of the Purniture
Hiya Wez, your tank will look like this...
When me and my mate did mine the first time, the original idea was to fit the sender and pump from the 24v Granada tank, reason being I had read a lot about people saying the twincam 8v pump is not suitable for the 24v Cosworth engine, so I wanted to make sure and use the pump that came with the engine in the Granada.
Some people say that the 8v twincam pump is alright but I wanted to rule out any doubts while I was fitting a new tank.
BUT the unit as a whole will not fit the Sierra tank so we had to swap the pump out of the 24v unit and put it in with the sender and feed pipe from the 8v...
So, you have two choices, use the in tank set up or buy a YB pump suited tank.
I don't like the mix and match idea personally, your best off keeping it as simple as possible to rule out any possible snags you may encounter.
Good luck whatever you decide.
Old Jul 21, 2014 | 03:37 PM
doga-ot's Avatar
doga-ot
Right totally forgot about this thread so I bought saph cossie tank and sender as I already had bracket/mount and saph cossie fuel pump so now gotta work out fitting it etc
Rob Wells
Ford Mondeo Including ST
Apr 18, 2023 12:19 AM
JK12
33
Apr 26, 2021 12:09 PM
xrmalin
Sep 13, 2015 06:52 PM
CrOwSoN15
14
Sep 3, 2015 12:21 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
