PC help, folder permissions
Old Jan 10, 2014 | 09:33 PM
Fil's Avatar
Fil
ELASTIC BAND
Default PC help, folder permissions
just installed a new ssd drive just for the OS, what to copy a few bits off my main HDD, as in my IE favorites folder, but when i click my name on users i get
in the past ive clicked it and all; has been well, this time tho the location bar goes green step by step, but 20mins later still just green and nothing happening?
any ideas people?
Old Jan 11, 2014 | 07:44 AM
TommysKeeper's Avatar
TommysKeeper
In installing the SSD drive and fresh copy of the OS (which one by the way?) it believes that the folder belongs to someone else. You may have used the same username but they are all converted to numerics - and obviously what it's created this time does not match the old value.
Did you click on the "continue" as shown in your picture? And if so what happened?
Cheers, John
Old Jan 11, 2014 | 09:11 AM
Fil's Avatar
Fil
ELASTIC BAND
win 7
yep used the same username
when clicking continue the bar along the top grows green and fills up the top bar, but nothing else.
martysmartie's Avatar
martysmartie
What users/groups are in the ACL?
Martin
Old Jan 11, 2014 | 10:49 AM
Fil's Avatar
Fil
ELASTIC BAND
acl?
whats that then? or wheres that?
Old Jan 11, 2014 | 11:06 AM
martysmartie
ACL= Access Control List
I haven't played much with the lower versions of W7 (assuming yours is?) but in the case of XP Home Edition, you have 'Simple File Sharing', only with the 'Professional' version you have proper access control (and even that wasn't enabled in a workgroup environment)
If this trait follows in 7 you might not have it, either way if you go into the folder properties and click the 'security' tab, it should list the respective users, groups and there permissions...
Martin
Old Jan 11, 2014 | 11:34 AM
Fil's Avatar
Fil
ELASTIC BAND
will have a look in a bit when I get back home . cheers
think its win 7 ultimate edition tho?
Old Jan 11, 2014 | 02:24 PM
Fil's Avatar
Fil
ELASTIC BAND
This?
Old Jan 11, 2014 | 04:09 PM
TommysKeeper
The problem is those "Unknown Accounts" which relate to your previous OS. Those numbers are what I was trying to describe in my earlier post.
Click on the "Phil-PC" account and then set "Allow" on all the items below.
Cheers, John
Old Jan 11, 2014 | 04:19 PM
Fil's Avatar
Fil
ELASTIC BAND
They are all 4 of them accounts when clicked on have everything set to allow?
Old Jan 11, 2014 | 04:37 PM
martysmartie
Cheers, John
Administrators have full control anyway, those accounts referenced by there 'SID' number won't make any difference.
OP, it's going to be an ownership issue, in the 'Security' tab you have an 'Advanced' option at the bottom, then the 'Owner' tab, you will probably find the current owner is referencing an unknown account, you therefore need to take ownership of the folder.
Martin
Old Jan 11, 2014 | 08:56 PM
Fil's Avatar
Fil
ELASTIC BAND
bugger.
so clicked something to allow permissions, that's been running for a few hours and said unable to do it,
now that harddrive dont show up in my computer? also doesnt show in the bios?
Old Jan 11, 2014 | 09:01 PM
Fil's Avatar
Fil
ELASTIC BAND
Oh and it's really slow to boot now?
Old Jan 12, 2014 | 11:06 AM
Fil's Avatar
Fil
ELASTIC BAND
well the drive has reappeared now?
Still unable to access it tho
Old Jan 12, 2014 | 11:18 AM
martysmartie
From what you are now saying it sounds like it may be a hardware or configuration issue as the permissions look correct, rather it is stopping at the copying stage.
Martin
Old Jan 14, 2014 | 07:42 AM
Eagle's Avatar
Eagle
Super Moderator
may help ..
http://technet.microsoft.com/en-us/l.../cc753659.aspx
http://windows.microsoft.com/en-us/w...#1TC=windows-7
Old Jan 17, 2014 | 09:30 AM
Fil's Avatar
Fil
ELASTIC BAND
cheers Eagle that 1st link sorted it, took several hours of the PC running and giving each file permission, but have not got all my favorites, docs, music etc working
thanks
Old Jan 17, 2014 | 10:57 AM
martysmartie
Martin
thanks
Lol that's what I said here ^^, glad it's sorted though!
Martin
Old Jan 17, 2014 | 12:28 PM
Fil's Avatar
Fil
ELASTIC BAND
yeah sort of, cheers, couldn't get it to work before, as was changing the main folder permission, needed to do every single file in the folder
Old Jan 17, 2014 | 06:41 PM
martysmartie
When you take ownership of a folder, there is an option to apply this to 'subcontainers and objects' in addition, thus would have saved you a bit of time and work
Martin
Nov 1, 2015 06:53 PM
jonnyenglish
Sep 21, 2015 07:31 AM
Old ford
Jul 31, 2015 06:50 AM
The Sludge
May 3, 2005 10:23 PM
slowpoke
Sep 22, 2004 08:30 PM
