Wireless Network Help Please!!!
Old Feb 20, 2007 | 10:21 PM
James's Avatar
James
Default Wireless Network Help Please!!!
I have a netgear router dg834n linked up to my packard bell machine, this all works fine, the only problem is when i'm on wireless with my laptop [advent].
Some websites it will work others just take ages and ages to load, and normally it goes into hibanation before the page loads. Simple stuff like google, passionford just will not load. Ebay, autotrader, microsoft all work fine.
I've tried IE and firefox and it's the same. Both machines are i.e.7 xp home with the most recent updates from windows update site.
i've done a speedtest.net on the desktop and that came back as 1850kb download and 240 upload, but the website won't even load on the laptop.
any ideas?
Old Feb 21, 2007 | 08:08 PM
nrg19uk's Avatar
nrg19uk
Default arrgghh
try hard wiring the laptop too the router see if it does the same, could be lots of things firewall antivirus software
Old Feb 21, 2007 | 09:35 PM
James's Avatar
James
ooops forgot to mention that, the laptop works fine when connected by cable.
Old Feb 22, 2007 | 08:38 AM
DanRSturbo's Avatar
DanRSturbo
First of all, turn off hibernation and screensavers, secondly, what sort of signal strength are you getting on your wireless adaptor connecting to the router ?
Is wep encryption enabled ?
Old Feb 22, 2007 | 09:18 PM
James's Avatar
James
ok, screensavers and hibernation are off, signal strength is "excellent" 54.0mbps, using wpa2 encryption.
Old Feb 22, 2007 | 10:37 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
That router is a Pre-N router. This is a standard which is not yet ratified which is why the routers are called Pre and not just N.
The wireless in your laptop is probably a B, G or 108G (TurboG) at best... grab yourself a Pre-N card to go with the rangemax router, you need the WN511B draft-n PC Card
Old Feb 22, 2007 | 10:42 PM
Turbocabbie
Top Cab !!
Your laptops standard wirelss card will probably not support WPA2 use WPA or WEP
Old Feb 22, 2007 | 10:48 PM
Turbocabbie
Top Cab !!
I take it you also know that this is a ADSL2 specification router and as such should only be used with a ADSL2 connection such as those offered by Be Unlimited, SKy, Bulldog
Old Feb 23, 2007 | 10:16 AM
James's Avatar
James
Riiiiiiiiiiiiiiiiiiiiiight!
i'm on tiscali adsl unlimited, don't know if thats adsl2 or not, how can i find out?
the wireless setup on the laptop is Intel (R) PRO/Wireless 2200BG Network Connection, is that not compatabile with my router then?
I've just tried switching from wpa2 to unsecured to see what happens and it's still the same.
Old Feb 23, 2007 | 11:12 AM
Turbocabbie
Top Cab !!
I dont know if Tiscali is a ADSL2 service, in general most of the the very high speed connections are ADSL2 such as Be Unlimiteds 24mb connection, I would suggest calling your ISP for clarification on this.
The Intel (R) PRO/Wireless 2200BG most certainly is not wpa2 complient as far as I am aware although some software upgrade may have changed this, there are however connection issues associated with this hardware.
http://www.intel.com/support/wireles.../cs-022509.htm
The issue is basically random disconnection, and I have seen it behave in a manner where it disconnects and reconnects straight after, this causes a page time out which shows as '404 error web page unavailable' in the browser.
Intel claim to have resolved this issue with driver updates, although other people including myself are not so sure.
Having said that the card should work with a 'G' setting and WEP on the router however it will never take advantage of the performance offered by the router and as such I would change it to a card that does once It has been clarified that you have a ADSL2 connection
Old Feb 23, 2007 | 11:22 AM
James's Avatar
James
Many thanks for your help lads, i've found a netgear forum and been searching through there, it seems it's a very common fault and it's a software issue on the router. Therefore theres a update available which i've downloaded and now it's working mint.
Cheers lads!
Old Feb 23, 2007 | 11:24 AM
Turbocabbie
Top Cab !!
can you post the link please, so I can have a read
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Rob_DOHC
Computers, Consoles and I.T.
Aug 15, 2015 11:17 AM
TrickyDicky
Jul 25, 2004 08:22 PM
AlexF
Jul 7, 2004 09:38 AM
