boost problem
Old Sep 8, 2005 | 08:51 PM
Toe Knee's Avatar
Toe Knee
Default boost problem
Basically had the car set up by stu a few months ago and was ok bar leaning out(fucked regulator) holding 1.5 bar and boosting nicely.
While there we found out that some of the turbo bolts had come loose and 1 cross threaded when tightened up so few weeks later took turbo off and replaced all the bolts (had 2 take housings apart 2 clean the thead in housing but aint rocket science )
Put it all back together and ever since then it hasnt felt right By rights when put back together boost setting should have been exactly the same as never touched the actuator, but it was peaking a over 2bar straight away, all pipes etc seemed ok and tight!!!
So wound actuator out a bit and got it to peak at 1.5bar again but, as soon as it hits 1.5bar its backing off to 1bar then slowly climbing again which i swear it wasnt b4 plus every so often its spiking over 1.5bar. Plus when in low boost it should hit about 1bar but its not even making that
Any ideas?! Boost hoses seem ok, actuator pipes ive replaced 2 be safe, just tonight replaced the actuator with a spare one which is supposed 2 be a -34 so will see how that works tomoz, other than leaves the amal valve which cant see it being as hi low boost works fine so deff is workin?!
Any suggestions?!
Cant complain thou least it runs
Old Sep 8, 2005 | 10:17 PM
GrimmeRS2K's Avatar
GrimmeRS2K
only a few things i can think of, amal valve could be playing up
or the pipes to the amal valve, from the turbo to amalvalve and actuator to amalvalve are the wrong way round
Old Sep 9, 2005 | 06:36 PM
Toe Knee's Avatar
Toe Knee
Nah pipes are ok mate their new ones, and in the right place, does the same as before with the other actuator so isnt that. tbh once it hits full boost it pulls ok, just doesnt seem the same to me now as it was before, and its still peaking then backing off
Will take off the amal valve and run a bleed valve just 2 see if it peaks and holds ok and take it from there
Old Sep 10, 2005 | 04:02 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
yep sound like amal valve or air leak between amal+actuator fit bleed let us know
m8
Old Sep 22, 2005 | 08:38 PM
Toe Knee's Avatar
Toe Knee
Well tried the bleed valve does EXACTLY the same thing so stuck what it could be now
Is there anything that could have been done 2 cause it from taking turbo off, replacing housing bolts then putting it back on?!?! As i say had 2 take housing apart 2 clean a thread in the housing with a tap.....
Strange that it'll peak at 1.5, back off 2 about 1bar then slowly creep up again?!?! Almost points 2 actuator but tried 2 which were fine before, unless their both toast Only thing it did do was overboost badly a couple times with the actuator pipe split but shouldnt have damaged anything?!?!
Boost hoses seem ok 2.................. may take it off again and have a look cos its proper pissin me off now
Old Sep 24, 2005 | 12:47 PM
Toe Knee's Avatar
Toe Knee
bttt
Old Sep 26, 2005 | 03:03 PM
Toe Knee's Avatar
Toe Knee
btt for any last min ideas b4 it goes 2 a tuner 2 be sorted cos ive had enuff now
Took the turbo off and 2 of the turbo downpipe bolts were loose so hoped it was that, but its still doin it even with a bleed valve............
Old Sep 26, 2005 | 06:19 PM
abdr500's Avatar
abdr500
did you clean the back plate on the turbine housing
Old Sep 26, 2005 | 09:56 PM
Toe Knee's Avatar
Toe Knee
which back plate
Old Sep 29, 2005 | 02:24 PM
abdr500's Avatar
abdr500
you said you took off the exshust back housing right if so thers a plater behind the wheel that should be clean other wise it will leak ex gases through the exshut and wount boost properly and un even boosting
Old Oct 1, 2005 | 07:19 PM
stealthcossie's Avatar
stealthcossie
Default ????????????
when you dismantled the housings,did you mark them up beforehand,maybe the actuator rod is fouling on the turbo housing or something??
Regards Dave
JK12
33
Apr 26, 2021 12:09 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Marino
Sep 12, 2015 11:10 AM
morg65
Escort MK 5 / MK 6
Sep 11, 2015 01:55 PM
markk
Sep 9, 2015 08:11 AM
