2.0 Zetec Running Rich
Old Nov 30, 2020 | 08:51 PM
billkent22's Avatar
billkent22
Default 2.0 Zetec Running Rich
Hello, would be really grateful for any ideas/help.
I have a 2.0 silver top Zetec in my mk3 fiesta which I put in myself.
I feel it’s running rich as the oil smells of fuel, it sometimes ‘pops’ from the exhaust and kangaroos on light throttle and when it’s warm it hunts on idle.
I have looked everywhere for air leaks, replaced the following sensors with new - air intake, coolant temp, lambda. I’m questioning the MAF but have no way of testing it, I’ve also swapped the TPS for another.
it pulls really well and revs lovely just do t want to do any damage caused by borewash!
Bill,
Old Nov 30, 2020 | 09:21 PM
GVK.'s Avatar
GVK.
Have you tried running it with MAF disconnected?
Old Nov 30, 2020 | 09:51 PM
billkent22's Avatar
billkent22
Hello, thanks for your reply. Yes I did, didn’t seem to make a difference. I did swap it for another MAF and no change.
Old Nov 30, 2020 | 10:01 PM
TristanH's Avatar
TristanH
Standard injectors and fuel pressure reg?
What airbox set up?
Old Dec 1, 2020 | 06:01 AM
billkent22's Avatar
billkent22
What airbox set up?
standard injectors and duel reg, has an open cone (which I know isn’t ideal!
Old Dec 1, 2020 | 06:03 AM
GVK.'s Avatar
GVK.
Have you checked the rubber hose that goes onto the PCV (runs under the coil pack bracket)
Whats the set up of the valve cover breather at the back?
Old Dec 1, 2020 | 06:47 AM
billkent22's Avatar
billkent22
I did actually find a small leak from a poor fitting hose under there and have rectified it.
the breather at the back of the cam cover just has a small filter on it
Old Dec 1, 2020 | 07:21 AM
big_wasa's Avatar
big_wasa
Injector seals go hard on them.
Old Dec 1, 2020 | 09:14 PM
billkent22's Avatar
billkent22
hello, I have changed these when I rebuilt the engine
Old Dec 15, 2020 | 10:00 PM
billkent22's Avatar
billkent22
So I have bought a new (Genuine) MAF to try. Question is can anyone tell me which pins do what on the MAF?
min using a DEEP ECU so I know pin 50 goes to the MAF but not sure which pin and also what the other pins are for.
Old Dec 16, 2020 | 07:52 PM
big_wasa's Avatar
big_wasa
There will be a 12v supply green or may be purple ? A chassis earth black ? A common ecu earth, brown ? The sensor wire white ? It’s a while since I did a pre pats.
s1rst300
Feb 9, 2011 07:08 AM
Ade
Mar 26, 2008 05:55 PM
Luke_si
Jul 31, 2005 11:30 PM
fo0q
Apr 4, 2005 07:47 PM
